Results 1 to 31 of 31
    Dec 2010
    Light for riding in absolute dark?
    I'm planning on riding along the great allegheny passage in the early March. I might stay on the path till 8 or 9 pm when there is probably no light at all and then merge out and sleep in an inn. Plan to turn on full power for 3 hours a day likely.
    So I need a light that can really brighten the road and erasing the fear for me. One that can unmount easily and used as a hand flashlight is definitely a plus.
    I have a tight budget so thinking about a used flashlight as well. Under $50 will be nice.
    Quote Originally Posted by garage
    This doesn't sound like a good plan. ( correct me if I'm wrong ). If you're riding a remote trail it doesn't sound like a good plan to be riding it at night UNLESS you know for sure the exact timing and places that you will be staying. If it were me I would plan on being at the Inn at least an hour before dark. Unless you've ridden this route before I would rethink this. ( I know nothing of this trail so my comments are based on it being a remote mountain trail )
    I would take two lights. A good dedicated bike light and a good P-7 torch with extra batteries....just to be safe.
    Dec 2010
    Quote Originally Posted by Cat-man-do
    Thanks man!
    Just out of curiosity, what potential dangers are there? I mean it's a biker/hiker only trail so no vehicles.
    A dedicated light, well could you be more specific cause I really know nothing about it. Ones that will cost around $50, used is also OK.
    Dec 2010
    In that price range (<$50), I think you might need to check out some candles.
    Dec 2010
    Quote Originally Posted by koherston
    Ok, so what's like the cheapest "good enough to beat a candle" light?
    Old Fart at Play
    Reputation: Titus Maximus's Avatar
    A black light.
    "... displays the social skills of a barrel cactus." - TNC
    BBW
    BBW is offline
    Reputation: BBW's Avatar
    If you want to ride in total darkness I would suggest to ride with night vision goggles 8=)
    I would get 2 P7 flashlights with plenty of batteries
    BBW. MS, RD
    get a magicshine from dealextreme they are around 70ish dollars with free shipping. if you run it on low settings the battery will pretty much last forever (/troll untill it catches fire and burns your house down). just make sure you order asap usually takes around 30 working days to get it.
    A waste of time it is is
    Reputation: emu26's Avatar
    Quote Originally Posted by FreeGravey
    Yes, and the only company with a reputation it cares about has a recall of their batteries going at the moment.
    Garage, surf Deal Extreme and kaidomain for some torches and rechargeable battteries as Cat suggested. Just make sure you order them early because delivery times can be a bit hit or miss. If you're in a rush then check your local discount outlets etc
    If you are just riding with the one light, and I would advise against this on unfamiliar trails, on your own, at night, then I would stay away from anything that even looks like a Majic shine light. They are not renowned for their reliability
    Quote Originally Posted by BBW
    Sounds like 2 P7 torches would fit the bill.
    Garage, I see that the Great Allegheny Passage is a rail-trail that mostly passes through Pennsylvania. It is well mapped. If you're good with maps, bike computers and/or GPS you should be fine. The web site on the trail has lots of info and is well detailed. Since it is a rail trail you might not need a DBL ( dedicated bike light ). A good 5 mode P-7 torch ( with bar mount ) should be fine. Still, it would be a good idea to have a back up torch. I'd take at least 3 extra batteries just to be on the safe side. On mid mode a P-7 torch puts out about 200 lumens of light and last about three hours with one 18650 Li-ion cell. Since it's a rail trail you won't really need the high beam too much. The chargers are small and light and will allow you to charge anywhere that you are sleeping ( if at an Inn that is ).
    I still hold to what I said in my first post. I think I would be a little wary about riding something like this at night unless you have done this kind of stuff before. IT WILL BE AS YOU SAID, COMPLETELY DARK. You have to be prepared for the unexpected as well. Don't be surprised if sections are flooded, muddy or if there are blocked trails ( with dead-fall ) Things like this happen. Shouldn't be a problem if you ride in the day. At night, stuff like that can cause problems. At least you might be able to get current trail conditions through the web site so that could be a big plus.
    Just remember, there are animals at night as well. Expect to see nocturnal creatures, perhaps snakes, owls, deer, skunks, raccoons, etc...perhaps even a bear, who knows. Anyway, not trying to scare you, just trying to make sure you are *prepared ( * and that said from a very old Boy scout... )
    a light is something I wouldn't want to go cheap on especially if out in a remote area alone
    Jan 2009
    Im surprised no-one has said this but i find when im alone and it really dark i tend to run a lot less power than when in a group. The light pollution form other riders mean your always in a struggle against the other riders.
    Id recommend a pair of XPG-R5's 501's, easily enough power when it total darkness and much better runtimes than P7's.
    With XM-L's now being available im surprised anybody would still recommend a P7 or MCE
    Reputation: random walk's Avatar
    I think it can't be said enough so I'll say it again: have a back-up light and plenty of batteries.
    And even if you rarely/ever use it while riding, a head lamp would be a good idea, for times when doing bike repairs on the trail, bushwhacking to negotiate trail obstacles, stopping to take a dump, etc. Wouldn't necessarily have to be a helmet-mount unit (torch or DBL), a 50-ish lumen head lamp like a Black Diamond Spot would work -- that's what I carry in my pack as a last-resort backup light.
    Also, this thread lists some other sources for torches besides DX & KD. I have one positive experience with DX (two torches work fine), but shipping was long and I have read that occasionally someone gets a dud, so getting a replacement would at least double that time. Just sayin'.
    Reputation: bullcrew's Avatar
    Jan 2005
    This way you have 2 lights!
    My Sponsor House
    "I dont make memories, I make History."
    CANFIELD - AVALANCHE SUSPENSION - SCHWALBE - TLD
    Jan 2005
    On a serious not, hunt around and try to find a good deal on a SOLID light and then throw a mag light in the pack with some velcro worst case you can strap the mag to the bars and cripple your way out...
    -NO LESS than 2 lights
    -NO CRAPPY lights
    Up to you but Id go wait tables for a week to come up with a little extra $ and get a better light.. Hell collect cans and recycle for a couple weeks, use the money for lights then youve gone green too...
    My Sponsor House
    I agree with what the other posters are saying here. Just one additional thing to mention is that it sounds like you are completely new to night riding. If this is the case, the ride you are talking about is not the time to go on your maiden night riding voyage. You'll want to experiment with what works best for you beforehand. Do you prefer bike/helmet mount? Do you have enough light for what you are planning to do? Etc. Definitely be comfortable with night riding as well as your equipment before any serious trip.
    A quick search with google will tell you:
    "The Great Allegheny Passage (GAP) rail-trail offers 135 miles of hiking and biking between Cumberland, MD, and Duquesne, PA, near Pittsburgh. In Cumberland, the GAP joins the C&O Canal Towpath, creating a continuous trail experience, 320 miles long, to Washington, DC."
    These types of trails are very tame, almost like a greenway, so I think all the post about the danger of this are a little overblown. But, much of the info posted here is good advice, such as having two complete light systems for safety purposes. You also won't need nearly as much light as what the typical off road rider on this forum needs to ride singletrack trails. I'm not sure you'll be able to get away with only spending $50, but I think we need more details to really be helpful.
    How many days will you be on the trail? Will you have access to AC power to charge batteries during the trip?
    Quote Originally Posted by moggy82
    I almost always recommend the 5-mode ( pill mounted ) P-7's for bar use. I have three reasons for doing this. First, there are lots of models to choose from. Second, the high beam is about 600lm, perhaps more with the D-bins. Thirdly, when used on mid-mode a P-7 can be very efficient and still have a nice wide ( good spill ) fairly bright ( ~ 200lm ) beam. Very good for moderate trails.
    Nothing wrong with using an XPG R-5 torch as a bar light although the beam patterns tend to be more narrow ( with drop-ins that is ). The XPG is more efficient ( and will run longer as you said ) but when used at lower mode levels the output is not as useful as compared to the P-7's ( unless as you stated, you use more than one ). However with that said, I suppose that is just my opinion. To me total functionality is more important than just efficiency. The throw and/or beam patterns must fit the needs, once again..my opinion. I consider the XPG as a thrower and as such I only use mine on the helmet and mostly on high ( but only when needed ).
    The XML's on the other hand will probably beat everything as far as sheer output. Like the P-7's though, they will gobble battery power when used on high. Also like the P-7's, the XML on mid-mode should still run about three hours but should be brighter than the P-7 and have better throw. The mid-mode on the KD C8 XML torch I own is quite awesome. I haven't been recommending it so much because I'm still testing it. Same with the XML drop-ins. I can't wait to see more XML pill mounted torches. More choice is always better.
    Jan 2009
    For now the P7 still offer the bst choice.
    The reflector on my XM-L Drop in gives it too much of a flood.
    Hopefully gonna play with a few other reflectors to see what i can do about that!
    I cant wait for the SF-15 Host to have the XM-L, would be perfect light!
    Dec 2010
    Awesome!
    Quick question: Are P7s waterproof at all?
    Reputation: Mike Brown's Avatar
    My personal low-tech and cheap opinion- it's a rail to trail for god's sake. If there's a 1/2 moon or more and it's clear out, I wouldn't even turn a light on- just like I don't on smooth gravel road closed to cars or even smooth single track when the moon is nearly full-full, clearn night. 2 20 dollar LED commuter lights should be plenty. Again, it's a rail-to-trail.
    If you do think you might want to venture off into some side trails, then you need a real trail light- otherwise, why would you need one?
    for $50 Only way would be make your own!!
    XPG R5 LED on 20mm star $10.50
    Regina optics $3
    Buckplus driver $16
    Cable glade $2
    Switch and water proof cover $2.50
    18650 tray $3
    Power cord with jack and plug for wiring $3
    Scrap alum sq tubing $5
    Camera bag for batttery holder $5
    300lumens for $45-50
    (4) 18650 battery and charger about $25-30
    Off the shelf gets a bit more pricey but can be done, I'd do this
    $21
    http://www.sbflashlights.com/Solarfo...09-L2m-p7.html
    plus this for $30
    http://www.sbflashlights.com/Thrunit...tage-p102.html
    plus bike mount, batteries and charger, still looking around $75-80 min
    Buy 2 DX Torches. I have SKU 39359 and it works well and has a usable mid-level mode. $20 x 2
    Buy 2 mounts, SKU 31871 for the bars and SKU 12000 for the helmet. $2-3 each
    Buy 4 batteries. I used SKU 28677. $16 for 4
    Buy a charger. I used SKU 1251 for $12. Or get one for cheaper that only charges one battery at a time.
    For around 70 bucks you have a somewhat redundant system that will run for a few hours and can be easily mounted/dismounted. And they will work as flashlights around the house or around the inn.
    Dec 2010
    by the way guys, what specific type of P7 is the best?
    Just looked up on the web and there are soooo many
    From Dealextreme, it's a bit of a crapshoot. You could buy from a more reputable source, but then it costs a lot more and kind of defeats the purpose. I bought a 3 mode P7 and a 5 mode MCE SKU 39359. I much prefer the 5 mode.
    I think you would do well with a 5 mode. High is bright but can get hot and the battery won't last all that long. Low is not a lot of light. Mid seems to work well for me, it's a nice combination of light and duration. And then I can turn it on high for any downhill sections.
    A 5 mode P7 would work. As you said, there are a ton of options. You could buy 2 different ones like I did, then see which one you like more. Or buy 3 and pick your favorite 2 to use on the bike.
    Yes, the SF-15 with XM-L would be nice. Hard to predict though what the beam pattern would look like. Personally, I would like to see the (DX) SKU12060 with an XML emitter. It wouldn't drive it as hard because the 12060 used a driver that only goes to about 2000-2200ma max. Regardless, I like the mode pattern and beam pattern of the 12060.
    It starts off in mid-mode and returns to mid-mode when turned off. I like that. Once again, I don't know what beam pattern would result when using an XML. HOWEVER...
    Since I have an XML drop-in I'm going to test it with the 12060 reflector just for kicks. All I have to do is take the reflector off the drop-in and hold the 12060 reflector up to the emitter with my hands. It won't be perfect but at least it will give me an idea. If I like what I see I'm going to buy an XM-L emitter/board and try my hand at modding.
    Quote Originally Posted by Mike Brown
    Just because it's a rail trail doesn't mean it will be devoid of objects/obstacles. This is not a trail going through a park, it is going through the mountains. Expect the occasional dead-fall, fallen tree branch or unexpected pot hole. Heavy rains can bring the unexpected as well.
    I've noticed on occasion while driving through remote/mountainous areas that rattlesnakes venture out onto the roads when the sun goes down. They like the heat that the road gives off. Not saying you'll see lots of snakes near a rail trail but I have seen them before. Years ago I did stuff like what you said. I still remember riding down a moon-filled park road with no lights on. It is really fun. However one night ( while riding with no lights ) I almost got ran over by a deer. I think it missed me by a couple feet but then again I really couldn't tell. I had to clean the shorts out when I got home that night.
    Quote Originally Posted by emu26
    Geoman Geoman.. you are God.. so hunky.. so funky.. your sea man tastes like chicken! Your bottom shines sun rays!
    On the other hand, Raleigh Bicycles, a bit larger than Geoman, like hundreds of times larger, haven't recalled their magicshine battery packs. There isn't an issue with Magicshine batteries. Nuff said.
    My Magicshine has been great. Over a year old, used many many times, still get the same runtimes as I did when I bought it. 3 hours on high, 8 hours on low, +14 hours flashing...
    Well I did what I said I would do in my last post. I held the 12060 reflector up to the XML emitter on the XML drop-in. It throws out a very nice wide flood beam that is very even with almost no hot spot. Hard to tell how much this would make the throw suffer as I was shining it up against the wall. I think the drop-in reflector would have more throw but also less spill. Darn, I think to get the best of both worlds you need a wider reflector ( like with the C8 ) or a modded Fraen reflector perhaps.
    Jan 2009
    Using an XPG reflector has given this light lots of throw, beats everything else i have hands down, i put the XPG on and it looks bright,but this thing seems to be three times the brightness with even more throw.
    I just want to show my admiration for this guys's courageous sense of adventure. Without men like this the west never would have been won. I wouldn't be surprised to find he is a descendent of the Donner party.
    BTW, bring plenty of snacks- or a sharp knife.
    All bikes weigh 50 lbs. a 50lb. bike doesn't need a lock. a 40lb bike needs a 10lb. lock. a 30 lb. bike needs a 20lb. lock.
    Quote Originally Posted by batvette
    I.... I wouldn't be surprised to find he is a descendent of the Donner party.
    ...hummm....If he has antlers you may be right. On the other hand a red nose might implicate a Rudolph lineage....WAIT!...Oh, you mean those other Donners!....never mind.
