Page 2 of 8 FirstFirst 123456 ... LastLast
Results 101 to 200 of 737
  1. #101
    May 2005
    Quote Originally Posted by znomit View Post
    Having XML-U2 written on the stars is a good indication that its anything but that
    They could possibly not be a CREE LED even. I'm looking at the pics on my phone so can't see enough detail to verify if they are real or not. A website for a mfg'r of off-road truck light bars I saw while ago showed images of fake CREE emitters. Fortunately they were pretty easy to tell by the lack of rectangular patterns on the die that is characteristic of genuine XMLs. Most buyers of these cheap lights would not think to research that nor is it likely to matter to most. It's still going to be pretty darn bright. Maybe not as bright as it could be, but very useable.
  2. #102
    Quote Originally Posted by 2melow View Post
    I am not sure what I am looking for, apologies.
    You have white die backplate which indicates it is new XML2 and probably T6 bin 3B tint as seller states that has been upgraded.
    The old XMLs have green backplate, and it is original die in this Yinding light...there is your sign XML-U2 coming from. It is original heatsink plate made by Yinding.
    Your light is superior to other Fastech, DX Yindings.
  3. #103
    Just noticed that mine had the green backplate, so mine is the old xml, not xml2.
  4. #104
    Sep 2012
    Quote Originally Posted by Vancbiker View Post
    Cree do not mark bin or tint codes on their emitters. Really all you'll be able to say is the tint is cool, neutral, or warm. Even that is pretty subjective. When I mention one of my MCE lights looking a little green on the low setting most people don't see it until I switch to a higher level where it gets more white. Without at the very least a calibrated integrating sphere and calibrated constant current power supply, you'll never know what bin you have. I very much doubt that the builders of cheap lights are really stepping up for a premium bin LED. Sure, it's not that much more expensive but at the price level lights are at now saving a dollar on LEDs is going to be very attractive to the builder. Add the fact that the consumer has no ability to tell and you have a sure thing.
    It's the driver causing the MCE led to go green at lower levels. Drivers that don't use PWM are more efficient, however leds that are not driven at 100% power actually change colour at lower levels, typically green for CW and orange for NW/WM.
  5. #105
    Kir
    Kir is offline
    May 2013
    Quote Originally Posted by bhocewar View Post
    This is correct. Aliexpress seller replaces the leds himself, you have T6-3B neutral-white leds which are MUCH better than very cold white U2 leds in stock configuration.
  6. #106
    Oct 2012
    I don't recall this question being asked and I know that most of the time it's random, but in general, those that have this Duo clone, how have the batteries been? Are they better than the average Chinese light? Average? Crap? Run times? Amp draw on low/med/high?
    STILL waiting for mine!
    Ordered 4 weeks ago now... Have tried checking the status of the delivery at several times during the process, but until now got nothing... Today I checked again, and finally I get this...
    Name:  Screen Shot 2013-10-16 at 18.32.07.png
    Not very impressed with my first order from Fasttech so far! That and I'm not in France either, I'm in the UK! So I'm guessing even if it did leave Hong Kong today, It'll be next week at least now til it arrives...
    Good to see the beam patterns make it look like it will be worth the wait though. I like quite a floody beam compared to a narrow one, though it does look like the Gemini optics (or possibly the Gloworm X2 ones) should fit, and those are easily available for me at least.
    Any more news on the battery quality/life and current draw etc. in each mode? Should I be budgeting for a new battery pretty quickly, or do the OEM batteries seem of reasonable quality?
  8. #108
    I like turtles
    Reputation: TiGeo's Avatar
    Will these lights work with my existing Geomangear Magicshine battery pack? It has the round connectors. This looks pretty cool!
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
  9. #109
    Sep 2012
    Quote Originally Posted by mrbubbles View Post
    That doesn't mean it's an old xml, the led die may have been swapped for a new die using the same old star, and I've seen XML2 leds on different coloured stars.
    There is a very easy way to check wether you have the new or old XML emitter. The old XML emitters have rectangular patterns on it (actually strips), the new xm-l2 emitter has no rectangular patterns.
    See this site for clarification:
    Brightness Bins - Flashlight Wiki
  10. #110
    Sep 2012
    XM_L2's don't have the rectangular patterns on them, only the first gen XML's do
  11. #111
    Quote Originally Posted by TiGeo View Post
    OHHH! So now we's gonna think'in of giving up on the ol' P-7's now are we.......'bout time.
    Ti, all these duel XM-L lamps will usually work with the typical MS type connectors. One of these on the bars should be much better than the older single P-7 lamps, at least as far as beam width goes closer in to the bike. They will draw more power though if you run them on high for longer periods. Using the medium setting though will typically get you much better run times and not run so hot. Even on medium, these things light up the night really well.
  12. #112
    I like turtles
    For the cost I just figured why not. My P7s continue to work fine.
    Sent from my SCH-I545 using Tapatalk
  13. #113
    It works with my original Magicshine battery.
    And it also works perfectly with my MJ-6030 5600mAh that I had bought as an upgrade for my tri-clone light.
    It works with the original tri-clone battery, but it's not a secure fit (but it does work).
    I do have one battery that it doesn't fit. It was a DX single XML-T6 (an MS clone).
  14. #114
    I purchased from here Free shipping 1Set CREE XML2 T6 3B Bike Light 1600lm Waterproof Bicycle Light LED HeadLamp + 8.4v Battery Pack + Charger-in Bicycle Light from Sports & Entertainment on Aliexpress.com but the price seems to have gone up $31 in the last three weeks. Order from Fast Tech for the better deal.
    I couldn't find any of these on fast tech. I searched for "CREE XML2 T6 3B"
  15. #115
    I like turtles
    Honestly, the P7 Magicshine 808s are great lights and more than enough to ride fast singletrack at night. I ride with some guys that bought theirs after mine and have the XML version..no real difference to me as we ride. I have been considering the newest MS 808 light heads lately as my batteries are fine..but they are basically the same price as these Gemini Duo knock-offs..just not sure on the quasi-shady quality of these things.
  16. #116
    Having a lamp with two emitters on the bars makes for a better beam pattern, no question about it. Brightness isn't always the primary issue. Since you can buy one of these duo clones "lamp only" for about $25 it's hard not to buy one.
    Since you're accustomed to having a MS on the helmet you might be interested in upgrading your helmet set-up to a newer MS 808 (L2) version. Jim at Action LED is selling the "light head only" for about $55 . Definitely, these are going to be noticeably brighter than the old P-7's. Not to mention like I said before, it's not always about being brighter. The newer XM-L2 emitters are more efficient which means when you run your lamps on low not only are they a little brighter but they are using less battery power than the previous P-7's. That said, longer run times are always going to be a nice by-product of the newer lamps.
  17. #117
    Reputation: Gharddog03's Avatar
    Sep 2013
    Is there a link for the lighthead only?
  18. #118
    I like turtles
    Cat, can you post a link to the $25 light-head only?
  19. #119
    My yinding has the first gen xml's with the rectangles.
    Still plenty bright, folks who got the xml2s should post the vendor they got it from.
  20. #120
    Klydesdale
    Feb 2005
    Within the last week, I've looked for a dual XM-L2 lamphead only for the least cost on all the usual sites mentioned in this forum and this is the only one I found for around $25:
    Black Color SolarStorm X2 2*Cree XM-L2 2200-Lumen Led Bike Light Without Battery Pack
    The XM-L version is about $3 less.
  21. #121
    Nov 2012
    I believe he was talking about the Solarstorm x2, which is available as a light-head-only for around $21-$25.
    I think that the Gemini Duo Clones are only available as full kits with battery and charger. I would love to get my hands on a a light-head-only option for this light. If anyone knows of place that sells it, please post a link
  22. #122
    Oct 2013
    Is there a big difference between the Solarstorm X2 and the YinDing light? Is it worth it?
  23. #123
    So I finally go out for a ride with the new Duo clone. A few initial observations:
    I mounted the light on my helmet, and as I was leaving for the ride, I went to stuff the battery in my camelback. That's when I realized how short the cables are on both the light AND on the battery (I just hadn't thought of it until that moment).
    This is a nice feature if you're using it on your bars, less cable to deal with, but if you're using this on your helmet and putting the battery in a backpack or jersey pocket, get a Magicshine extension cable!
    Fortunately a friend had one to loan me.
    Next, the button is very flat, and can be a bit hard to feel with gloves on. Again, not much of a problem if it's on your bars because you can see it, but takes a little getting use to on your helmet when you're doing it by feel. I did find it was easier with my left hand than my right.
    Would be nice if the button stuck out just a bit.
    The beam is nice and even, no hot spot, no rings, etc. Definitely more of a flood light, but still very bright and decent range. But this is yet another reason it would be better on bars.
    I'm hoping that eventually I'll find some "spot" optics or reflectors that fit and will give it more throw.
    I think a stock one on bars for flood, and one configured for more spot/throw on helmet would be a PERFECT set up!
    I used it on high while riding, and switched to low or off when we stopped to regroup.
    Total ride time was 1 hr 22 min. Plus about 15 min on low while stopped, and my indicator light was still green at the end.
    Considering when we started, there was a sea of green leds on (17 riders with a LOT of various Magichines, and MS clones), and by the end of the ride there was a sea of blue, orange and red leds, I was pretty happy that mine was still green :-)
    Overall, very happy with this light and will buy another one which I will try to mod for more spot/throw using different optics or reflectors.
  24. #124
  25. #125
    Sep 2012
    Thanks for the feedback fightnut, out of all the bugdet multi-emitter lights I've seen this one appears so far to be the best built, in particular the internals and the Nuetral white tint if you get the version from Aliexpress. Beam profile looks fantastic.
    How did you find the mode spacing?
    If we can find some replacement optics this would be perfect.
  26. #126
    Quote Originally Posted by whokilledJR View Post
    Good question. I wouldn't mind if the "low" was lower.
    When I'm riding, I always have it on high. I don't mess around with switching modes when I'm going slower or faster, climbing or descending. I just leave it on high.
    But when we're stopped to re-group, or for trail side repairs, or even when I sneak off for a pee, I'd like a lower low to save battery and so I'm not blinding people.
    Not a big deal, but it would nice.
  27. #127
    Quote Originally Posted by Pinkman View Post
    There was one Solarstorm X2 on last nights ride. Unfortunately, there were so many riders, and so many lights going at any one time, that I just didn't get a chance to talk to the guy and compare it to my Duo clone.
    I'm hoping I run into him again on another ride, because I do want to compare the beam and the throw between the two lights.
  28. #128
    Oct 2013
    Quote Originally Posted by fightnut View Post
    There are differences in the quality of the light, but the technical things are nearly the same, right? I think the luminous power and is the same?!
  29. #129
    I think you'll find ( when you catch up to him ) that the SSX2 will have a bit more throw. On the other hand I have a feeling that the Duo clones are going to be better for more spill, hence make a better bar light than the SSX2. A good ( cheap ) combo set-up might be a SSX2 on the helmet and a Duo clone on the bars. Still all things considered while I may like the SSX2 on the helmet it still doesn't beat out the intense spot that a good single XM-L2 emitter reflector lamp can put out. Larger reflectors just rock.
    I'm going out to test my new Gloworm X2. I'll post up later...see ya.
  30. #130
    So any links to the Duo clone light head only?
    I purchased one set from FasTech last Tuesday(still not shipped) but would like another one if it is ~$25.
    Chris.
  31. #131
    Kir
    Kir is offline
    May 2013
    Magicshines have 4 stages battery indicator, Yinding has basically 2 stages (100-30% green, 30-25% red, 5-0% red blinking) - so don't be happy heh.
    My own Yinding has ~3500mAh battery and draws about 1.7A on high. So while it does have almost the same brightness as SSX2 its battery will only work for about 2-2.5 hours on high.
  32. #132
    May 2005
    I like having a "hidden" low low for things like map reading or pretty much any non-riding time. By "hidden" I mean that it is a mode accessed by something like a press and hold for 3 seconds. I don't want it in a rotation with the riding levels. Low enough so the map isn't blown out with too much light reflection.
  33. #133
    Quote Originally Posted by Kir View Post
    Considering my rides are under two hours anyway, and this is the stock battery, trust me, I'm happy :-)
    I can always spend a little extra money and get a better battery if I felt the need, but I don't see the need just yet.
    But I do carry a spare battery anyway. Since I use two lights, only makes sense to have one extra battery, just incase something fails, gets damaged in a crash, etc.
  34. #134
    Kir
    Kir is offline
    May 2013
    Quote Originally Posted by krzysiekmz View Post
    Chris.
    I talked with the seller of these lights on aliexpress.
    Light head only will cost $35-40 if you order 10-50 pieces. Complete set can be bought for $40-45 for same quanity, so imo its not worth it to buy only the head.
  35. #135
    Gemini Duo clones
    Just went out for my first ride with two Yindings I got from fastech. Shipping was about 3 weeks from order which I found acceptable.
    I have been night riding on and off since the good old days of the dual beam night suns 20 years ago. My latest setup was a Baja Designs origional Stryker and the original magicshine on the helmet.
    These two tiny lights blew away every other setup I have ever had (but to be honest I always have been a bit cheap with the lights). After a two hour ride both lights were still green using a combo of low through high. I used the stock battery on one an the Baja designs battery on the other. I was very impressed that these lights are available for 50 bucks.
    Would be nice if some tighter optics would be available for the helmet light but honestly I am not really into tinkering with them but as soon as someone figures out what will drop right in I will order up.
  36. #136
    Sep 2013
    Sweet set-up. Might pull the trigger on one.
  37. #137
    Great thread, can anyone compare the light pattern from the original vs. the clone? looking for a headlite and wondering if the original duo is more of a spot?
    Thanks for any help.
  38. #138
    Oct 2011
    Has anyone seen these yet with the new XM-L2 emitters? I am planning on ordering a couple of these, but not sure if I should wait and see if the new models show up soon.
    2012 Carbon Flash
    2012 Epic
    2011 Anthem X
  39. #139
    Well mine FINALLY arrived from Fasttech today, a mere 5 weeks since I ordered it!
    Anyway... Rant over... Battery is currently on charge, but the light head unit seems exceptionally well made compared to other "cheapo chinese" light head units I've seen. Just hoping it's as good as the initial beam patterns thrown up on this thread so far suggest it should be, and that the battery is significantly better than the rubbish ones the Solarstorm X2's are coming with!
    Will post more later when I've tried it out...
  40. #140
    Incidentally...
    I've had a play with a Gemini Duo fairly recently (and it was superb), and aside from the 3 grooves in the fins on the top of the body, this light head is not so much a clone of the Gemini, but is more likely actually the same unit!
    I'll see if I can get hold of a Gemini again and do some measurements to compare them, but I'd be very surprised if they don't come out of the same factory.
    I can't speak for the batteries though, I know the Gemini's ship with high quality Samsung cell packs.
  41. #141
    Sep 2013
    Quote Originally Posted by markyboy1980 View Post
    Incidentally...
    WoW, I love my duo's. If that's the case I would buy a few.
  42. #142
    Quote Originally Posted by Gharddog03 View Post
    Well to be fair, the driver will be different too (doesn't appear to be programmable), and annoyingly it cycles low/med/high/off so you have to go through off each time to come back to low or medium! Ah well...
    Here's some VERY rubbish beam shots to compare... First up is the Yinding on High...
    Then here's my Exposure Toro Mk3 on high...
    You'll notice that the Toro has a narrower, more focussed beam. I'd say that crap photography aside, the Toro is slightly brighter in the centre of the beam (so probably has a bit more throw), but the Yinding has WAY more spread which will make it a much better offroad light than the Toro is (and most of the cheap XML's).
    And here's my Joystick Mk7 on high for comparison too...
    Other things to note. The Yinding starts to warm up pretty quickly, suggesting the LED's have been connected well by lots of thermal compound to the head unit. Overall quality seems very high, and I'm impressed with it for what it cost. Even on low power, the light is plenty useable for moderate paced offroad riding, and medium beam is more than enough for anything except full on DH trail riding at night. Beam pattern wise, it's mildly reminiscent of my old Troutie Lumen Liberator (though not quite as broad) which is easily the best offroad light I've ever used. I will however be keeping my Toro for road riding at night though, cos the tighter more focussed beam (and built in battery) make it much better suited for that purpose.
  43. #143
    Reputation: tmoney's Avatar
    I have a Gemini Duo that I purchased from Jim at ActionLED. My question is do these clones have the ability to program the modes? My gemini will allow you to adjust the Hi Med Low settings in 10% power increments. So for example you can have a Hi of 90% Med of 40% and Low of 20% if you want or have a Hi of 100% med of 80% and Low of 60%. Pretty cool feature! Seems like a great deal on a bike light regardless.
  44. #144
    Quote Originally Posted by tmoney View Post
    No
    Sadly not. But I'd say the 3 modes it does have are well thought out. Don't have a multimeter available to measure current, but I'd guess low is about 30-40% and medium is 60-70% is high is taken to be 100%.
  45. #145
    Got my Yinding 2xXM-L U2 from Fasttech today (20 days from order).
    Tried it at home and snapped some comparison shots for reference. Nothing like proper beamshots but thought they might be of interest.
    It really is tiny
    Floodier than the 3xXML. Will probably feel like shorter throw in use.
    Brighter, cooler colour and less floody than the Magicshine MJ-872
    Finally. A lot brighter, whiter and floodier than my old MJ808 (P7)
    I think, changing one lens to more spot would make this a really really good helmet light.
    Cheers
    /Johan
  46. #146
    Nice shots modig.
    I'm interested in seeing how the 2x compares to the 3x out in the real world.
  47. #147
    Extremely bluish...hope some of this is reflect of the blue housing anodisation.
  48. #148
    Quote Originally Posted by the mayor View Post
    Nice shots modig.
    Thanks. I'll try to get out and make some proper comparison shots and post back here.
    /Johan
  49. #149
    No, I have a red one, and I'd say his photos are pretty spot on (I also have the 3 XML he's comparing it to).
    However, when out on the trail, and using both of these lights together (the Duo clone and the triple XML), I don't really see the "blue" tint so much, if at all.
  50. #150
    Sep 2013
    Thanks Markyboy180 and Modig for the pics!
    It looks smaller then my Duo.
  51. #151
    fightnut,
    How would you compare the 2 lights?
    I have the 3x
    Is the 2x worth getting?
  52. #152
    fightnut,
    I have the 3x
    Absolutely worth getting. I think it's the best deal going right now.
    As far as how it compares to my 3xml:
    1. Significantly smaller
    2. Significantly lighter
    3. Cost less (once you add in upgraded battery to 3xml, which is pretty much a must). Like I said, I'm into the 3xml for $100 with upgraded battery. With current prices, it would be more like $$85 for light and upgraded battery.
    4. Almost as bright. Doesn't have the throw or "punch" of the 3 xml, but with some different optics, or maybe reflectors instead, it could have very decent throw.
  53. #153
    Gharddog, do you have any calipers to measure your Gemini?
    I get 44mm wide x 34.4mm deep (front to back) x 24.2mm high (not including mount) for the Duo clone with my digital calipers.
  54. #154
    Sep 2013
    No I don't.
  55. #155
    A
    Thanks for the reply!
    I have a 3x....and agree with you. But if it's brighter....I'm going to keep it... for now.
    But I might get this 2x....or a SS2x xml2...to replace the Hi-Max single U2 light on my helmet.
  56. #156
    Got out a short spin tonight but doing beamshots was trickier than I figured. Will have to do this again but find a better place and mount the lights to my bars. I didn't have a tripod for my camera and I managed to point the lights a bit differently so it'll be hard to make a proper comparison. At least the are all shot with the same exposure (F2.0, 1/3 s, ISO 800) and whitebalance (daylight). My bike is about 20 m away.You can click the image for larger size. (Or go here for even larger http://privat.bahnhof.se/wb594059/test/Comparison.JPG )
    The med in the Yinding is much more sensible than on the 3xXML where there is almost no difference to high. I think that I would have a hard time to tell the beam pattern apart on the trail.
    Big win for the Yinding since it's so much smaller and lighter. I haven't tested battery properly but I find the short leads stupid but not a real problem since I already had an extension.
    Cheers
    /Johan
  57. #157
    Sep 2013
    Wow. Thanks Johan.
  58. #158
    Just ordered this light, has anyone found any optics to make it slighly more spotty ?
    Was going to replace just one of the optics.
  59. #159
    No I don't.
    Use a ruler.
  60. #160
    Nov 2012
    Thanks for the pictures Johan. Nice work
    I wonder why the triple on medium (2 led's lit) looks as bright as the Duo clone on high. Is the triple drawing more current, or are the optics of the duo sucking up all the light energy? Perhaps the Duo outhrows the triple? The triple looks to be much floodier than the duo also, which is a positive in my book.
    Based on these pictures, I would buy the triple before the duo. What do you all think?
  61. #161
    I just got back from a ride where I ran into a guy with a real Duo.
    My 3x is brighter and floodier on medium....and even more brighter on high.
    I don't know why people say there isn't much difference between high and medium. If you shine it on a wall at close range, there isn't. But outside...it is very noticable.
    I might look at a Duo clone or a SSx2 for a helmet light.....but I like the 3x for the handlebar in the woods.
  62. #162
    Sep 2013
    The 3x is no slouch that's for sure.
  63. #163
    Yep, that's for sure. Keep in mind most of the tri-clones are just standard XM-L T-6. Shouldn't be too long before you start seeing them in U2 or with XM-L2's. Right now I'd like to see a SSX2 with XM-L2 (U2). Ha!, for that matter anything with XM-L2 U2 is going to rock.
    When I first got my tri-clone I compared it to my Gloworm X2 (v2) with XM-L U2's. Both lamps compared very well as far as output ( on high ) goes with the Tri-clone having perhaps a bit more throw because of the tri-reflector set-up.
    If I were going to go with a super cheap Chinese combo set-up for MTB'ing I would either go with a combo Tri-clone on the bars / single XM-L (U2) emitter clone lamp on the helmet OR Duo clone on the bars and SSX2 on the helmet. The first combo would have a bit more throw with the second a bit more flood.
    Yep, if you can afford $80 for a Chinese combo set-up you can rock the night. Spend another $30 or $50 for a better battery and you're set.
  64. #164
    Oct 2011
    Cat-man-do, I recently ordered a SSX2 to run on my helmet, and am struggling to pick out a flood to go with it. I was pretty sold on the duo clone, until seeing the picture above with the three XML beam shot, maybe I there is something I am missing but it looks like the 3xml destroys the duo clone in both flood and throw? Is there something I am missing? Could you explain the reason for matching the duo clone to the SSX2 and not the tri-clone?
    I am ready to order something but would feel much better picking a sound option from those with experience, no matter how many threads I read it will not make up for those of you who have actually seen these lights firsthand
    2012 Carbon Flash
    2012 Epic
    2011 Anthem X
  65. #165
    Nov 2012
    Like fightnut said, one of the main things that the Duo clone has going for it is the really small size. The triple has to be pretty cheap by now, on the other hand. I remember seeing the light-head-only option for around $35 a couple of months ago.
    By the way, the original seller of the xm-l2 version no longer has them, but I found this alternative:
    On sale for $69.81.
  66. #166
    Sep 2013
    Quote Originally Posted by varider View Post
    On sale for $69.81.
    Damn, no more 49.99$. That's Gemini territory for me. Since I wouldn't use the battery.
  67. #167
    Nov 2012
    The xml versions are still available on fasttech for 51.18. The xm-l2 versions were always more expensive.
  68. #168
    And there's still these at Wallbuys.com with XM-L-U2's
  69. #169
    Quote Originally Posted by Posher View Post
    As I said above...after comparing my 3x with a Duo....I am sticking with the 3x.
    It's a little bigger...but a LOT brighter.
    Here;s one for $40
    SecurityIng® 3X CREE XM-L T6 LED 3800Lm LED Headlight Headlamp and Bicycle Light:Amazon:Sports & Outdoors
    But the supplied battery will only run about 1 1/4 hours on high....so you may need a stronger battery.
    I am probably going to get a SSx2 or a Duo for my helmet....
  70. #170
    Reputation: J.R.A.'s Avatar
    Nov 2012
    I just purchased one of the Gemini clones from Fast Tech and like other posters that have asked if I want to make the light a little more spotty what lense would you need to exchange it with? I know it 20mm in diameter but what angle do I need to get? Do I need a 5* angle, a 10* or a 15*???? Please help. Thanks.
  71. #171
    [QUOTE=the mayor;10770945]It's a little bigger...but a LOT brighter.
    QUOTE]
    I would disagree. Granted, terms like "little" and "LOT" are relative terms and will have different meanings for different people.
    But we can measure weight and size, and I'd hardly call a 250% (2.5x) difference in size and weight a "little" bigger. I'd call the 3xml a lot bigger.
    As far as brightness, is the 3xml brighter?, yes. But I don't know that I'd go as far as to call it a "LOT" brighter.
  72. #172
    Nov 2012
    Quote Originally Posted by J.R.A. View Post
    There was a lot of optics talk on page 9 of the d99 thread
    UltraFire D99 a promising new 2x light?
    That's a good place to start
    If you want spotty then you would get 5 degrees or smaller
  73. #173
    In regards to Cat-man-do looking for a SSX2 with XM-L2 (U2). Is this what you are looking for:
    Black Color SolarStorm X2 2*Cree XM-L2 2200-Lumen Led Bike Light Without Battery Pack - Bicycle Lights Lamp Cap - Bicycle Light & Headlamp Worldwide Free Shipping!!!
    I have been reading through pages and pages of posts trying to educate my self on the current options and like most people trying to get the most bang for my buck and spend as little as possible at the same time. My wife is not convinced that I even need lights. So I am looking at maybe ordering the above. With a better battery.
    Would it be a bad idea to even just order 2 of these?
  74. #174
    Sep 2013
    Already sold out.
  75. #175
    Already sold out.
    Looks like it's just the black ones are sold out. They still have reds and blues (for now).
  76. #176
    [QUOTE=fightnut;10771030]
    QUOTE]
    I would disagree.
    Of course you would...
    It's brighter. You can't argue with that.
    Size? If the size is that big of a deal....go with the dimmer light.
  77. #177
    [QUOTE=the mayor;10771324]
    No need to get butthurt because I disagree with you on a couple things.
    Man, must be the change in weather or something.
  78. #178
    Klydesdale
    Feb 2005
    My Gemini Duo measures basically those same dimensions with my cheap plastic calipers.
  79. #179
    Sep 2013
    Quote Originally Posted by klydesdale View Post
    Copy that. Used a plastic ruler I had laying around and pretty much dead on with the same dimensions.
  80. #180
    Quote Originally Posted by bmoney View Post
    Thanks b$. The link you posted is likely for XM-L2's using the standard T-6 bin. These will be very bright but I'm going to hold out for the U2 version. I just like the whiter tint. Currently I have the SSX2 with standard XM-L (U2) ....which is the first XM-L U2 version. When these are released with the second U2 version they will be even more awesome.
    b$, if you buy two of these XM-L2 (T-6) I don't think you will be disappointed...however....one of these 880 clones might be better for the bars because of the wider beam pattern. Find one with XM-L2's and that would be even better.
    Wifey should have no problem with you buying a couple "emergency home illumination light-sets"...yes, yes...in a power outage these babies will light your house for about 6 hours when on low. With two going you have all the light you need ( including one for the bedroom if you catch my drift... )
  81. #181
    [QUOTE=fightnut;10771393]
    I'm old. My butt is sensitive.
    But my brighter light helps a little.....and little is subjective ;^)
    Seriously....the Duo and it's clones are frikkin amazing for their brightness and their tiny size. When I saw the first one last year...I laughed until the lady turned it on.
    I am flip flopping on the Duo clone and a SSx2 to replace my Hi-Max XML U2 helmet light.
    But with the buzz about the possible Xm_l2 U2...or better...
    I still have my Vista Lite dual 10w set up from 1991....like 2 birthday candles on your bars. They were awesome back then
    Then I got the Nite Sun Team Issue ( which I still have )....
    I guess we have real 1st world problems arguing over bike lights, right?
  82. #182
    I like turtles
    Vista Lites..I had the 2x10w and 1 wt circa '95. I remember the older ones like you are talking about. The new cheap LEDs are amazing compared to those old lights.
  83. #183
    [QUOTE=the mayor;10772965]
    Agreed! We do tend to get a bit obsessive over lights in this forum at times.
    I just need to bundle up, step away from the keyboard, and go ride!
  84. #184
    You can convert it into a modern light.
    Convert Nightsun to LED 400 to 500+ lumens
  85. #185
    LOL...bubs you really dug that one up now didn't you. That thread is from back in 2008. All the links are outdated and dead. When you can buy a twin XM-L lamp head for about $26 all the conversions make no sense anymore.
  86. #186
    5 secs using a search engine. It can be cheaper than $26, how much is two mr16 triple cree bulbs? $5 each? Pretty sure they're dirt cheap on ebay.
    Yeah, I rather get an xml dual ssx2 lighthead from lightmall for $22 instead.
  87. #187
    He, he...I hear ya. When you factor in the problem of doing the DIY conversion, finding a compatible battery and having no mode changes the $22-$27 lamp head is a real no-brainer. Back then when the cheap P-7 torches came along almost no one talked about conversions anymore.
  88. #188
    Reputation: androgen's Avatar
    Apr 2005
    edit: nevermind ...
  89. #189
    I like turtles
    Anyone seen or tried this one? Light head only....$40...XM-L U2s....
    Nitefighter BT20 1200 Lumen 4 Mode Bike Light Head Only with O Rings | eBay
  90. #190
    Nov 2012
    I think KD MJ 880 clone or SS X2/X3 is better option ...
  91. #191
    Finnaly, I`ve got it!
    It is indeed very small and light...compared to MJ808 P7 and MJ872
    It is right between MJ808 P7 and MJ872. That goes for beam pattern and amount of light-
    I would say around 1000-1100lm
    I am very impressed with the build quality but disappointed with charger. It cuts off at 8,2V. That is waaay to early.
    I will post trail beamshots in a week (including MJ808, MJ808e, MJ880, MJ872, MJ880 clone, 3xXML clone, SS2X, Lupine Tesla)
  92. #192
    Sep 2013
    Sweet. Patiently waiting for the beam shots.
  93. #193
    I like turtles
    Wow...I had no idea how small these actually are! Yes..looking forward to beam shots. I really want either a genuine Duo or one of these clones..look so cool.
  94. #194
    Here are some quick shots
  95. #195
    Nov 2012
    Nice comparison! Very well done. A couple of questions for you. Which MJ880 clone do you have, the one from KD? Do you have the genuine MJ872 or the $30 clone? I always like the ability of the MJ872 clone to evenly light the near field. Is it the xml solarstorm or the xm-l2?
    The dual emitter lights are clearly superior to the single emitter lights. It looks like the Yinding (Duo clone) has the best throw, but that could just be a function of how it's aimed (slightly higher?). They are all pretty similar really, but the Solarstorm has the brightest hot spot. It's tough to pick a favorite. I would probably go with the MJ880 clone or the Duo clone, because of the even beam in both near- and far-field.
    I'm really impressed with the Duo clone. How are they pumping out this much light in such a small housing without overheating the light? Does it get hot, or is it a superior design?
    The 872 is good if you want a really bright near-field, maybe for tricky root or rock sections. It obviously has bad throw. The three dual-emitter lights are probably a better buy for most people.
    Based on the picture Modig posted, the triple xml is also a good bet. It's has a proven track record, and it appears to be somewhat brighter then the three major dual emitter lights (880 clone, Solarstorm X2, Gemini Duo clone). The triple can be had for pretty cheap now, I'm sure. There's also the option of buying these lights as light-heads-only. That's especially good if you already have decent battery from action led or xeccon. The Solarstorm and the KD 880 clone are both available that way.
    It seems that we have reached a new standard for cheap lights and a new era of night riding. It's probably enough for most riders to ride at their day time speeds without too much worry. The doubles are definitely in and singles are out. These new lights really open up the world of night riding for everyone.
    In my opinion, the better the cheap lights get, the harder it is to justify the $200 minimum for the "good" lights. I feel sorry for the guys who only buy their lights at the bike store. $100 buys you a 400 lumen light that last 1.5 hours. $100 sent to China buys you two complete sets of lights that are two to three times as bright and last for twice as long! If you read the bike magazine this entire segment of lights, i.e. Chinese imports, is virtually ignored. If it wasn't for this forum, I would have never known this stuff was out there. Thanks guys.
    Happy night riding everyone!
  96. #196
    I like turtles
    That 808 XML looks a lot nicer than the P7...man...I really need to upgrade
  97. #197
    bhocewar, is there a chance the MJ872 was aimed a little lower then the others?
    Great comparison of lights by the way.
  98. #198
    Sep 2013
    Very nice. Thanks.
  99. #199
    It is original Magicshine.
    XML u2 from aliexpress, the first one that was selling for $33.
    SSX2 and MJ880 clone have noticeable better throw. They are also brighter. It doesn't have such spot it is floodier so it is hard to aim them the same.
    No, it is veeery floody. It doesn't have any throw.
  100. #200
    Sep 2013
    The 872 appears to have a nice flood.
  1. Magicshine clones arrived!
    By klynk in forum Lights DIY - Do It Yourself
    Last Post: 05-14-2014, 07:34 PM
  2. Anyone try one of these 872 clones yet
    By Rakuman in forum Lights and Night Riding
    Last Post: 12-30-2013, 06:16 AM
  3. Gemini DUO x 2
    By jgutz71 in forum Lights and Night Riding
    Last Post: 05-02-2013, 08:27 AM
  4. magic shine 808 xml clones
    By Reelchef67 in forum Lights and Night Riding
    Last Post: 11-23-2012, 07:21 PM
  5. Gemini Duo
    By rixsurfer in forum Lights and Night Riding
    Last Post: 10-09-2012, 11:00 AM
