Page 24 of 25 FirstFirst ... 14202122232425 LastLast
Results 1,151 to 1,200 of 1224
  1. #1151
    Oct 2010
    Bruce,
    When will the GoPro mount be available in the US? I saw a pic from Interbike and would really like to check it out. Thanks!
  2. #1152
    Action LED Lights
    Reputation: Action LED Lights's Avatar
    Quote Originally Posted by yoeddy View Post
    I'd like to buy an X1 and X2, but it sounds like I should wait for the new versions. Do I understand correctly that they'll be available in about 6 weeks?
    New versions of the X1 and X2 should be here in 3-4 weeks.
    Two reasons you may not want to wait. The prices (on our site) are going up about 10% with the new lights, and I'm offering a 10% discount (from the current price) on existing stock. Discount Code MTBR-GLO.
    Jim Harger
    Action LED Lights
    www.action-led-lights.com
  3. #1153
    Action LED Lights
    The new X1 and X2 are on the way and should arrive before the end of the week. Listings should go up tonight.
    Jim Harger
    Action LED Lights
  4. #1154
    Jul 2013
    Any news on the XS model?
    2014 Trek Fuel EX 9.8 29er
    2003 Klein Palomino
    2000 Klein Adept Pro
    1999 Specialized Hardrock
  5. #1155
    Feb 2013
    Wondering if someone can help me, I just received my X2 V3 and I love it, have used it twice, but I think its faulty (unless im doing something wrong) when cycling through the lights power settings it gets stuck on full and then wont turn off. The only way to turn it off is to pull the power pack, then it wont turn on and the only way is to hold the button in for 15 seconds to reset the light.
    After a reset the light works ok again for a few more cycles but then locks again on the highest cycle and wont turn off. I only press the button once to change cycles and I wait a good 10 seconds between presses. I love the light but this is so frustrating
  6. #1156
    Action LED Lights
    Rotaholic,
    Sounds like you have a problem. If you got the light from us let me know and we'll get a new one on the way to you. If not, contact who ever you got it from and a replacement light head should be simple.
    Jim Harger
    Action LED Lights
  7. #1157
    Feb 2013
    Hey thanks for the quick response Jim, I purchased the light here in New Zealand but wasn't sure if it was user error. I will contact the store I got it from for an exchange/warrenty. Thanks again
  8. #1158
    May 2014
    Hi all, quick question for those who use this light on different bikes regularly (eg, MTB and Commute, on the same day) Is it possible to replace the pivot screw with a thumbscrew of some type ? it seems to me there must be a quicker/easier way of switching between helmet and bars ?
  9. #1159
    Action LED Lights
    Quote Originally Posted by pstanbis View Post
    No reason you couldn't leave the helmet mount bracket on the helmet and just unscrew the mounting bolt. It might be hard to find a thumb screw with the right thread. (I'll have to check on what that is tomorrow) you could also put the O-ring mount on the light and use a Gemini or Magicshine O-ring type helmet mount but you would lose the low profile of the Gloworm mount.
    Jim Harger
    Action LED Lights
  10. #1160
    May 2014
    Thanks for the swift reply !
    Yes, leaving the mount on the helmet was the plan. I hadn't considered the gemini helmet mount though. The DUO was the alternative to getting the X2, and the mount doesn't look too much more bulky than the X2 native mount.
    Re. the thumbscrew, I haven't got the light in front of me, but I kind of assumed it was just an M4 or M5 bolt - was mainly wondering if the light body would suffer, given that it would be screwed/unscrewed at least 4 times a week, at least during the winter months, and also if the clamping pressure would be sufficient with 'finger tight'.
    Many Thanks, once again.
  11. #1161
    Action LED Lights
    Yes, finger tight with a thumb screw would do the job. Your tightening against a couple of O-rings to provide friction. Keep a little grease on the threads and they should be fine as long as your careful and don't get them crossed.
    Jim Harger
    Action LED Lights
  12. #1162
    Slovakia (Europe)
    Reputation: PeterG's Avatar
    ...was mainly wondering if the light body would suffer, given that it would be screwed/unscrewed at least 4 times a week, at least during the winter months...
    2 lightheads would solve that
  13. #1163
    Action LED Lights
    Quote Originally Posted by PeterG View Post
    I like the way you think.
    Jim Harger
    Action LED Lights
  14. #1164
    Slovakia (Europe)
    DIY remote control handlebar mount
    DIY remote control handlebar mount made from BBB Easyfit bicycle bell and 3Mô Dual Lockô Recloseable Fastener . I replaced original velcro hooks on remote control with 3M Dual Lock and the same fastener was used for handlebar mount. Eeasy to do, very nice fit to handlebars, rock solid.
    Bruce, what do you think about such mount as a standard accessory?
    Attached Thumbnails Attached Thumbnails Introducing Gloworm X2 - New Dual XM-L LED light system-remote-control-handlebar-mount_02.jpg
    Introducing Gloworm X2 - New Dual XM-L LED light system-remote-control-handlebar-mount_03.jpg
    Introducing Gloworm X2 - New Dual XM-L LED light system-remote-control-handlebar-mount_04.jpg
    Introducing Gloworm X2 - New Dual XM-L LED light system-remote-control-handlebar-mount_06.jpg
  15. #1165
    Action LED Lights
    Gloworm Switch Mount
    Gloworm has now come out with a mount for their remote switch. Attaching the flat bottom switch to a round handlebar with the included velcro patches has been a less than perfect solution. This new switch mount zip-ties to your bar to give you a secure, flat surface. There now standard with all Gloworm light or available separately if you need an extra or want one for an older light.
    Find it HERE
    Jim Harger
    Action LED Lights
  16. #1166
    Slovakia (Europe)
    Wow, almost as good as my solution .
  17. #1167
    Hi there. Is there a gopro mount?
  18. #1168
    Feb 2006
    Quote Originally Posted by Action LED Lights View Post
    Find it HERE
    Looks like a nice solution, and glad to see the company continually improving.
    I've had great luck using these velcro tie wraps. Also let's me position/rotate the switch if needed and doesn't leave any adhesive residue/portion on the bar when not in use.
  19. #1169
    Action LED Lights
    Quote Originally Posted by greasyrider View Post
    Gloworm is indeed working on a quick release mount that is compatible with GoPro mounts. I don't have an exact date for availability but it should be soon. Individual brackets will be available to convert current lights. Future head strap will use this quick release bracket. It will also be possible to add a QR bracket to existing head straps.
    Jim Harger
    Action LED Lights
  20. #1170
    That's great Jim, thanks for the response. I thought I'd seen something about this ages ago but thought you might have some licensing issues.
    Glad to hear that it's coming along, and look forward to seeing it.
  21. #1171
    Mar 2013
    Hey lads,
    On my X2's the indicator is stuck on the 20% red mark. And doesnít turn off either?
    Is it possible to reset the battery level circuit? Charging it to full and attempting to drain it to nothing currently
    Regards,
  22. #1172
    ww.glowormlites.co.nz
    Reputation: Gloworm Manufacture's Avatar
    Quote Originally Posted by Skarajew View Post
    Hey lads,
    Regards,
    Hey, have just received your email. You'll need to return it to the retailer from which you brought it. They will warranty it. Any issues, drop me another email and we can sort it out for you. Cheers
    Gloworm Website
    '...it's more fun with the lites on!'
  23. #1173
    X2 plus triple
    FWIW, I thought I'd try a photo with my new smart phone on tonight's ride. Gloworm X2 is on the bars and a D/X triple Solarstorm clone on the helmet, both on high. Photo didn't turn out as good as I first thought but then again the phone's screen is HD. Not bad though considering I'm not using a tripod.
    Attached Thumbnails Attached Thumbnails Introducing Gloworm X2 - New Dual XM-L LED light system-local-patap-trail-14.jpg
  24. #1174
    Directed toward ActionLED:
    Jim, I've noticed on my last couple rides that ( at least once every ride ) that I will inadvertently enter the "Stepless adjustment" menu while changing modes on the fly. This usually happens when I am riding fast and switching from standard low to high. To do that fast I have to hit the remote button TWICE in order to skip medium. Problem is if you hit the remote button twice VERY QUICKLY the lamp enters the Stepless program mode. Kind of a buzz kill when in a hairy situation. When it happens you have to stop and reset the mode which is very much a buzz kill. I know not to change modes so fast but sometimes I get caught up in the moment. I know that there were some changes to the user interface with the newer model. Do the new versions still work the same way? Have there been any other complaints?
    Going forward I suppose I could try setting my modes ( L-H-M- ...). That might work but if I'm in mid-mode and want high I'm back to double pressing the switch ( slowly ) again and more often than not I like using the mid-mode for general all around riding. ( low I use for slow climbs and yes I use low a lot too ) I'd rather not mess with my mode set-up because I like the current set-up. Sometimes my finger though has a mind of its' own. Would be great if there were some kind of way to lock the stepless feature while riding. Any thoughts?
  25. #1175
    Action LED Lights
    Cat,
    I will pass the thought on to Gloworm. I've done that myself occasionally. I assume you know that if you double tap when you start up the light you only have two brightness modes. If you find yourself in programming mode, an easy way out is just to unplug the battery for a moment. It reverts back to how it was.
    Jim Harger
    Action LED Lights
  26. #1176
    Slovakia (Europe)
    ...Any thoughts?
    Using of 2-level mode (Medium - Max) for riding with customized Medium according to your taste.
  27. #1177
    Cat,
    Yes, I know Double tap start up for the two mode menu.
    Pulling the plug would be a simple fix but you still have to stop the bike. For people who race perhaps the better option is to use the two mode setting and program the ( press hold ) sub mode to low power for the slow climbs.
    Yes, please pass the idea of a "programming lockout" setting on to Gloworm. With lockout in place the lamp could likely change modes very rapidly just like the earlier editions. If you get any positive feedback on this idea let me know as I'm likely their favorite fanCAt.
  28. #1178
    Anybody bought x2 from crgmoto?
    I bought it 2 weeks ago, asked some questions via email, got instant answer.
    Payed with paypal, and asked for tracking code after 1week and now he doesnt answer at all, ive send like 3 mails after that. Thinking on disputing with paypal.
    And its getting dark here
  29. #1179
    Slovakia (Europe)
    I tried to ask twice at crgmoto about purchase of X2 lighthead only, but haven't received any reply, so finally ordered from Fooh.eu - great communication, offer and service, so bought X2 + X1 finally .
  30. #1180
    Glowormlites UK
    Nov 2012
    Quote Originally Posted by Oppet View Post
    Hi Teppo - it was shipped over a week ago as notified by email. Please check your spam folder.
    Peter - sorry, not sure what went wrong there.
  31. #1181
    Glowormlites UK
    Nov 2012
    Oppet - thanks for letting me know it arrived. International post can sometimes be slower than expected.
  32. #1182
    No problemo. Now doing second charging, first load it show fuel gauge only to 40% when it stopped charging. But we will see
    Edit.. seems to work fine now
  33. #1183
    Glowormlites UK
    Nov 2012
    Thanks for the update. It would be worth checking that the plug adapter that slides on to the charger is pushed in to place with a click so that it is flush with the bottom of the main charger body.
  34. #1184
    Am almost certain there was talk of a gopro mount for the X2. And seems like they have this available along with the light. Anybody knows where to purchase just the gopro mount?
    2014 TREK FARLEY
    2013 TREK RUMBLEFISH PRO
    2012 TREK SUPERFLY AL ELITE
  35. #1185
    Action LED Lights
    Quote Originally Posted by bapski View Post
    We should have them in a week or two.
    Jim Harger
    Action LED Lights
  36. #1186
    Thanks. Just about the right time. Night-riding will be here soon.
    2014 TREK FARLEY
  37. #1187
    Action LED Lights
    The new Gloworm Quick Release mounts have arrived. They will be included with all X1's and X2's orders and are available separately HERE. The head straps now use the same mount. They are compatible with the Go-Pro QR brackets. The helmet bracket is designed to me mounted with a velcro strap but there are also adhesive mounts readily available such as HERE.
    Jim Harger
    Action LED Lights
  38. #1188
    Wahooo! Ordered! And cant wait!
    2014 TREK FARLEY
  39. #1189
    Reputation: Wombat's Avatar
    The new Gloworm Quick Release mounts have arrived. They will be included with all X1's and X2's orders and are available separately.
    Jim
    What's the difference between the X1 and X2 helmet mounts. It looks like the latter has a wider base?
    Tim
  40. #1190
    Action LED Lights
    Quote Originally Posted by Wombat View Post
    Jim
    Tim
    Correct. The wider X2 has a wider base so either light is centered over the mounting bracket.
    Jim Harger
    Action LED Lights
  41. #1191
    Recieved my gopro helmet mount bracket.
    From what i understand from action-led website, it says it includes a velcro strap.
    The one i received did not come with any velcro strap. Did i understand wrong?
    update:
    also ordered the Gloworm quick release bracket and right away encountered quality issues.
    the quick release bracket is attached to a modified gopro mount by a screw that goes into a nut. while attaching the quick release mount to the helmet mount bracket the screw came loose and came off. i thought it just needed further tightening but no matter how i tried to screw it in to its nut, it just would not tighten!.
    just decided to glue the assembly which i hope will solve the problem.
    i have not tried to fit my X1 yet to the bracket and hopefully i would not have issues on that aspect.
    also noticed the picture of the gopro mount on the action-led website comes with a washer which i hoped the mount i ordered will come with the washer included.
    as this washer is small and is easy to misplace, i just thought i would not have to bother to look for a replacement since i thought the gopro mount would have the washer included (as pictured).
    2014 TREK FARLEY
  42. #1192
    Action LED Lights
    Looks like we have some details to work out.
    You should have had a strap for the alloy helmet mount that came with your light. I'll have to see if I have straps to include.
    The washer you are seeing is the larger O-ring of which there are a couple of spares in the small parts bag that comes with the set. You can also use the one off of the alloy mount you are replacing.
    I'll send you a replacement mount for the one with the stripped threads and inspect the ones we have here.
    Jim Harger
    Action LED Lights
  43. #1193
    2014 TREK FARLEY
  44. #1194
    Anybody else have trouble with the new Gloworm quick release mounts? The large velcro band the Gloworm system uses to fasten the helmet mount to the helmet irritates my head, so I purchased a genuine Gopro vented helmet mount. Sliding the Gloworm quick release into and out of the genuine Gopro mount is a bit of a project. It's difficult enough to nearly defeat the purpose of "quick release". It's more like a friction fit than a slip fit.
  45. #1195
    Action LED Lights
    Quote Originally Posted by db_010 View Post
    I looked at a number of the ones we have in stock here and they go together well. (though a little silicone spray makes it easier) Being a new product I would be interested if anyone else is having trouble. bapski above did have one with a small bump on the center rib. You might look for that and sand it down.
    Using 2 straps, one on either side, might work better to fasten the mount to your helmet. If you pull the pads out before installing it shouldn't rub on your head. We do also have self-adhesive ones.
    Jim Harger
    Action LED Lights
  46. #1196
    To clarify, the two parts from Action-Led fit together nicely and clip in and out easily. Compatibility of the Gloworm male clip with a genuine Gopro female clip / helmet mount is what I'm having trouble with, but I've only tried the one Gopro mount. I'll see if I can tinker with it to figure it out someday when I'm in the mood.
  47. #1197
    Jan 2013
    Hi Guys
    Could someone confirm the switching off of the X1 or X2 latest models
    to turn off the x1,
    holD the remote switch.
    the light will cycle through SM, then
    it will turn off.
    Does this means that the light will go through the flash mode before turning off. ie your light going from your steady chosen ouput to a flashes then eventually turning off! I hope I have misunderstood this and the light will turn off without flashing like some light do (very annoying to me)
    Also do they have a memory, ie if you are in high and you turn off the light for a few minutes, when you turn it back on would it still be on high or would you be back to what ever your first set mode was?
    Bearing in mind the difference in price between an X1 and X2 with the twin cell battery pack which one would be better choice as an helmet light. Thanks
  48. #1198
    Action LED Lights
    Quote Originally Posted by Skyraider59 View Post
    Hi Guys
    to turn off the x1,
    it will turn off.
    You have it right in that the light will cycle through Special Mode and then turn off. What that special mode is depends on which program your in (2 levels or 3) or what you have the special mode programed to be. (you can select from dim, flash, or beacon) The only way to avoid the special mode is to unplug the battery.
    No, the light does not remember which brightness level you where in. It always starts in the first level, which can also be programed to be what ever you want. (Such as Hi-Med-Low or Low, Med, Hi)
    Jim Harger
    Action LED Lights
  49. #1199
    Action LED Lights
    In case you missed it in the XS thread, Gloworm now has a new wide angle optic available.
    Name:  X2-XS lens small.jpg
    We will be including one of these with all Gloworm lights we sell from this point on and have them available for existing owners HERE.
    It does an excellent job of spreading the light horizontally only, not up in the trees were you don't need it. Add one or two of these to customize the light to suit your needs.
    Jim Harger
    Action LED Lights
  50. #1200
    Reputation: sherwin24's Avatar
    Hi Jim, I am glad to see they have a wide angle which works better than the flood from before. My question is, how would it be running a wide and the spot in the X2? Planning to order and X1 from you soon, so I am trying to decide if running the spot in the X1 on helmet and 2 wides in the X2 on the bars would be better than one spot, one wide in the X2 with the spot in the X1 as well. Have you run any tests with that configuration?
  1. Niterider dual light system *NIB*
    By wannagoforaride in forum California - Socal
    Last Post: 07-08-2010, 09:48 PM
  2. Recomendations for dual chainguide system for 6.6
    By pocgnikcuf in forum Intense
    Last Post: 11-11-2009, 06:25 PM
  3. Recomendations for dual chainguide system for 6.6
    Last Post: 11-09-2009, 02:20 PM
  4. Intense EX DC Light/ Edge Light/ System 4 Light?
    By Hardtails Are Better in forum Downhill - Freeride
    Last Post: 04-24-2008, 02:24 PM
