    Reputation: gticlay's Avatar
    Gemini Duo - you like the pattern or want more spot?
    I have some optics that really tighten up the beam and make it into a medium spot. Definately way less than the stock optics but not silly spotty like a P60 or the classic "magicshine" light. Anyway, PM me and if there's enough people I'll make more (requires modification).
    "It looks flexy"
    Here are some shots I took in my garage to compare beam on Duo
    I took them with stock optics close and further and the custom ones I modified close and further plus my P60 MCE and my 3-up XPG DIY with the Carlco narrow beam.
    The order is:
    Duo Stock far
    Duo Stock near
    Duo Custom near (I put the two near together so you could see how much tighter this beam is)
    Duo Custom far
    3up XPG narrow close
    3up XPG narrow far
    P60 flashlight near (easily the most tight spot)
    Lemme know what you think....
    Attached Thumbnails Attached Thumbnails Gemini Duo - you like the pattern or want more spot?-duostockfurther.jpg
    "It looks flexy"
    BBW
    BBW is offline
    Reputation: BBW's Avatar
    I think outside pictures (showing farther away) would be more helpful to give the best perspective?
    Good job tinkering!
    BBW. MS, RD
    Well, I ended up thinking they were a little too much spot so I'm now running one stock and one spot lens.
    "It looks flexy"
