    Helmet light weight?
    I purchased a Fenix BTR-20 planning to use it as a helmet light. I thought I'd mount the lamp and battery both to the helmet. The lamp and battery sizes allowed such an installation. Problem is just walking around I felt like I had a brick on my head. Read somewhere the Fenix weighs 380g. So is there a cut point for how much weight feels ok on top of your head? Thanks.
    Quote Originally Posted by keen View Post
    There is a cut-off point but it is different for every rider. Usually I have no problems mounting just the lamp to the helmet but on occasion some lamps are too heavy. Once you mount the lamp mounting the battery to the helmet ups the ante. Usually if I try to mount even a two cell battery I have problems. The only "confined helmet", setup ( lamp/battery together ) I ever use is a an Ultrafire 501-B torch. Other than that I will mount the dedicated bike lamp to the helmet and put the battery inside my hydration pack and use an extension wire.
    May 2005
    My neck is usually tired after a couple hours of riding without the weight of a light on the helmet. I sure do not want the weight of a battery added to the helmet so I carry it in my jersey or jacket pocket. Current favorite helmet light is ~60 grams. Pretty much can't tell it is up there.
    Jan 2013
    I also use an Ultrafire 502b flashlight, modded to make 800 lumens. When I tried it on my Fox helmet, the location of the top vent was more forward so the weight of the light was not well balanced on top and felt really heavy even before riding. Luckily my Giro helmet has a center vent on top, it was perfectly balanced. 502b w/ battery is 170g. Velcro strips keep it solidly in place no jitter. I also use a lanyard just in case.
  1. Regular bike helmet with an added light weight chin guard?
    By KVW in forum Apparel and Protection
    Last Post: 03-05-2014, 07:32 AM
  2. Full face, well ventilated & light weight helmet
    By The Collective in forum Apparel and Protection
    Last Post: 03-25-2013, 03:16 PM
  3. Good light setup? MJ-880 + helmet mounted light?
    By Muffinhead in forum Lights and Night Riding
    Last Post: 11-07-2012, 11:10 AM
  4. Help With Helmet Light
    By eastspur in forum Lights and Night Riding
    Last Post: 10-04-2012, 11:48 AM
  5. Light Helmet
    By pattongb in forum Weight Weenies
    Last Post: 10-23-2011, 12:22 PM
