Results 1 to 3 of 3
    DCM
    looking for replacement battery for Nimh 6 V 4.0 Ah TurboCat lights
    The nickel-metal hydride, 6 volt, 4.0 Ah, BATTERY to power the S-10 and S-15 lights.
    want same battery it came with the 5 (green battery)pack has "4000 mAh" "Japan FLH" marked on each battery .
    Any place I can order these ? Any link input appreciated D
    Factory Direct
    My earlier long answer disappeared... So here is the short version.
    Order direct from the factory
    TurboCat Bicycle Lighting Systems
    P.S. I still have my S47, S25 and Trailguide systems, even though I haven't used them in a while... Such nice lights.
    Light freak
    Reputation: scar's Avatar
    Jun 2005
    There are many 6.0V Ni-MH battery packs available at BatterySpace that you would not have to mess around with re-connecting up the single cells. Since you already have your old pack open, just transfer over the original cable.
    BatterySpace 6V NiMH Battery Packs / Chargers
  1. Niterider NimH Replacement Battery
    By Albanach in forum Lights DIY - Do It Yourself
    Last Post: 02-11-2010, 02:46 AM
  2. Convert HID light w/ NiMH battery to use Li-Ion battery
    By special k in forum Lights DIY - Do It Yourself
    Last Post: 11-09-2009, 05:13 PM
  3. Turbocat 6v NiCd battery pack replacement?
    By fsr1 in forum Lights DIY - Do It Yourself
    Last Post: 06-26-2009, 10:05 AM
  4. Replacement Light and Motion NiMH Battery advice
    By iggs in forum Lights DIY - Do It Yourself
    Last Post: 11-13-2007, 04:16 AM
  5. Cheap Battery Replacement for Lights
    By dryheat? in forum Lights DIY - Do It Yourself
    Last Post: 07-04-2005, 08:04 PM
