Results 1 to 3 of 3
    Reputation: mazspeed's Avatar
    Gemini charger lost. Can you charge the battery with this?
    I have a handful of netgear and other chargers that will fit the battery pack, but seemed to have misplaced my charger. Can you guys recommend if this would work?
    Netgear charger output 12v 2.5 amp
    lei charger output 9v 0.6 amps
    What would be a substitute for a charger for the 6 cell pack?
    Action LED Lights
    Reputation: Action LED Lights's Avatar
    Absolutely not!!!!!
    The charger must be designed to charge Li-ion batteries. For your Gemini pack they are voltage controlled to 8.4V with a maximum current of 1.5 or 1.8 amps.
    Jim Harger
    Action LED Lights
    www.action-led-lights.com
    because GIANT
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    you need a lithium specific CC/CV charger appropriate for 8.4 volt lithium
    a 4.2 volt CC/CV won't do a thing
    otherwise...if you use something like you described, prepare for a fire,
    or the plastic chemical stink from hell+a fire.
  1. When to charge a Magicshine MJ828 battery ?
    By edle in forum Lights and Night Riding
    Last Post: 11-26-2013, 07:09 AM
  2. Gemini Olympia? End of Charge Behavior?
    By dcelento in forum Lights and Night Riding
    Last Post: 09-27-2013, 10:40 AM
  3. Turnigy charger- can you use it to monitor charge level of battery packs?
    By Ofroad'bent in forum Lights DIY - Do It Yourself
    Last Post: 12-11-2011, 05:12 PM
  4. Imax b6 to charge a magicshine battery?
    By Wombat in forum Lights DIY - Do It Yourself
    Last Post: 08-29-2011, 02:19 PM
  5. Majicshine battery charge times
    By Pitto in forum Lights and Night Riding
    Last Post: 05-30-2011, 10:06 AM
