Results 1 to 2 of 2
    Jun 2013
    Handlebar or helmet mount?
    I'm racing 12hr of Temecula and this will be my first time mountain biking at night (I commute on the road at night). Should I mount the headlight on my bars or helmet (350 lumen Cygolite Pace 350)?
    Is 350 lumen enough?
    Light freak
    Reputation: scar's Avatar
    Jun 2005
    350 lumens is on the low side. I would recommend more like 800-1000.
    Characteristics of where you place the light
    Light on the bars – With the light being below your eyes, it produces “shadowing” of obstacles. The downside of the light being on the bars is the light is always pointed in the direction that you bars are pointed. Can be a problem on tight, twisty switch backs where you want to look around the corner. The other thing is having to make a repair in the dark with your light bar mounted. Almost have to remove it to get the light pointed where you need it
    Light on your head – With the light above your eyes, it tends to “flatten” out obstacles as it doesn’t produce as much “shadowing”. The upside is that your light is always pointed directly where you are looking. Making repairs in the dark in much easier with the light on your head. The downside to a helmet mounted light only is that when you are looking to the sides or around a switchback, you don’t have lighting on the ground (which could be actually visible in your peripheral vision). In snow, fog, and rain, a helmet only light can be difficult. The light reflecting back at you off of the moisture in the air can make visibility very difficult.
    Light on both the helmet and the bars – Best of both worlds. Always have light directly out in front of you and where you are looking. If it gets snowing, raining, real dusty,or foggy and it is making visibility difficult because of the helmet light, then you just go bar only. All 24hr races require repetitive light systems for safety. I have heard stories of many people that have had their only light die on them and have had to walk out, not fun.
  1. Tripod mount Contour Roam 2 onto Magicshine helmet mount?
    By khaytsus in forum Videos and POV Cameras
    Last Post: 07-31-2013, 06:35 PM
  2. Custom helmet mount for magicshine mj-880 using go pro mount
    By awareham83 in forum Lights DIY - Do It Yourself
    Last Post: 12-27-2012, 05:13 PM
  3. Handlebar or helmet?
    By SoloRider in forum Apparel and Protection
    Last Post: 11-04-2012, 01:39 PM
  4. Handlebar or Helmet?
    By rmalling in forum Lights and Night Riding
    Last Post: 04-16-2012, 04:49 PM
  5. One lite handlebar or helmet?
    By luvdabeach2001 in forum Lights and Night Riding
    Last Post: 03-18-2012, 07:35 AM
