Hi Bikerribs, thanks for the kind note. The Spiker 1211 and Niguer 300 are available now. The Sogns are still going through some final tweaks before release. I can't say for sure they are going to be within two weeks from now. Going from experience and this applies to all manufacturers, the timetable almost always blows out. The 900 is closer to release, both in wired and wireless remote versions. New and upcoming models will be published in this link
New Xeccon Models 2013.
Transit times are about 7 working days from order. Just a matter of choosing the best light for your needs. There's always a compromise between weight : brightness : light throw. I will post weights of most models here now. Will separate the helmet/bar and bars only lights from lightest to heaviest. All weight postings includes cables and connectors.
Geinea light head with cable but no remote -
39g - with remote and cables -
90g. Spiker 1211 -
67g. Niguer 300 (more bar) -
99g. S12 Two -
121g. Spiker 1206 (more bar) -
125g. S14 (more bar) -
128g.
Spiker 1207 -
139g. Spiker 1210 -
141g. S6 with remote and cables -
191g. Sogn 900 Proto with controller, cables and alloy camlock -
223g. Sogn 700 Proto with controller, cables and alloy camlock -
289g
BAK 2200mAh with Neoprene pouch -
166g. BAK 4400mAh with Neoprene pouch -
287g. BAK 6600mAh with Neoprene pouch -
337g. BAK 6600mAh Hard Shell -
370g
My recommendation for helmet light will always be S12s. I run two Twos on the helmet. A bit weighty but if we want V12 performance we can't complaint about weight. I can live with 567g nesting on my head because the joy of having a mini helicopter searchlight outweight any discomfort.
If you are after the lightest weight to throw ratio then I recommend the Spiker 1211. Will attach pics to give you perspective. The beam throw is pretty decent considering it's weight. It outperforms the 1206 IMO. Captain's Log: I would like to see a mirror finish version, boosting it with LiPo and possibly upping the amp draw a little.
The Geinea light has a velcro strap. We've posted this pic before but will do it again so you can see how it's attached directly to a helmet which has provision for it. Pic show is actually the rear prototype light we had. The actual colour is the beautifully anodized green and bronze combination. The 1206 is a little too floody for the helmet IMO. I prefer to recommend the 1206 and Niguer 300 as a commuter light rather than a mtb one. If anything the S14 makes a better helmet light.
