    Action LED Lights
    Reputation: Action LED Lights's Avatar
    Lupine Plug polarity help
    Could someone tell me the polarity of this Lupine plug?
    Jim Harger
    Action LED Lights
    www.action-led-lights.com
    dur I am dumb and read the post wrong. I thought this was about something else
    Do you have a multimeter if so this article should explain how to do it
    How to manually check electrical wires for polarity. | Pconthego's Blog
    Action LED Lights
    I'm making up a battery adapter for someone. All I have is a Lupine and Magicshine extension cable that I am going to cut and then splice together so they can share batteries. I want to make sure I get the right wires hooked together but without a Lupine battery to check polarity I need a little help from someone who does.
    Jim Harger
    Action LED Lights
    Reputation: OpenLight's Avatar
    Oct 2011
    You are in luck, I have a Lupine battery on my desk and it is clearly marked with the positive and negative cable. The positive side is the angled side, the negative side is the square side.
    Josh
  1. Help with Lupine connector polarity
    By pethelman in forum Lights DIY - Do It Yourself
    Last Post: 09-03-2013, 06:06 PM
  2. Blatant plug
    By TroutBum in forum Beer Forum
    Last Post: 03-03-2012, 03:37 PM
  3. Should I plug up the holes in my EBB?
    By allroy71 in forum Singlespeed
    Last Post: 10-10-2011, 05:37 PM
  4. Shameless Plug.
    By pisgahproductions in forum North & South Carolina
    Last Post: 08-11-2011, 06:37 PM
  5. A9C - Plug the holes?
    By Turtle71 in forum Niner Bikes
    Last Post: 06-01-2011, 08:58 AM
