Results 1 to 37 of 37
    Help with Magicshine (Geomangear) light
    Hi everybody… I bought this Magicshine from Geomangear (after his recall and with his new battery). I can't recall the model. Can somebody help me determine which model it is? Also, I have a problem with the unit. I did charge the battery the whole day and it seems that it does not have anything on it. The flashlight would not light up. Any ideas on how this thing can be fixed and who can service it? Thanks a lot for your help in advance. Help with Magicshine (Geomangear) light-photo.jpg
    Aug 2013
    Quote Originally Posted by lottel View Post
    can somebody help me determine which model it is?
    mj-808.
    Aug 2013
    From your description, it's not clear whether the problem is with battery, the charger, or the light itself. What about indication lights?
    I left the battery on the charger the whole day. The charger light was green. I plugged it to the light and it was dead. I then re-recharged it. The light on the charger was red initially and then after a few minutes, it turned green. Battery continues to be dead after it was recharged for half a day.
    Reputation: mtbRevolution's Avatar
    Quote Originally Posted by Lottel View Post
    It's a MJ-808. It's fitted with the P7 emitter. Is there a light on the charger when you charge it? If so, is it red when charging or stays green regardless? If it's green while connected to the wall socket and battery and still doesn't power the light there could be any of these reasons -
    1. copper wire torn off at +/- solder point in the light or battery end.
    2. wire torn internally near the connectors of the battery or light head
    3. battery has been overdischarged and locked out. When was the last time you used the light and was the battery charged before it was stored away last?
    4. charger is faulty. Is there a burnt smell from the charger?
    5. driver board is faulty/damaged. The P7 emitter still looks good
    Best idea is to get another set from a friend or a friend of a friend to do a crosscheck. Crosscheck batteries with lights, chargers with batteries etc. You will find where the fault lies eventually. If it's the light head at fault, probably a good idea to just get a relatively good but cheap replacement. It's not worth servicing. An hours labor and parts cost more than a brand new light head 2-3 times brighter. There are heaps to choose from if the charger and Geo battery is still good if not over-discharged.
    Leonard - All things Xeccon + Beyond
    mtbRevolution.com
    Aug 2013
    Seems to be that the battery completely lost its capacity, or is heavily out of balance. What about indication LED on the back of light head? Was it illuminated upon battery connection, and if yes, what color?
    Aug 2013
    Quote Originally Posted by mtbRevolution View Post
    It's a MJ-808.
    Offtopic: how you've managed to write it properly? I've tried several times, but forum autocorrected the letters from capitals, regardless from "Automatically..." checkboxes state under Options...
    When battery is connected to the light, there is no light indicator on the light itself. When battery is plugged initially on the charger, the charger is initially red and then turns to green in ~ 1 min. I used this light a few weeks ago and that it was not charged completely before it was stored.
    Quote Originally Posted by -Archie- View Post
    Didn't do anything special Archie. Don't know why you have that problem. Some are larger than others I guess.
    Took me a while to do the last post with daughter needing me so didn't know the Light Doctor is in the house. Over to you. Does sound like the battery though.
    mtbRevolution.com
    Aug 2013
    Maybe it depends from position of abbreviated word (at the beginning of line or within it). Just curious, and try both variants:
    It's MJ-808.
    MJ-808 it is.
    But you've already identified all the possible sources of problem, so I have nothing to add.
    Is it worth tinkering on this or just buy another one?
    Aug 2013
    I'd follow mtbRevolution's advise:
    Unless you have some friend who can check/repair it for free...
    I loved this light for what it is. Any good recommendation that comes close price wise?
    Or, is there a battery that can be used to replace it if light is still fine?
    Aug 2013
    An updated version, perhaps?
    MagicShine MJ-808E HA-III CREE XM-LT60 3-Mode 1000-Lumen LED Bike Light Set (4x18650) - Free Shipping - DealExtreme
    Aug 2013
    Plenty of them. But make sure it's really battery problem first.
    Any suggestions?
    If you know someone with a 8.4V battery with similar 5.5 x 2.1 DC connectors like yours it will save you a lot of time working out if the battery is at fault. It seems to me its a battery problem and the light is still good.
    Where are you?
    mtbRevolution.com
    Aug 2013
    Any suggestions?
    IMHO, the best MagicShine battery is a MJ-828:
    Buy MagicShine 0.8" LCD 8.4V 2200mAh 18650 Lithium Battery Cell Pack for Bicycle Light
    Bullet-proof aluminium case, reliable mounting by wide welcro, and true 4400 capacity.
    I like turtles
    Reputation: TiGeo's Avatar
    Sounds like the charger to me...they are pretty chincy. I had one my chargers (same GeoManGear 808 set up as you) go bad a few weeks ago....same problem. The indicator on the charger would just turn green even when the battery was dead. I got a new charger for $~10 or so from Action-Led-Lights..problem solved.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Where are you?
    Valencia, CA
    Quote Originally Posted by TiGeo View Post
    Is this what you got?
    Action-LED-Lights ? 1.8A Gemini Charger
    Reputation: Gharddog03's Avatar
    Sep 2013
    What's your budget? Gemini and Magicshine chargers are cross compatible. I use a gemini charger with my magicshine 6030h batteries.
    This would be my choice for a replacement.
    Action-LED-Lights — MJ-872 1600* Lumen Light Set
    Or
    Action-LED-Lights ? Magicshine MJ-808-L2, 4 Mode 1200 lumen* Bike Light
    Valencia, CA
    Since it may be the battery or charger and we don't want to be ordering batteries from China, I suggest you contact Chris of Magicshine and FEREI LED bike lights at BIKEEMPOWERMENT.COM USA. I understand he's in San Diego. Arrange to bring the family to SeaWorld and you kill 2 birds with one stone or if you're lucky he may have someone you can see LA for a crosscheck.
    mtbRevolution.com
    I like turtles
    Nope, this one:
    Action-LED-Lights — Magicshine 1.8A Charger - MJ-6012
    Just email Jim at Action and tell him what you have and he will send you the right one.
    Some info in this thread. Staying tuned, as I have a similar problem with one of my cheap single led clones. I suspect it's the battery on mine.
    Anyone in southern cal that has this charger?
    With no indicator on the light itself, my first thought is that it is a bad cable on the light head. My MJ-808 from Geomangear in 2009 kept going bad at the cables - in the original battery (but Geoman worked hard to make sure the Geomangear replacement battery was safe - mine is still good even now), the extension, and the cable coming out the lighthead itself. It could be the battery or charger, but I'd think about the light head first. Check the cable carefully for cracks in the sheath, especially at the connector or any kinks. Do you have a multimeter? If so you could check the voltage on the battery and charger.
    I like turtles
    808s have an indicator light on the light head...its the button.
    Sent from my SCH-I545 using Tapatalk
    I know that, since I have one, as I mentioned. I wasn't precise in that sentence. I meant that since the indicator light wasn't lighting up, as the original poster was saying in the portion that I quoted, he should check out the cable carefully.
    Sep 2013
    I think it will be best to purchase a new light set and if your battery, lighthead, or charger is good just use it as a back up.
    Hi Lottel, apologies if we seem to be further rather than nearer to a resolution. Let's start over again. This is what we do for non-customers who contact us with problems we can't determine or be sure of; We get them to send the whole set to us. They include an identical self-addressed return satchel inside. We check it over, and if we find the fault to be battery or charger etc, we will inform them. They purchase the replacement item and we send it back to them with the original items including the faulty item.
    Suggest you contact Jim from Action LED instead. Tell him the issue and ask him if you can arrange this with him. Action's website sells light head, charger or battery only so just purchase the one he says is faulty. He pops it in the self-addressed satchel and all resolved within a week if you use USPS Priority.
    mtbRevolution.com
    After much tinkering, I found that the plug that connects of the light to the battery is defective. Is this repairable or best for me to just buy another one? If it is repairble, where can I get it repaired? Thanks a lot for your response in advance.
    Aug 2013
    You can buy standard 5.5/2.1mm plug in local electronic store, but it won't maintain watertightness and fixture of original one. Better way is, to order MagicShine extension cable and solder it in place of damaged one. This will require light disassembling and some soldering skill, though...
    If you are certain the fault is at the connector on the light side then I concur with Archie for Option 1 below.
    Option 1: Get the extension cable here. Action is cheapest plus $2.07 postage. Cut off the male end and have someone solder the red and black wire to the +/- of the driver board inside the MJ-808 light head. I was looking out for a business or handy electronics guy in Valencia/Santa Clarita for you. Small computer shops like this may be the only ones who will do small jobs like this. They have great soldering skills and heaps of time IMO. Give them a call and explain you need faulty cable with DC connector de-soldered and new one re-soldered to a PCB inside a LED light head. Ask for recommendations if they don't.
    Attaching a pic to give you an idea what's involved. This is an 808E which is similar to yours internally. The red and black wires on the right of the screen are the ones to be de-soldered and re-soldered. Replacement wire is on the top right.
    Option 2: Get the extension cable anyway. Do it the lazy way. Cut off the faulty connector, slide in an old pen cover. Use that as a short 1.5 - 2 inch tube. Attach the red and black wires together then use some electrical tape and insulate them from each other. Slide the re-attached section inside the pen cover and inject silicone at both ends of that tube. Wipe off excess. That should waterproof the connection.
    Option 3: If it's all to hard or end up being expensive then get the 808 L2 light head only from Action here. Postage is less than $3. It's brighter than the one you've been using. For less than $60 with a full years warranty, it's certainly worth considering.
    Attached Thumbnails Attached Thumbnails Help with Magicshine (Geomangear) light-dsc06594.jpg
    mtbRevolution.com
    Considering you can buy these for $20 these days....and the fact that simple repair is over your head....is it worth putzing with?
    Action LED does repairs for reasonable prices. They do warranty repairs, but also out-of-warranty repairs. Jim quoted me $10 plus return postage for a cable replacement for my out-of-warranty Gemini Xera. That's barely more than the cost of an extension cable. He's certainly not making bank with repair work and that's appreciated on this end - great service. Maybe because he's a authorized service center for Gemini, and he's invested in supporting Gemini.
    I'm not sure he will have the same price for an Magicshine repair, but it's worth asking for a quote. On product support part of his website, he says that for Magicshines, he only warranties the Magicshines that he sells, but can repair out-of-warranty lights for a fee.
  1. 2 cell Magicshine battery w/ Magicshine tail light?
    By INABIL in forum Lights and Night Riding
    Last Post: 11-12-2015, 02:02 AM
  2. Geomangear Magicshine
    By smittylube in forum Lights and Night Riding
    Last Post: 01-12-2012, 02:32 PM
  3. which magicshine light?
    By RTM in forum Lights and Night Riding
    Last Post: 09-27-2011, 04:29 PM
  4. New Magicshine XM-L light
    By HakanC in forum Lights and Night Riding
    Last Post: 07-11-2011, 01:44 PM
