Results 1 to 7 of 7
    BBW
    BBW is offline
    Reputation: BBW's Avatar
    Lupine Wilma with 15 and 18 degree lens. Pics!
    I just took a few pics to compare the lens. Camera (Canon SD1000) was set with a tripod and with same manual settings... scroll to the bottom
    http://www.lupine.de/phpBB3/viewtopic.php?f=7&t=1934
    Spanish biker
    Reputation: msxtr's Avatar
    Hi, wowwwwwwww, what a difference!!!!!!!!
    Greetings - Saludos
    msxtr
    Warning!!! my english is very very bad, sorry.
    Easy DIY led light1
    Easy DIY led light2
    The Beast!!!
    Reputation: MaximusHQ's Avatar
    Excellent job BBW! It really does make a big difference.
    M070R-M0U7H FR3NCHI3
    Reputation: Acadian's Avatar
    BBW - is that a lens you added to the light or did you get it straight from Lupine?
    BBW
    BBW is offline
    Quote Originally Posted by Acadian
    Straight from Lupine, just unscrew the top cap, 4 little screws to play with and done. If you live in the US, Gretnabike has them
    it's worth it IMO if you use it as a bar light
    BBW - thanks for sharing those pics are great. It really looks like the beam immediately in front of you is much better, but in theory it sounds like the trade off is the light doesnt throw as far? Has that been your experience or can you see just as far down the path with the new lens?
    BBW
    BBW is offline
    Out of the 4 individual lens? only 1 is different and creates a wider beam. The other 3 are just the same so I don't that much difference in throw... I use it on my HB though....
    I think is the way to go on the Wilma unless you junt want to run it as helmet mount, then it is not so important I guess (but nice anyways)
    Let me know if you have any other question
