Results 1 to 2 of 2
    Light & Motion Seca 900 battery problem
    We just got a Seca 900 in April and was used for one 24-hour race. Now when plugged in, the charger unit does not light up (battery error). We cannot find our instruction manual nor can we find one on Light & Motion's site. Any suggestions??
    Are you now just charging up the battery from April's race? If so the battery may have been left discharged for to long causing damage to the battery.But now that i think of it you should at least get a red led reading with a bad battery,maybe the charger?If there is no led reading at all,,,,you didn't happen to plug the charger into a plug conected to a light switch in the off position,it's happened before.
