Page 2 of 2 FirstFirst 12
Results 101 to 181 of 181
  1. #101
    Action LED Lights
    Reputation: Action LED Lights's Avatar
    Quote Originally Posted by butasan View Post
    I too tried my Olympia last night as a helmet light. Although I was pleased with the amount of light, I too felt that I could use a little more throw, but I understand that Olympia was designed as a bar light so I should probably not complain about the throw.
    I am now considering getting Xera as my helmet light, but I am not sure about the throw. I've read somewhere that a lighthead needs to have a large&deep reflector to attain a long throw so Xera's small body leave me a concern.
    The stock Xera optics have a fairly narrow spot that smoothly transitions to the spill. If you want a tighter spot the Xera reflector turns it into a very tight beam with minimal spill so you really get a lot of throw. It is plenty large enough to control the beam. It's when you start getting below 3/4" that control starts getting harder. It's also more of a problem with old incandescent lights because the light comes from a larger area. The XML is such a small spot source that it's easier to control.
    Jim Harger
    Action LED Lights
    www.action-led-lights.com
  2. #102
    So you are saying that Xera has more throw compared to Olympia? If it does, I will definitely get it.
    Quote Originally Posted by Action LED Lights View Post
  3. #103
    Action LED Lights
    I'll let others with more experience give there opinion but I would say the 2 complement each other quite well.
    Jim Harger
    Action LED Lights
  4. #104
    Reputation: d365's Avatar
    there is a thread down the page titled "thrower wanted" that might help answer your question.
  5. #105
    wot no bike?
    Reputation: pahearn's Avatar
    Feb 2006
    Quote Originally Posted by Vancbiker View Post
    I am pretty sure that is what the Olympia already uses.
    That would be a good thing, since it looks like they come in three angles, 9.5, 12.5 and 20 degrees. Gemini's site claims a beam angle of 19 degrees, so maybe it's using the 20 degree lense.
    Could someone from Gemini comment on this?
    pete
  6. #106
    I am Walt
    Reputation: waltaz's Avatar
    Olympia (on the bars) feedback vs/in conjunction with the Xera
    I got the Xera a couple weeks ago, to use as my helmet light, and have run it for one 24-hour race. Love it...I posted up about that in the Xera thread.
    I ordered the Olympia for my bars, but it was not ready for that race, so I cobbled together another bar light in the interim.
    I got the Olympia last week (thanks Jim/Action LED!), and ran the Xera helmet/Olympia bars combo for the first time this morning. I loved the combo...here are some initial observations (I am not overly technical about all the lighting stuff and specs, just an experienced night rider, etc):
    - I have the stock reflectors of each light
    - Xera is definitely more of a tighter spot; Olympia more of a "spread." I could see the Xera's spot-beam in the spread of the Olympia beam. And that Xera beam goes out a ways...that light is bad-ass.
    - Xera is definitely better on the helmet, and Olympia is definitely better on the bars. The Xera's spot, and the Olympia's spread complemented each other perfectly.
    - I ran both lights on Medium...that was all I needed with the two of them together, plus it conserves battery power. I was hammering fast, on moderately tech terrain, and it was awesome...I can't imagine running both on High.
    - The Olympia stayed nice and snug and in-place on the bars with the larger O-ring (I run 29'er bars that are thicker in the middle). Love the pivot feature so I can aim it properly. I previously ran a Magicshine on the bars, and it bounced all over the place, always ended up pointed down, and could never be aimed properly.
    - The Xera + 2.4Ah battery is light as hell on the helmet...does't cause any helmet bounce/shifting at all. Love how clean and light it is.
    I am totally pleased with my choice of these lights, and love the setup and the light combo/spread.
    BTW, Jim at Action LED rocks!!
    Walt in AZ
    Ride more; post less...
  7. #107
    just a Newbie
    Reputation: colleen c's Avatar
    Perhaps I can provide a little detail here. I have a Olympia and a Xera with an optic and just received a xera with a reflector. The Xera with the reflector do provide a tight spot in comparison to the optic.
    When using the xera along with the Olympia, the xera optic does not do much in helping with the throw. It just lights up everything in front of your path brighter. However xera with a reflector does help with the throw when used with the Olympia.
    Here is the interesting thing. If you have an object 100ft away and had both the xera with reflector and Olympia on high pointing at the object, the object with appear very bright. If you cover either the xera or Olympia with your palm, you will notice that the amount if brightness of that 100ft object will appears to have the same amount of brightness from either light by itself. However in real life, my eyes get to used to the close proximity wash out effect from the Olympia such that I don't see much of an throw although when bench testing at still motion show the same as the xrea with reflector. When I am out riding, the tight spot from the Xera with relector gives it the throw since it is concentrated at the same spot of what the Olympia can throw. Now the throw is twice as bright while the close proximity range remains about the same yeilding in a better definition of distant perpective. The tight spot of the xera with reflector allows for better throw without additional close range wash out effect.
    Edit: I used the Olympia for three days now and I found the Xera reflector and Olympia combo to be a pretty good combo. Olympia with Xera/optic gets too bright at close range making distant object appears darker. Olympia alone does a pretty good job alone but still need a little tad more on the throw, while the Xera/reflector and olympia combo just about fill that gap.
    Last edited by colleen c; 02-29-2012 at 04:02 PM. Reason: Some pretty bad spelling.
  8. #108
    Any thoughts on Olympia with 12.5 optics?
    The price difference between Xera and Olympia lightheads is not too significant so I would rather get a more powerful one.
  9. #109
    May 2005
    You will end up with a wider beam than stock with the optic linked. Note in the Cutter page that the beam angle number has +/- in front of it. A 12.5 degree optic really has a 25 degree spread.
  10. #110
    Oops. Glad I asked!
  11. #111
    wot no bike?
    Feb 2006
    Son of a *****. I didn't notice that, and ordered both the 9.5 and the 12.5. I guess that's why the Gemini site says the angle is 19 degress. Looks like i just wasted ~$25.00.
    On the plus side, i briefly read on candle power forums about someone who polished their cute-3 lens to get a tighter beam. Now that i will have two, i guess i will be able to experiment. :/
    pete
  12. #112
    Reputation: Rakuman's Avatar
    You can sand and fire polish. try only polishing the top optic and leave the bottom diffused to get flood
    I always type in bold cuz I'm blind as a bat
    For the Rich there is therapy!!!! for the rest of us we have Mountain Biking
  13. #113
    wot no bike?
    Feb 2006
    I was thinking that would make sense too, i've never done anything like this before though. Do you happen to have any informational links on how to best do this, or can you offer advice? I'm confident in my ability if i have some direction.
    pete
  14. #114
    Quote Originally Posted by pahearn View Post
    I just sand the area smooth were you want to fire polish and hit it with a pencil torch hold the flame away from the plastic and wait till it starts to bubble slightly then pull the flame further away at that point , it takes a little practice to find the sweet spot on how far to hold the flame.
  15. #115
    May 2005
    Sorry I didn't mention the angle specification in my first post about this optic. It is a bit confusing in how optics manufacturers vary in how they report beam distribution.
    Taking the "bobbles" off the Cute SS optic seems to narrow it up, but I don't think it adds throw. I recently did this on the last new design I built on the advice of one of the posters on the DIY lights forum. I wet sanded the optic with 320 grit paper. Do tthe sanding with the paper laying on a flat suface and sweep the optic in a figure 8 pattern. After the bumps are removed, start working through finer grits of paper keeping it well wetted. I finished at 1000 grit. Then I polished with a car polish and then finished it off with plastic polish. I didn't feel like trying the flame polish though it would likely be a bit faster. While all this sounds like a lot of work, it only took about 30 minutes.
  16. #116
    wot no bike?
    Feb 2006
    It's my bad, I wasn't paying attention and was hasty in placing my order. Not the first time I've done that!
    Thanks for the tips. I may try despite the possibility of not getting any more throw, just to experiment.
    pete
  17. #117
    I am Walt
    Wow...you guys (and gals?) are something else...that level of detail and fussiness would kill me...
    I just opened the box, charged the batteries, strapped on the lights, and rode...both the Xera and the Olympia are bomber OOTB, for me...YMMV...
  18. #118
    Reputation: MRMOLE's Avatar
    I've been out the last few nights comparing the olympia with my other lights (BikeRay IV, MS 808 & 808e with and without action wide angle lens) and thought I'd figured their comparative strengths and weaknesses untill Wednesday night. I'd been riding on unlit canal banks (25+ yards wide 1 mile long sections) until Wed. where I was riding on a bike path (unlit) that has a 1/4 mile section with a 5%+ grade. While climbing where I could look up slightly to see the full throw instead of having to look through the glare of the hot spot it definately had more throw than was appearent riding along the flat canal. The previous night I'd taken one of the wide angle lenses out of one of my MS lights to see what it would do if I just held it over the front of the olympia. I wasn't sure what to expect holding one optic over another but it worked excellent. It eliminated the hot spot, slightly widened the beam (mostly around the wheel), and didn't seem to shorten the throw much (this was on the canal bank so it' just how I visually preceived it). Jim (Action) have you had time to experiment with the olympia yet? I'm not trying to make any point here, just sharing my observations. Love the light so far!
  19. #119
    Action LED Lights
    Quote Originally Posted by MRMOLE View Post
    I'm looking into a wide angle lens for the Olympia and Xera. For those enterprising DIY types, I have taken the current wide angle lens and cut it down to fit under the glass lens on a Xera equipped with a reflector. (I used a drum sander attachment in my drill press)
    The result is much like the lens in a Titan or 808, turning the spot into a wide oval. I also tried attaching it to the front of a Xera that had a stock lens and had good results. (You can use a thin strip of double stick tape on the front edge of the bezel to attach it.)
    This will work on the Olympia too but the effect is much less pronounced. It would take a customized solution to do any real beam shaping on it.
    The problem with a permanent solution for either of these is the tooling cost. I have to have enough volume to pay for the mold.
    Jim Harger
    Action LED Lights
  20. #120
    I took my Olympia for a first ride last night. Tons of light output. I'd describe it as a big xera in every way. It's obviously a slightly larger housing. The beam is tight with very little spill just like the xera, but has a slightly larger beam angle. Just as advertised. The throw is about equal, so just imagine a xera that covers slightly more area. I was actually hoping for a little bit of spill for the peripheral vision while mounted on the bars. I really like the bikeray 3 pattern on the bars - for reference. I set my middle custom level on the olympia to 80% and it seems to equal the output of the bikeray 3 on high. I'm pretty happy overall.
  21. #121
    I run Gemini Olympia on bars and MagicShine 880 on helmet. Colors dont match up perfectly with Olympia being a little more white. MJ880 has more throw and I would say more overall lumens.I find this combo sufficient for Cat1 XC speeds.
    I took my MJ880 with me to purchase a "night" helmet and found a Bell (top of the line model?) that the 880 fit to perfectly without the lame plastic mount.
    Purchased from Action LED, I highly reccomend
  22. #122
    May 2005
    The Cute SS appears to me to be the optic used in the Olympia. That series has medium and wide versions.
    Cutter Electronics
  23. #123
    just a Newbie
    Edit
    Please disregard this post.
    I had lots of beamshot of the Olympia and Xera in comparison with other light I had but then noticed the camera setting was wrong on the shutter speed.
  24. #124
    just a Newbie
    Ok here is the correct beamshot I took again since my last post had the wrong setting.
    All setting are MTBR standard but since my camera in manual cannot do ISO 100 but ISO 200 instead, I compensate that using a shutter speed of 2sec instead of 4sec.
    There is one 2 litter bottle and two 1 litter bottle at 100ft. The second tree in the background is 150ft while the farthest tree is 200ft.
    More beamshot including MS, Bikeray, Gloworm and the control shot can be seen here:
    Gemini Olympia and Xera beamshot comparison pictures by Colleenlc - Photobucket
    Olympia
    Olympia with Xera using Optic
    Olympia with Xera using Reflector
    Interesting is that the Olympia alone can throw as good as the MS 808E xml
  25. #125
    [COLOR="Red"][I][ I really like the bikeray 3 pattern on the bars - for reference. I set my middle custom level on the olympia to 80% and it seems to equal the output of the bikeray 3 on high. I'm pretty happy overall.[/QUOTE]
    I'm curious how you had your light aimed? When I saw your post It didn't seem to match what I had observed. I reset my olympia presets to 50-80-100 and took my BikeRay IV along to see what I'd get. If I had the Olympia aimed up high enough I cold aproximate the brightness of the BR IV but the Olympia covered a much bigger area. If I aimed the Olympia to approximate the same lit area it was pretty close to the 50% setting (60% would be generous).
    I also found I prefer the Olympia set @ 80% better than 100%. It softens the hot spot a little.
    Last but not least, It was 70 degrees-F and I got a chance to ride both lights on high for about 4 miles and they were only warm to the touch when I stopped. No heat problems so far.
  26. #126
    EXCELLENT job!
    It looks to me that Xera's reflector is not really helping with the throw, but the wider spill.
    Quote Originally Posted by colleen c View Post
  27. #127
    night riding enthusiast
    Reputation: GraXXoR's Avatar
    It seems the reflector is less efficient than the optic. It just restricts the output to a narrower beam without increasing the overall brightness significantly. However, it does make the foreground light less blinding.
    Click the thumbs up button if you have a thumb...
  28. #128
    A quick thank you for everyones advice. I am using the Gemini on my helmet and Olympia on the bars, I have nothing to compare to but, I can tell you this combination has greatly helped extend my biking season and allowed me to stay in condition. The winter season has been a blast.
  29. #129
    just a Newbie
    Quote Originally Posted by GraXXoR View Post
    EXCELLENT job!
    Yes, I too notice there is not too much difference in throw between the optic and reflector for the Xera. If anything, it is slightly more with the reflector if I point them straight at the tree instead of the bottle. The reflector does provide some side spill but not so much in the immediate foreground for the first 50ft or so.
    Effect wise, when using the xera/reflector along with the Olympia, it helps to cut down on the foreground glare while still helping with some extra throw. OTOH, Xera/reflector is not as useful when used alone. The optic is better. I run two Xera ony drop bar commuting bike. Two Xera/optic had too much spill and I cannot see the throw, but two Xera/reflector makes a nice combo light offering a balance of spill and throw.
    Depending on the setu, the reflector does have some advantage and disadvantage.
  30. #130
    my Magicshine 880 has Way more throw then my Olympia. MS880 for helmet and Olympia for bars is my best combo to date. Comparing the 2 the 880 is a v8 and Olympia is a turbo4
  31. #131
    I think I'm going this route.
    I like the Xera's light weight, but it seems to me just the weaker version of Olympia so I don't think I will get a good throw regardless of the use of the reflector.
    Quote Originally Posted by sevencycle View Post
  32. #132
    Cool. Action LED will ship out the day you order. I have no connection with them other than a purchase.
    I rode last night and took my standard t6 magicshine (spot) to compare.TheMS8?? helmet spot did work ok with the Olympia. But when I went back to the MS880 I didnt realize how much spill it added plus the size of the spot was times 2 and whiter.
    I feel I have a good opinion on lights being, Old with bad eyesight, Kinda fast usually top 3 Cat1, Experienced, Raced the very first 24hr race in Slatey Fork WV... 1992?? and many after that.
  33. #133
    just a Newbie
    I just did a review on the Olympia at another forum. I will post the review here for all to see. There is some notes with looking at like the 6cell runtime and lux reading for the User Intuitive programing. Here is the Review I wrote:
    Gemini manufacture introduced their line of bicycle lights with the introduction of the Titan P7, since that time, they have now introduced the Gemini Xera and Olympia in which both of these fine lights uses the Cree XML. I purchase both of these lights and was impress by the features and performance of these light. A little over a year ago, I did a review of the Titan P7 and I feel that the Gemini Olympia is worthy of an review. The Olympia light uses 3 XML led to provide a manufacture rated 1700 lumens using an optic that is 19-degree beam. The runtime from their 5200 mah pack is 2hrs as listed. They also offer an optional 6 cells 8400 mah pack, which allows for a 3.5 hrs of runtime. The listed weight of the Olympia light is listed at 78g which is consider pretty light enough to be mounted on the helmet. It has a user intuitive programming for the brightness in all of the three mode plus strobe mode. One can be overwhelm with these listed feature and is curious how well the Gemini Olympia will perform the claimed listing. I bought one of the Olympia light package which had all their accessories including the 6 cell battery, and after several weeks of using this light, I found the Olympia was worthy of a review.
    The package with the 6 cells battery arrived a little later than I was hoping for. The DHL tracking showed the package was sitting at Hong Kong for several days and I figure there might have been a problem. Not long after that, I received a notice that Gemini has sent what seem like another package and sent me a notification. I was not home at the time of the delivery and Gemini sends me an email notifying me that the package did not get deliver. It was nice to have some assurance of customer support when there is problem with delivery and Gemini did just that. My package arrived safety and undamaged. The content in the box included the following:
    Light
    Battery
    Charger
    Helmet mount
    Pro Head belt
    O-ring
    Extension cable
    Physical size
    The size of the Olympia is smaller than the Magicshine P7. I took a weight measurement of the light head with my scale and the scale showed 82 gram. The difference in the listed 79g vs. my 82g might be in the scale itself. Here are some pictures of the light head along with it in comparison with the Magicshine 808 P7
    The weight of the 6 cell battery was weighted at 322 gram including the nylon pouch.. The 6 cells battery was shipped charged at 7.61v. I charged it but notice that the charger did not terminated at 8.4 volt. The charger had 8.7 volt written on it and I figure that was intentional. After emailing Gemini, they assure me that was Ok for the 6 cells battery. I charged the battery and the termination voltage read 8.76 volt. As soon as I unplug the charger from the battery and check the SOC of the battery, the battery volt read 8.42 volt. After charging, I plugged in the light to the battery and notice how bright this light was putting out. I have a lux meter and did a 5ft ceiling bounce test in my 10x8 room to see how many lux this little light head was putting out. I got a reading of 162.5 lux. Not bad for a little light.
    Programming
    One of the neat features of the Olympia light is the User Intuitive programming . It allows for adjustment for the brightness of the light in any mode. It has three modes and a strobe mode. You can access any of the three modes without having to go through the strobe mode. In each mode, you can program the level of brightness in any increment of 10 steps. This feature allow the user to be able to program each mode to anyway they want such that the unit can be program for sequence instead of being stuck in the OEM setting of H-M-L or L-M-H. This feature goes for the same in the strobe mode. What nice about that is that now you dont have to put up with a strobe that is strobe at 100% brightness. The programming of the setting is very easy and can be set out in the field. I took a lux reading of each of the 10 increments step for the programming and here what I measured.
    1- 6. lux
    2- 11 lux
    3- 24 lux
    4- 40 lux
    5- 57 lux
    6- 74 lux
    7- 92 lux
    8- 111 lux
    9- 130 lux
    10- 162 lux
    Battery Runtime
    The performance from the 6 cells battery is promise as claim and more. I started with the battery fully charged with a SOC of 8.4v and the battery indicator showing green. Here is what I got:
    After 2 hours of total runtime: the indicator turned yellow and the battery read 7.09v.
    After 3hrs 10 min of total runtime: the indicator was red and battery read 7.01v.
    After 4hrs 5min of total runtime: the indicator was blinking red and battery read 6.64v.
    Afterward the unit went into low mode and I stop the runtime test. I was please to find that the Olympia runtime was better than what the runtime was suppose to be. I took a Lux reading with a ceiling bounce test at the last hours of runtime and the Lux meter read 150 lux. This tells me the regulation was pretty close to flat line.
    Beam shot
    The Olympia is very bright for use in the trail or road. The beam pattern has more flood than throw, however the throw is not really bad at all. It can provide enough throw to be used as a stand alone light, but adding an additional throw light such as the MS 808E xml or a thrower flashlight will spice thing up quite a bit. Gemini offers the Xera light with a throw reflector optic, which I am using currently and gosh does the combination with the Olympia, really lights everything up in front of me. Recently they are testing a different reflector for their Xera line for even a more throw pattern. Here is a picture of the Olympia beam. There is two 1 litter bottle and one 2 litter bottle on the grass at 100ft. The tree behind that is 150ft and the last tree is 200ft. The picture was taken at F4.0, 2sec, ISO200, daylight, and manual focus.
    I have much more pictures with comparison of the Olympia beam shot along with many other lights I have in my collection like the MS P7, MS XML, Bikeray IV, Gloworm etc. This album also contain the control shot and daytime shot showing the setting. They can be found here:
    Other mounts
    In my helmet setup, I had mounted the Olympia along with the Xera on my helmet. I decide to use a different mount than what came with the Olympia. The Oring mount is OK for most but I prefer the mount offered by Cateye although the tilt adjustment is not as fine as using an Oring mount. On the other hand, the Cateye does offer easier removal and somewhat a lower profile. There some mod that has to be done to fit besides just removing the screw. The screw of the Olympia is a large head and the Cateye spacer had to be drill for clearance so that the screw sit flush and slide over the helmet mount with ease after filing the side of the mount. It is easy process and takes a few minute to adapt. The Cateye helmet mount is #534-1831 while the space is #533-8730 model H-27. Here are some picture of the Olympia at the top of my helmet and a Xera in front using Cateye mount.
    conclusion
    Im please with this light so far. The price is higher than some lights but yet lower than some others. I think it is a good upgrade for those who are consider a single brighter light for their lighting system. The small size and User Intuitive programming features will helps with those who seeks a light that is user selectable which is one of the best feature I found with this light.
  34. #134
    Reputation: pethelman's Avatar
    Nice review... try one more thing if you get a chance.
    Take the light indoors and turn it on the highest power output in steady burn mode and just let it run and see what happens...
    If you have access to a "laser" thermometer, take some readings at various places around the case and note when/if thermal cutback occurs. If the temperature of the case gets above 140F before any thermal cutback occurs, probably best to abort and shut it off.
    Inquiring minds want to know...
  35. #135
    just a Newbie
    Quote Originally Posted by pethelman View Post
    Done! (I work in an industry shop and just happen to have a thermo gun)
    I took some reading. The hot spot is dead center top near the bezel. It was only about 2 degree difference elsewhere on the body. I am not sure what the Emissivity should be set at on the thermo gun. I know it is different on Aluminium and not really sure what it is on silver anodized AL. I just left it at the turn on default of 0.93
    The unit did not cut back at 140 F.
    Ambient = 63
    1 min = 83
    2 min = 96
    3 min = 113
    4 min = 123
    5 min = 136
    5 1/2 min = 140
    6 min = 143
    Last edited by colleen c; 03-12-2012 at 10:35 AM. Reason: Corrected ambient and added 1 min reading.
  36. #136
    Nice!
    The conclusion from this is that you should probably avoid running the light at full power under conditions of little to no convective cooling, not only to prevent burning yourself but also damaging the LEDs.
    EDIT (3/15): Pure conjecture on my part with limited data... Gemini states below in a later post that they have tested repeatedly that cutback occurs at a 63-ish degC case temperature (hopefully under these same circumstances), which is roughly 145 degF. So hopefully just a few seconds more, and colleen would have seen a reduction in power. Please take any analysis below as a "what if" scenario, and realize that turning on ANY high power LED light, STARTING from ambient temeratures with no air-flow is an absolute worst case scenario, and should normally not occur.
    So lets assume a 14 watt power draw just in the LEDs. We want to estimate the LED junction temperature based on the measured external case temperature. We know, based on CREE's datasheet that the XML die itself has a thermal resistance of 2.5 degC/watt. So the problem now becomes, "what is the total remaining thermal resistance to the outside world that would be required to keep the junction temp below 150C when the case temperature is at 143F (62C)?" (Obviously the temperature rise was not going to stop at 143, but just for sake of argument). This thermal path includes:
    Die-to-substrate junction (usually low),
    Substrate-to-mount junction (probably low but dependent on quality of thermal compound),
    Mount-to-housing junction (dependent on method of assembly and/or thermal compound),
    Housing-to-ambient (dependent on the design of the case, total exposed surface area, and presence/lack of forced convection).
    Or simply stated (at 6 minutes):
    150C = 14watts * (2.5 degC/W + ? degC/W) + 62C
    Solving for ? = 3.78 degC per Watt
    This would be VERY difficult under static ambient conditions. As a designer with a conservate bent, I would have liked to have seen the thermal protection kick in around minute 3. Just my preference, NOT a necessity.
    It'd also be interesting to see similar test results over a longer time period with simulated air-flow, comparable to climbing speeds.
  37. #137
    Colleen, just out of curiosity is there any way you can do one of those thermal scans on the Gloworm X2....pretty please!
  38. #138
    Nice!
    The conclusion from this is that you should probably avoid running the light at full power under conditions of little to no convective cooling, not only to prevent burning yourself but also damaging the LEDs.....
    ...... At a minimum, there should be some verbiage in the instructions telling the user to be-ware these scenarios. As usual though, completely just my opinion.
    I would think by now that most people would know this about "any" LED lamp. Seeing that there are more and more lamps now using multiple LED's it is real important to power down when stopped or slow climbing for periods longer than ten minutes.
  39. #139
    I'm not so sure I'd go that far and say "most" in general, but definitely most of the folks that frequent the boards here have a keen sense of how to handle the high power lights. Hopefully this conversation will increase awareness to some degree.
  40. #140
    just a Newbie
    No problem, I was a little curious myself to see how the Gloworm X2 compare. The number was almost identical in term of temperature and time. The mode was at 1200 lumens. Here they are:
    Ambient temp = 67.7 F
    1 min = 86 F
    2 min = 100 F
    3 min = 114 F
    4 min =125 F
    5 min = 135 F
    5 min 44 sec = 140 F
    6 min = 142 F
    6 min 30 sec = 147 F
    No cutback even at 147 F
    This was the 1200 lumen mode. I can only imagine it will rise faster in the 1300 lumen mode. The temperature rises for the X2 at 1200 lumens mode using two LED is almost the same as the Olympia at the 1700 lumens mode using three LED. Interesting huh?
  41. #141
    ww.glowormlites.co.nz
    Reputation: Gloworm Manufacture's Avatar
    1 min = 86 F
    2 min = 100 F
    3 min = 114 F
    4 min =125 F
    5 min = 135 F
    6 min = 142 F
    Hi Guys,
    Just to shed a little light on the situation (couldn't resist) - the thermal cutback at the board is set at 70deg C (158F). We will be reducing this to 60deg (140F) for V2.
    I can only suggest that the Watts produced by the X2 are the same or similar to that of the Olympia hence the temp increase similarities. The thermal/surface area characteristics of the cases also seem to be similar. We're looking at 14W max for the X2 at 1200 lumens.
    Hope this stimulates or helps the conversation.
    Cheers
    Bruce
    Gloworm
    NZ
    Gloworm Website
    '...it's more fun with the lites on!'
  42. #142
    Ambient = 63
    1 min = 83
    2 min = 96
    3 min = 113
    4 min = 123
    5 min = 136
    5 1/2 min = 140
    6 min = 143
    OK, I just couldn't resist... per Jim's comment in post #51, bold emphasis mine:
    I understand your concern about heat and electronics, but from what I have seen with the Xera and heard about what went into the design of the Olympia, Gemini has put some effort into making sure this is not a problem. According to CREE the Junction temperature at the LED is safe up to 150˚C (302˚F) though the life span would be shortened at that temperature. The 50,000 hour life rating is at a temperature of 85˚C.
    The Xera and Olympia are designed to provide a wide path for the heat to get quickly away from the LED and into the housing where just a slight amount of air flow can carry it away. If I remember right they have the temperature sensor set to reduce power at 78˚C. It may have no more surface than the 872 but MS does not give heat flow as much attention. Their LED holder is thin, the contact area between it and the housing is small and they are stingy with the thermal paste. Sometimes there's only a couple of little dots between the two.
    The amount of thermal mass in the LED holder and driver circuit board where the temperature sensing occurs is small so it can react fairly quickly if things start to get too hot. It then cuts the power down to low (20% I think) until things cool off. They have put this thing threw the ringer running it on the bench to assure everything works as intended.
    It should be pointed out that the model equation that I proposed earlier is a very simple "steady-state" equation and does not take into account the thermal mass and temperature gradients that exist in the system as the unit is heating up. By virtue of the fact that the shape of the temperature ramp was still fairly linear when colleen pulled the plug, it tells us that the system still had a good ways to go before hitting "steady-state." In other words, it's "possible" that the LED temperature was already actually "higher" than the 150C limit that the model equation predicts at 6 min, but again this is just a rough prediction during a worst case scenario.
    The trip point temperature that Jim pointed out (78C) refers to the location of the temperature monitoring sensor, NOT the LEDs themselves. This temperature monitoring point, as he states, is ON the controller board itself. So the issue here is very likely that the thermal coupling (resistance) between the LEDs themselves and the controller circuit is not sufficiently low to enable adequately fast (for my liking) thermal cutback during the transient "heating up" phase of operation as demonstrated here. There are three ways to address this problem:
    1. Dramatically lower the thermal resistance between the LEDs and the temperature sensor.
    2. Significantly lower the temperature trip point (down from 78C).
    3. Make it very clear to the user that this scenario really should be avoided.
    #1 can be expensive to implement with a remote temperature sensor. #2 is feasible, but due to the overall low surface area of the case, it's likely that they had to choose this "high" value to sustain operation at steady state in the presence of moderate to low air-flow without the like cutting back pre-maturely. Since addressing #1 or #2 requires extra cost and/or design change, #3 is the only option, and to Gemini's credit, they have put some warning in the literature. Could it be a little more strongly worded? Perhaps, but that's just a matter of opinion. I'm totally OK with a design that is, by nature, capable of operating outside of safe limits, both to the electronics and to the user, as long as adequate warning is given.
    Begin Edit (3/15)
    My sincere hope for this design and overall preference would be that it could truly protect itself, even from any incremental thermal damage under any circumstance. And it may indeed do that. I can't say definitively one way or the other. Clearly there has been enough testing from the manufacturer to determine that the light will not self-destruct or become an immenent burning hazzard, even under a worst case scenario.
    As has been pointed out below, and again, purerly just my opinion, but I do like to take a conservative approach to heat management and stay as far away from the limits as possible without hampering the functionality of the light. Can a more aggressive approach work? Absolutely, and as the manufacturer has pointed out, they have at least included some necessary warning to the user.
    Upon further reflection, it was completely unfair for me to make any claims of fact on the safety features of these lights without firsthand empirical data. So I'll leave the technical interpretation of colleen's test as an interesting aside, but no hard conclusions can be drawn from it. END EDIT
  43. #143
    Quote Originally Posted by Gloworm Manufacture View Post
    Realizing that this should really be it's own thread... total cross-pollination here.
    60C is definitely more appropriate, but you still better have a darn good thermal path to the temperature sensor at 14W. Considerations for heat-sinking the controller board involve MUCH more than just using a good layer of thermal grease. JFWIW
  44. #144
    May 2005
    +1
    I suspect that most of the drivers are using either a thermister on the board as an input to the MCU or an embedded thermister in the MCU. PCB material will present a poor thermal path between the the housing and thermister. Yes, eventually it will lower the drive current, but only after the emitters have overshot the temperature setting. A low thermal mass housing exacerbates this scenario.
  45. #145
    Gemini Lights
    Reputation: Gemini Lights's Avatar
    Pethelman,
    The thermal resistance between the LED and temperature is very low. We have the LED Aluminum MCPCB mounted onto the same piece of aluminum as the Driver PCB. The PCB is multi-layered with heatsinking and has many thermal vias transferring this heat to the outside retainer. The thermal vias have lots of soldering contact with the aluminum retainer. That's as close as you can get without building a light engine on one PCB.
    As for thermal protection, it is indeed built in. The threshold is set a little higher than 140F. As Cat has mentioned, it's quite common knowledge that LEDs get hot, especially with such high output these days. Yet, the trend is to fit more power into lighter and smaller products.
    We have safety warnings in our user manual. They are located on the very first page under "Safety Precautions". We do inform our users about the extreme brightness (potential eye damage when in direct vision) and heat.
    Here it is:
    Safety Precautions:
    1. When turned on, do not look directly into the light. The OLYMPIA is extremely bright and can damage the eye.
    2. The OLYMPIA is intended for outdoor use. The LED emitter can generate a lot of heat is used without airflow to the aluminum casing. Please be careful.
    3. Use only the supplied Gemini charger to charge the battery pack. Do not use any other chargers, as it may cause damage to the battery.
    With that said, we do expect some people to go without reading through the manual which is why we implement our overheat protection. The protection feature kicks way before any chance of damaging the LEDs.
  46. #146
    Gemini Lights
    Why not go ahead and tell the whole story... i.e. The built in thermal protection will NOT protect the light if it's initially turned on at the highest power levels and denied air flow. It will become hot enough to burn you and the LEDs will suffer permanent damage. If I were Gemini, I'd be posting it in big RED letters. But then again, that's just my opinion.
    You are entitled to your opinion, however what you have just said is entirely not true.
  47. #147
    Quote Originally Posted by Gemini Lights View Post
    EDIT (3/15) You know, I don't mind admitting when I'm wrong, and I must say, I have to agree with you here. It was completely unfair of me to make such an emphatic static as if it were fact, based on so many assumptions, so please do accept my apologies for making that insinuation. End EDIT
    We have Jim's (Action LED) comment originally stating a "threshold" of 78C (or thereabouts). This is equivalent to 172.4F. So when you say that the "threshold is set a little higher than 140F", what exactly does this mean? Did the design change at some point from Jim's original comment, or was he just wrong to begin with? It's just confusing.
    (Nitpicking here for sure) To the extent that we now have empirical data showing the case temperature going above 140F with no cutback, and this is the generally accepted temperature at which skin begins to burn, I don't believe it's a "completely" false statement to say that the light will become hot enough to burn the skin. Granted, I doubt anyone would actually touch the light long enough at this temperature to get burned, but still, there's at least some rationale. I'm sure if colleen were to continue to let the light run, we'd eventually see the thermal protection kick in, and hopefully, under these conditions, it would not get so hot that it would "instantly" burn when touched. Would colleen be willing to run the test again to the point where we see thermal cutback occur? Hmmm.
    It's not my intent to spread misinformation, so I agree with you, I cannot state with certainty that damage WILL occur to the LED under the test conditions that colleen performed. We have limited test data, so all we have to fill in the gaps is best engineering judgement. I've made a couple of "critical" assumptions in the process that could certainly stand to be corrected if need be.
    Assumption 1: Max power draw on high = 14 watts
    Assumption 2: LED case-to-outside world thermal resistance = 3.78 degC per Watt
    I made assumption no. 2 by giving the light the benefit of the doubt at 14 watts, and assuming that the steady state output had been reached at the recommended LED die limit of 150C or 302F. My experience says that this number for thermal resistance for this link in the chain is at least VERY conservative.
    It's reasonable to assume (based on the good design technique that you highlighted) that the thermal resistance to the on-board temperature sensor is indeed lower than the composite value to the outside world. This means that the temp sensor should be higher than the value measured at the outside of the case during the 6 minute test.
    Lets assume a LED-case-to-temp-sensor thermal resistance of 2.5 degC per watt (for a total of 5 degC per watt, when including the LED die itself). In this case, using either assumption (140F or 172F) for the temperature threshold for cutback, we should have seen the light cut back during the test. If the thermal resistance was lower than this, then we should have seen the light cut back even sooner.
    Can you explain why the light didn't cut back during colleen's 6 minute test? And perhaps more importantly where I've made any gross mistakes in my assumptions? The chart attached here is reflective of those assumptions. Again, I have to re-iterate that these are estimates based on assumptions, so my apologies for making it sound like confirmed facts. Would love to see some actual test data confirming your statement that the "protection feature kicks *way* before any chance of damaging the LEDs" under the conditions of starting from ambient and turning the light on full power with no air-flow.
    Attached Thumbnails Attached Thumbnails Gemini Lights OLYMPIA LED (2012)-gem_thermal_estimate_plot.jpg
  48. #148
    Gemini Lights
    Pethelmen,
    The cutoff point normally occurs at 63C 1C (temperature of the outside case). We have tested and retested our lights to ensure the safe handling for our customers. Whilst we appreciate your concern for safety, you can be rest assured that it is perfectly safe to use our light. We don't appreciate your spreading of false claims, saying that the light will in fact burn people and permanently damage the LEDs. We would not release a product if this was the case.
    As for Action LED Lights statement of 78C, I feel that it was perhaps a miscommunication and the 78C was referring to the cutoff point of the temperature sensor on board.
    Now put this all aside, there is never the case where the use of a high powered LED light (i.e. Olympia) must strictly be used on the highest mode, indoors and without ventilation. We say this because low mode is all that is ever required to see things indoors and without moving. We will leave the other reasoning up to you because we don't feel it is necessary to state such obvious facts. Normal common sense tells you that if you feel the light heating up, reduce the power. If by chance, you can't do this for whatever reason, the overheat protection kicks in.
  49. #149
    Much ado about nothing?
    Guys, I'm feeling conflicted about this discussion. On the one hand, I'm running 2 Xeras and and Olympia and I love the way they light up the road for me, especially at the price point. On the other hand, I have a Designshine DS500 on order and I know it will be a kick-a** rear light. You both have slightly different philosophies - Gemini may be a little on the edge of pushing the specs, Designshine a bit more conservative. I believe there is room for both points of view in the marketplace. I understand that my Gemini lights may overheat if I am not attentive. I hope other users also understand this. What it comes down to is buyers doing adequate research and making informed decisions that fit their riding style. While your back-and-forth is interesting and helps keep us informed of the technical issues accompanying every design decision, at some point, methinks you protest too much. While I fully expect to enjoy my Gemini lights for the next couple of years, I realize that the technology is moving so fast that I will probably lust after some new hottie before my Geminis give up the ghost. The DS500 should serve forever, because I don't think more than 500 lumens will ever be needed off the back. So let's not argue the fine points too aggressively- you both are great companies with a proven record of listening to the customer and providing superior customer service.
  50. #150
    Gemini Lights
    Thank you jgmarcotte. I very much agree.
    We do try to push the performance to the very edge to give you the maximum you can get out of your equipment. We have never put down other products, in fact we feel the DesignShine makes a great set of tail lights. We strongly promote healthy competition, where it only drives product development further than it is today. In the end, with more competition around, only the consumers win.
  51. #151
    Thanks Gemini for your clarifications here, and again let me re-iterate that I appologize for all commentary that was/is disparaging of the lights. I clearly let my "soapbox" cloud my better judgement, and I have, to whatever degree possible gone back through previous posts, to make corrections reflecting as much, so as not to mislead any readers.
    I do, in fact, take a very conservative approach to light building and suscribe to the philosophy that the rider should never have to worry about heat while they're riding. This means that regardless of the power level, or temperature of the day, or speed that they're riding, they should just be able to set the light and "forget it." And I have no reason to suspect otherwise for these lights.
    The worst case scenario that was presented here (power on high, indoors, no air-flow), I agree is absurd. But as we know, weird things happen, and perhaps of utmost concern is if children get the light in their hands (probably not a bad idea to add this to the list of warnings... keep out of reach of children). Believe it or not, one of the first things I tell my customers to do is set the light on a hard surface indoors and turn it on full power and just watch it for about 5 to 6 minutes till the thermal protection kicks in. At this point the surface of the case is around 125F to 130F, and I suggest that they touch and handle the light at this point to get a "feel" of what the maximum case temperature should be. Then if at some point in the future the light is ever found to be much hotter, it'll be obvious that there's a problem, and it needs to be shut off.
    More consumer awareness can only be a good thing. More consideration on my part to not make "accusations"... even better.
  52. #152
    just a Newbie
    Ok, I'm hoping this temp thing is behind us now. The only reason why I did the test is because there was a dark cloud hanging over us in the begining of this thread on page one concerning with the temp and package size. I'm hoping the finding is informitive for owners of the Olympia or future customers. Based on the data, for me, it is comforting to know that I can leave the light on for X amount of minute with no airflow. I'm thinking about 5 minutes or less if the light was cold or less if the ambient temp of the light is warmer. On top of that, the info Gemini provided here about their safety hi temp system is good info to know the work they put into their design for this light.
    On to other things. It's been raining 4 days in a row here and I was able to run the Olympia and Xera using the prototype optic on high that are mounted on my helmet. I can attest the combo worked well in finding deep pot holes that are almost filled with water. I have this stretch of road where 18 wheelers travel to get to the freeway and potholes are never in the same place as the city patches them and new one are created just as fast. The pothole get fill with water and becomes hard to find but the combo was able to pick them out
  53. #153
    De nada
    Speaking of pushing the performance edge, I'm very much looking forward to the new Xera spot optic. I trust you will post to the Xera thread when they are available for purchase. Any chance to create a narrower optic for Olympia?
  54. #154
    I am Walt
    Potential issue with my Olympia...
    Quick question to see if I might have an issue with my Olympia: I've run it 4 or 5 times thus far, in conjunction with a Xera on my helmet. It's been great; ran Medium the first few times, then High for a ride. My second-to-last ride, I turned it on to High, and started riding...it immediately started going back and forth from bright to dim to bright to dim, etc. I don't recall if it was in response to bumps in the trail, or a consistent cycling through the brightness settings. In any event, on my last ride, I fired it up, cycled from Low to Medium to High...and it was weirdly dim. I turned it off and started again...still dim...way dimmer than it had been, and way, way dimmer (on High) than my Xera (also on High).
    I didn't bump it at all, and it was fully charged each time.
    Any thoughts?
  55. #155
    Action LED Lights
    Walt, Contact me and we'll get the problem resolved.
    Jim Harger
    Action LED Lights
  56. #156
    I am Walt
    Will do, Jim...thanks!
  57. #157
    Can someone with the 6 cell battery post a pic of the battery without the case and take some measurements of the battery pack itself? I want to see where I can build a mount for it and if one will fit in the open pouch in my pack.
  58. #158
    wot no bike?
    Feb 2006
    Quote Originally Posted by waltaz View Post
    Any thoughts?
    What was the frequency at which it was changing modes?
    pete
  59. #159
    Action LED Lights
    72.5mm x 55.0mm x 37.1mm
    Jim Harger
    Action LED Lights
  60. #160
    I am Walt
    Every 5-10 seconds or so...
    The ride after that, it didn't do any changing, but all three modes were much "dimmer" than they should have been.
    I took it out again this morning to see if I was losing my mind, and it was the same as above...much "dimmer" than it should be...
    Jim from ActionLED is all over this for me!
  61. #161
    just a Newbie
    Any thoughts?
    Question: Are both the Olympia and Xera on your helmet were power from one battery split with a Y-Cable? If so, was the battery a 4cell battery?
  62. #162
    I am Walt
    Nope...Xera is powered by the 2-cell battery mounted on my helmet; Olympia by the 6-cell mounted on my stem. Both fully charged...
  63. #163
    Reputation: gticlay's Avatar
    I tried to run 2x xeras from a single 4 cell and it went into "low battery mode" after about 45 minutes. Bummer even though there was lots o' charge left.
    "It looks flexy"
  64. #164
    Quote Originally Posted by gticlay View Post
    Gclay, In your case that shouldn't be a problem. Your Xeras are sensing the two voltage drops ( instead of just one ). Unless the lights automatically go into a lower mode when this happens you should be fine. Just keep in mind your run time will be cut in two when running two lights from one battery.
  65. #165
    just a Newbie
    Oh ok. You got something else then. When I tried to use a Y-cable to both Olympia and Xera from one pack, the voltage sag caused premature shutdown and one or the other will blink most likely caused by the Y cable. It sound like something else. Not to worry, you'll in good hands with Gemini and Action Led.
  66. #166
    just a Newbie
    I took a picture of the Olympia and Xera with Prototype 14 degree Optics combo. The Olympia is aimed at the bottle at 100ft and the Xera Optics is aimed between the two tree at 150 and 200ft.
    Control shot can be seen at this album
  67. #167
    Cat, well duh! Xera seems to have a higher than normal cutoff.
    "It looks flexy"
  68. #168
    Duh indeed!...That is strange though. The Xera is designed to run off of a 2-cell battery. If you are using a 4-cell you wouldn't expect to have a problem running two Xera's from one 4-cell battery. This is another reason I tend not to like the built in electronic sensing of bike lights. Sometimes it can cause problems if you're not using an "out of the box" set up or riding in cold weather.
  69. #169
    Heat tolerance report - so far so good. I just go back from a 10 mile mountain ride with the termps. in the 90's and no overheating problems (the light was run on high the whole time). The lighthead was quite warm but not to the point where you could burn yourself on it (maybe if you left your hand on it on for awhile). I figured these temps. are warmer than most of you will ever see at night. I'll do an update when our night temps. get into the 100's.
    Has anyone else tried the Olympia as a helmet light? I planned on using it as a bar light and one of my 808e's on the helmet but after trying it on the helmt I think I'll just order another Olympia. Love the light ! Thanks Gemini.
  70. #170
    wot no bike?
    Feb 2006
    For helmet use I find the throw a little too short if you're really hammering. If I could trade a little bit of flood for a little more throw I'd be really happy with it.
    pete
  71. #171
    OK now these have been out for a while I'm almost ready to bite bullet whats the consensuses on this light, anyone having overheating issues or short run times I plan on using Geomans 6.0 batteries anyone pair one of these up to one of those and have any issues?
  72. #172
    Quote Originally Posted by Rakuman View Post
    Mr. Mole ( post #169 ) had a good report. This threads been quiet for a while. I take that as a good sign.
  73. #173
    just a Newbie
    I hate to say this, but the Geoman pack does not perform too well with the Olympia. I have the 6.0 and the 4.4 Geoman pack from the recall and tested those on the olympia. I only got 1hr15m for the 4.4 pack on high and 1hr35min for the 6.0 pack. In both cases, the shutdown volt was 6.54v. During the first 1/2hour of runtime, the voltage drop from the 4.4 and 6.0 pack was at 7.1v and 7.23v. The red indicator light was already red at 45 minutes for the 4.4 pack and 1hour for the 6.0 pack.
    Dunno why the Geoman pack sag so much when the Gemini 4cell pack has a much better runtime listing for the Olympia. I don't think it is the cell quality in the geoman pack but the protection circuit might be making it sag more in voltage under that load.
  74. #174
    Thanks Colleen that's good to know I will make sure to bring a extra battery for longer runtimes I bit the bullet last night its hard to turn down 25% off right now
  75. #175
    just a Newbie
    One very important thing worth mentioning. At the 1hr35m mark for the 6 amphr battery, the Olympia went into a lower setting mode. If you allow the battery to recover for a little while, you can still go into the medium mode and use whatever reserve is left in the Geoman pack. I think the battery is not completly discharge, but just not useable at the high setting. This will give you some extra runtime in a lower output. You do have the programming intuitive option to adjust the brightness to get the maxium possible output while not overloading the pack after it has changed to the lower setting.
  76. #176
    Thanks Colleen 80% of most of my local ridetime is climbing UP so for the first hr I usually run in medium and then crank it up to full for a short 20 min downhill. also when I'm in tight singletrack I usually have my lights at lower settings so not to wash everything out, so for me it sounds like the 6.0 should work fine
  77. #177
    The last three nights I've been doing rundown tests with the olympia lighthead and the three batteries I own (2- 6.0 Geoman and a 5.2ah bikeray). The two Geoman batteries mirrored your results, the bikeray did better at 2 hrs 10 min to flashing red (about what Gemini claims for their 4 cell battery). Something else I did on the Geoman test was to hookup a 808e to the same battery that was on the (powereed down, flashing red) olympia and it happily ran another 1 hr 40 min to flashing red. Looks to me like there's still about half the charge left, so if we can find the sweetspot (power setting) we should get considerable extra runtime. If not, It looks like I'll be looking for a more compatible battery. How do you like your Gemini 6 cell? Is it heavy?
  78. #178
    just a Newbie
    The six cell is no problem when mounted on the bike frame. It is another story off the bike. There is no way that pack is going on my helmet. The extra 2cell does make it a challenge to carry in your clothing because of the shape, bulkiness, and weight. Also try to find any pocket to slip it in on days where I dress casual is a real challenge.
    The solution was simple. I bought one of those photographer vest with gazillion pocket and D-rings. Place the battery in one of the pocket and ran the extension to the mid ring and looping into another ring near the top of the vest and to the back of the helmet where the Olympia connector sits. Problem solved. not only can I carry the battery on my clothing and keep the cord out of the way, but now I can wear whatever clothing I want without worrying about the pack.
  79. #179
    I did some additional runtime tests on the Olympia light paired with a Geoman 6.0ah battey. Here's what I got (full charge to flashing red).
    100% - 1hr 30 min
    80% - 2hr
    70% - 2hr 20 min
    60% - 4hr 10 min
    I stopped at 60% because the runtime went up so much I figured the voltage drain had dropped to the point where the light head no longer interpreted the battery was fully discharged. Recharging the battery took alot longer when I got to the 60% level also.
    Next interesting characteristic - When to power level got to the end of the blue cycle it started alternating between blue and red avery few seconds, then yellow to red, then just red till the light dimmed and it flashed red. Is this a power fluxuation and could this be potentially damaging to the light head? I'm interested in hearing any opinions.
    I think for now I'll use my BikeRay battery for this light and look into getting a 6 cell Gemini battery or maybe on OpenLight.
  80. #180
    Action LED Lights
    I found a Geomangear 4.5Ah battery in one of the lights I got from them so I thought I'd do a little testing to see how it behaved under load.
    It tested at full capacity with a 1.5 amp load (black line) which is about what a MJ-808E draws on high.
    At 2 amps (red line) it dropped off to about 4.3Ah. Not bad but other batteries I have tested stay about the same with loads under .5C
    At 2.25A (blue line) things really change. At about 3Ah the battery switches off. Something in the electronic protection say it's working too hard or getting a little hot.
    At 2.5A (green line) it's really pronounced, cutting off at 1.65Ah.
    At 2.7 and above it shuts off after only a few minutes.
    In any case this confirms what people are seeing when running the Olympia on high.
    These batteries are perhaps a bit over protected as 1C is usually considered a safe current draw. (4.5A)
    Jim Harger
    Action LED Lights
  81. #181
    After using my original Olympia lighthead for a couple of months I relized how much I liked it as a helmet light so I ordered a second unit. I've posted several times on how happy I've been that the light did so well in 100+ degree nights but the second unit proved much more temp. sensitive. I sent the second unit back to be looked at and I wanted to relay the response as to what they found.
    "Gemini made an unanounced change to the Olympia with the older one having the wire exit more to the rear, and the new one on the side. The older one had LEDs and driver mounted on a carrier that was inserted into the housing from the front. Heat had to transfer from this carrier to the housing. The newer one is machined from the front and rear with a web between the 2 cavities. The LEDs are mounted directly to this web. Heat is transfered directly to the housing. There is actually a cap threaded onto the rear where the driver circuit is mounted. It is so well done you can't even see the seam. At the same time they adjusted down the threshold temp. for switching to low. The older one I tested went to 213 degees F before switching. I tested yours and another one like it and they switched @ 175 degrees F (IR thermometer on the side of the housing). So your lighthead is normal, the two are just different generations."
    It sounds like Gemini actually made the light more temperature efficient but decided to be more conservative with the threshold temp. I'm OK with this since 100% power is too much for me on the bars and set @ the 80% setting I've never had a problem. I never had any problems unless it was over 100 degrees but this is information that someone is a warmer climate might want to know before choosing a new light so I thought I would post it.
    Mole
Page 2 of 2 FirstFirst 12
  1. 2012 Colorado Endurance Series
    By Timo in forum Endurance XC Racing
    Last Post: 04-29-2012, 06:37 PM
