The highly anticipated X1 is the second light by Gloworm, designed 100% in NZ. As the name suggests it is a single LED, XM-L U2 to be exact, driven by a switching regulator that is combined on the same PCB as the LED itself.
The X1 gives out an astonishing 850 lumens from a unit weighing in at 58g (remote included) and 35mm in diameter. It boasts the same characteristics as the X2 in being waterproof, robust and CNC machined from 6061 Alloy - No plastic parts here!
The optics are a custom solution designed to provide maximum throw while maintaining a beam pattern that is easy on the eye - no discolouration, round beam and no artifacts. The kit will include 3 interchangable optics: Flood, Spot, Super Spot. (Beam shots to come in the next day or so).
This tiny unit will utilise the same low profile style mounting solution as the X2 for the helmet, however will not have a bar mount included in the set. Instead our new QR bar mount will be available as an extra accessory. The QR mount will also be compatible with the X2.
The X1 will be supplied with a 2 cell battery (appx 115g), once again containing high capacity Panasonic cells. Its capacity will be 2900 mAh giving a runtime of 2hr 15min on maximum. The 2 cell battery will be compatible with the X2.
Controlling the X1 will be managed through a remote switch. It will also present the same selectable programmes as its big brother.
The Gloworm X1 will retail for $179 USD with a 2 cell battery and can also be ordered with a four cell battery (runtime 4.5hrs).
Spec Summary
850 Lumen (real, not theoretical)
IMT technology (selectable programming)
Light Head Assembly 58 grams
Waterproof to IP66
2.9 AH Lithium Ion Hard Case Battery
1 x Cree U2 XML LEDs
Interchangable Optics (Spot lens and frosted lens)
2.25 hr runtime on max power
Remote switch
IMT Programmes
On pressing the button from 'off' the light will start in Normal Operating Mode. Special modes are accessed by holding down the button for 2 sec from any normal mode. This allows the user to conduct any outdoor activity without having to cycle through the special mode and having an interuption of a steady light beam. Additionally, the X2 is shut down by holding the button for appx 5sec. IMT gives you the flexibility of refined programmes and modes without needing to access them every time you go from High mode back to low. Programmes are changed through a sequence of button presses.
Presales will start pretty soon for a limted number of units - more information will be posted here.
Cheers
Bruce and Vag
Team Gloworm
Spec Summary
Waterproof to IP66
Remote switch
IMT Programmes
Cheers
Bruce and Vag
Team Gloworm
