K/D MS 880 clone. Not as fancy as the Solarstorm ( which they sell as well ) but likely do the same job as the other cheap two XM-L emitter lamps. At least these will likely handle heat better and have a decent mode set-up ( press to hold strobe ) Kaidomain looks to have a few two Xm-l lamps that ( while not fancy ) have a decent mode arrangement. Not that I'm stumping for K/D but I just had to tell folks about the MS clone.
Mj880clone does not have exact MS connector, but the headunit fits MS batteries (loose fit and not waterproof), however clone battery doesnt fit classic Magicshine light unit. The problem is the outside diameter that is smaller at 880 clone. Note that original MJ880 has different connector than other MS (it is not round)
I want to mount a 880 clone to my helmet. Looks like it comes standard with bar mount. Is there a helmet adapter available to fit this head? I could mount it 'as is' but it would not have a way to swivel for beam angle.
Let me start with good ones.
-it has indeed XML2 leds
-it has standard Magicshine connector (picture on KD site shows connector from old XML series)
-you get two mounting silicone o-rings and both are small size, so you get a good tension on a handlebar.
-very fast delivery. Less than 3 weeks.
and the bad news
-very poorly packed. Only bubble wrap and standard chinese envelope. But it survived the journey.
-very poor heat transfer design (SSX2 alike). It has slightly different design compare to first version with XMLs.
Does not have leds on stars and inserts but leds are on a custom one piece backplate that fits very loosely.
You can see heat transfer contact area on a picture above. It is only that middle area with some thermal paste on it and some
random contact points at the edges. The main middle wall is thicker compare to old one and if there werent those
huge holes drilled out, but just two small ones for cables, it would have sufficient heat transfer. But now it needs
overhaull!!!! I will make some solid alu inserts to pressfit in those holes and make a bigger contact.
I think that this light is not very good as it is...it is not plug&play, but if you upgrade it, it could be very good.
Driver looks the same.
Tomorrow I will be able to compare brightness between this one and the first XML version.
Finaly...I got a new version KD XML2 880 clone. Head unit only.
...Does not have leds on stars and inserts but leds are on a custom one piece backplate that fits very loosely.
Driver looks the same...
All things considered, the 880 clone still looks to have more thermal contact area ( on the emitter board ) than the SSX2 clones not to mention it has a larger head for added heat dissipation area. Plus, the 880 clone looks ( as you stated ) like you could add extra pieces into the slots but likely you might have to go to a machine shop to get them made. Unless you can make the inserts yourself I'm not sure it would be worth spending the extra money. ( of course that would depend on what they charge you for something like this. )
I bought one in black from Kaidomain (XML U2 version with slim type connection). For the money it's good. Beam pattern is large bright spot and then a large spread. Very good for commuting. Have not taken it apart yet. I like the stealth look
It is hard to believe that the same SS X2 thing happend to this 880 clone. I can see some thermal paste in the middle of the MCPCB. So both "reputable" kaidomain and fasttech are selling some weird clones of clones
I have one heading my way. I'm a bit disapointed that the internals don't have the same design and heat transfer capabilities as the model Kir described.
I also have the 15 and 30 degree lenses coming from fasttech, do you have any idea if they will fit this slightly diferrent design?
bhocewar bought light head only, Kir and I, we both bought the full set and have the same design and just XM-L not XM-L2. My 15deg. lenses stuck somewhere due to lifepo cells in the package so I don't know if they fit, but there is still alternative to buy from DX.
No lens would fit as it is. You need to machine new inserts to elevate leds to correct position. That way you upgrade heat transfer too. I also hope that lens will hold OK. Front panel has 19mm holes, lens OD is 20mm, that gives just half mm at the edges to hold on a rubber gasket. You should avoid those 21mm lenses with plastic shell because it would not be waterproof (or just throw away that shell).
Yesterday I compared 880 xml clone and new XML2 version, and I didnt notice any difference in brightness. Did not find spare time to measure the current draw.
Here is a funny fact:
880 clone reflector fits perfectly in SSX2. IF you want to have smoother transition from spot to flood...I will soon have extra OP 880 clone reflectors available.
I thought that a mix of some copper shavings and thermal paste would might be worth to try, at least you don't need to pay for a precise manufacturing of those pieces. But that is just my suggestion ...
Dont be cheap. Those inserts will cost a few bucks...and will improve heat transfer by at least 500%. I will overhaull my light to the point, it will match the original MJ880.
To be fair the light head is only $29. So how much more of an investment are we looking at here? If it dies you can just grab another cheapo light head. Also it looks like the heatsinking is not as good but how much of an issue Is it really? Is there a good way to measure that?
I did see some people on the blf forums make a heat sink from thick copper wire and solder. Then put it in with a bunch of thermal paste. That may be a budget option
About $15 in material/not including labour/including a few other tricks.
Thermal managment is the most important thing in light design and its performance.
It depends on whether the driver needs cooling or not.
I was thinking about 15° and 30° for a handlebar. But now I am using 7 XM-L as a bar light and 880 clone will move to a helmet light so I probably won't change anything.
My fasttech optics showed up today. Loose fit. Needs to be raised a mm or 2. I fit them anyway with 15/30 combo just to see how it looks. Beam pattern loses the hot spot. Def more flood. But for now I'll run stock until i feel like messing with it. Comparing against my friends yinding light. That thing is 1/2 the size and same amount of light. With a better beam pattern.
Nice work! Inspired me to make a piece for mine so i can use my optics. 15° and 30°.
Much better beam pattern. I am currently running both of my light heads on the bars. I'll do a ride with the modified optics and the stock reflectors to see how I like the difference.
I have the Kaidomain version. Never opened it or addressed the heat dissipation problem - is that something I should do or it'll die on me?
With regards to the beam pattern, I simply cut out a cheap plastic lens (intended to mod some common U2 lamp of larger size) and siliconed it on to one half, like this:
I tried spreading the light from both LEDs but for me this strikes a good balance. Easy, cheap and ugly. But this lamp would still blind people and oncoming traffic so I also added a cap, cut out from a schampoo bottle.
Unfortunately, the cable is complete junk and as you can see the cover is broken already (same goes for the battery pack cable on the other end):
In your minds, what's the easiest way to repair that? Heat shrink tubing would require disassembly - maybe one could just as well switch it out to a new cable all together? I dunno. Just put something glueish on it maybe and see if it sticks?
Anyways, the performance is good. It hangs upside down like this:
...I think you have redefined the term, butt-ugly..
That has to be the largest lamp hood I have ever seen. With the lamp being mounted as low as it is IMO I would think you could get by with just about a quarter of that. Not to mention that having the entire top of the lamp covered in plastic is going hamper the lamps ability to dissipate heat.
Interesting mounting solution. I like it but my guess is that it would have to vibrate/sway quite a bit being so elongated as it is.
Well I tried with a smaller hood first and it didn't provide a sharp enough cut-off for the beam. I want the brightest centre directed as far ahead as possible without deer-ing oncomers to the headlight. And in fact, the lower the lamp hangs, the more precise you have to be.
The lamp never even feels luke warm when I touch it so I stopped worrying about the hampered dissipation. Maybe come summer I have to cut the cover narrower; it's strenghtened with construction glue anyways.
The low mounting serves a purpose: otherwise my handlebar bag would block the light. Also, (especially since I sometimes use a head-lamp) the lower position makes for good road perception. The Topeak BarXtender does its job and I haven't noticed any vibrations or swaying at all. As a bonus I can strap the lamp on in two seconds because I never have to take the rubber mount off, instead just twitching it over the end of the bar.
The battery pack normally goes in the bag. I hate fiddling with that flimsy mounting strap - and speaking of ugly I use a random piece of foam in between the battery and the frame when riding without the bag. With the wire all over the place, straps, pices of foam, a schampoo bottle cap and some random rubber band here and there it has white trash written all over it. Butt ugly would sum it up.
Well it works for you and that is the important thing. You must have a heck of a time trying to reach the mode buttons when riding though.
Have you ever considered a small frame bag? I use a small bag on my road set-up that fits nicely between the top/head and down tube. The advantage of this kind of arrangement is that it helps free up space around the bars ( vs. a handlebar bag ) and I don't need to use a bag under the seat. It's small enough that is doesn't interfere with the water bottle too. I figure with the lamp mounted on the bars you could more easily *adjust the lamp for on-coming traffic. ( * either by tilting the lamp down or changing modes )
Anyway, if you are really concerned about cut-off for the lamp you might consider a dynamo light head. Most of the good ones are designed with cut-off in mind. Matter of fact I've been thinking of going dynamo myself for my on the road set-up but just don't have the money needed to get what I want. I don't worry too much about it though as I have good battery powered lights.
After some time using this light with a couple of other blokes around I found out that the R100 resistor likes to blow up increasing its resistance from 0.1Ohm to xyzOhms. The light seems good overall, buttons all green but it won't power on - actually it does, but the amount of current is very low rendering the leds powered off. Changing the resistor and maybe a increasing its heat dissipation makes the light work fine again. That happens more frequently on the "solarstromified" versions of the 880 clone.
The reflectors have similar dimensions, 880 is OP whereas X2 is smooth. 880 should push more current to the leds. I think the throw difference is negligible. Here is my photobucket album with some lights beamshots including 880 clone and X2. The quiestion is what driver X2 uses, 880 clone uses just one type.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
