Results 1 to 5 of 5
    Action LED Lights
    Reputation: Action LED Lights's Avatar
    How to tell a XM-L from a XM-L2
    I took a close look at several lights with the XM-L led and the new XM-L2 to see if there was a way to tell them apart. I found there is an easy to spot difference. There is a 5mm square board the the emitter and dome are mounted on. For the XM-L that square is green and on the XM-L2 it's silver.
    XM-L
    XM-L2
    Jim Harger
    Action LED Lights
    www.action-led-lights.com
    The better indicator between xml and xml2 is the die, xml has rectangles and 3 leads in the die, xml2 has no rectangle and 2 leads.
    Reputation: Gharddog03's Avatar
    Sep 2013
    Nice!
    Nov 2012
    I thought it was supposed to be more of a white color, but I suppose you are right
    Cree XLamp XM-L2 LEDs
    Action LED Lights
    Quote Originally Posted by mrbubbles View Post
    So I see. But you don't need good light and a magnifying lens to see the color. (at least with older eyes)
    Jim Harger
    Action LED Lights
