Results 1 to 35 of 35
    Found All The Parts for my Old NiteRider Digital Pro 12
    Hey Guys,
    I just found all the pieces to my old NiteRider Digital Pro 12 light... Here is what I have:
    Wall Charger w/Micro-Brute piece
    Rear LED Taillight
    Digital Pro 12 Headlamp
    Nickel Metal Halide (spelling?) battery
    Handlebar Mount
    So I found all of these parts in different parts of my garage and house... I just plugged in the battery into the charger and it immediately light up and started charging. I got antsy to see if it was working okay and I plugged the light into the battery and it turned on and all seemed fine.
    Is there anything special I should do to the battery? I haven't charged this thing in probably 6 years... Anything else I should do to get everything running again?
    Thanks,
    Mike
    Reputation: California L33's Avatar
    Are you sure it's a NiMH battery? If it is, it might just work for you, with a decent run time. They tend to be pretty forgiving if stored in a cool place. I thought most batteries of that time were NiCad. Those tend to degrade rapidly if not charged. What I'd do is either run it during the day to see what the run time is, or bring the bike into the house and put a fan on the light head to keep it cool and check it (don't leave unattended). You may need to charge/discharge it a few times to get maximum run time.
    Edit: And if the battery isn't shot, give it a charge about once a month. That will increase its life.
    To the troll mobile, away...
    Yup, it is a Nickel Metal Hydride... That's what it says on the bottle at least.....
    I think a charge takes 5 hours so I'll charge it up and run it down and then plug it in again right when I go to bed.
    Thanks,
    Mike
    Great... Everything seemed to be working fine and I brought it all to my buddies house. Now when I plug the Micro-Brute thingy into the charger, it flashes red/green, indicating some sort of error.... FIGURES!
    Whats the charge time without the Micro-Brute? Any ideas on what could be wrong?
    I'm going to cycle it as many times in the next two days as possible to get the battery back in tip-top shape.
    Thanks,
    Mike
    Update: Unplugged it a few times and now it seems to be working - got a red light on it at least.
    -Mike
    Goats Rule!
    i still have mine from 1998.
    Okay so the Micro-Brute went from a red light to a green light so I tried the light out... I got it into SOS mode once and both beams on once too. After that all that would come one was the spot beam and the red light on the digital battery charge indicator thingy.
    Any ideas on how to get this light running again? I don't even remember how to switch modes and what not on the light lol
    -Mike
    Quote Originally Posted by Rex32
    -Mike
    Charge it again. When fully charged put it in the SOS mode- I'm assuming this is a flashing (and lowest power) mode. Let it run down. Don't put it in any other mode. Repeat a couple of times. Make sure you run a full charge cycle each time. You may coax the battery back, but it's unlikely if your former experiment only got a few seconds of run time.
    I did read somewhere that you could get replacement batteries from Battery Space dot com for NR systems that are a fraction of the price of the originals, but they don't have the 'smart chip' in them, so the fuel gauge won't work. I don't know if it's possible to 're-cell' the original battery pack, which would be a DIY project involving a soldering iron. Has anyone ever done this? It depends on whether you can get into it.
    You could theoretically make your own if you know the original battery's voltage and can cannibalize the original cable, and are somewhat handy You've got to consider the benefit of getting this running again with going with a new system.
    I noticed Salem Cycle selling the Dinotte 200L Pro for $120 without batteries/charger. A pair of those would give 400 lumens of smooth white light. (See my preferred way of using them in a message to you on your other thread.) If your old NR is halogen, you'll notice a difference. I replaced my 30 watt halogen system with a pair of 200Ls, and while the halogen may have been a bit brighter, the LED is better, more even, better color. 400 lumens isn't enough to blast down single track, but is enough for road and fire road riding. The nice thing about the Dinotte Pro system is that it uses off the shelf NiMH AA batteries, which are easy to replace, easy to find, easy to carry backups for. 'Precharged' batteries such as the Eneloop have a much longer lifespan than standard NiMH batteries, but you can get a set of 4 standard NiMH, with a charger, for sometimes as low as $20 at hardware stores, and even some supermarkets.
    I use the 200Ls on my road bike, and my old 30 watt Cygolite on my mountain bike. But when the battery packs for it fail, I'll be going with LED.
    ballbuster
    Reputation: pimpbot's Avatar
    I would be very surprised...
    Hey Guys,
    Rear LED Taillight
    Handlebar Mount
    Thanks,
    Mike
    ... if the battery was good. Do a run test to be sure it won't leave you stranded in the woods in the dark. NiMH have horrible self-drain... like 15% in a week. If you leave the battery flat for any length of time, it goes bad. Newer LiIon batteries are like 8% a month self-drain, IIRC
    I have one myself. It was a great light for its day. These days, LEDs are king.
    For the price of rebuilding the battery yourself (about $50-60) you are very close to getting a Magicshine that smokes it for $90 with more light output, 1/4 the weight and 2-3x the runtime.... not to mention replacement batteries are like $45 complete.
    If it works, great. If not, I wouldn't invest any money into refurbishing it.
    BTW, there is nothing smart in the battery. The charge circuit and battery fuel gauge is actually all in the light head. Some model years, they put a thermal cutoff resistor in there.
    Do It Yourself
    Reputation: Homebrew's Avatar
    There is a good chance your battery is shot. Here is a thread on building DIY NiMH packs in case you're interested:
    DIY Lights: How to build your own battery...
    However, rather then spend $50+ on a new battery, I would just get a Magicshine for $85. The MS will be easily twice as bright, 1/4 of the weight and burn twice as long.
    Long Live Long Rides
    ballbuster
    That's...
    Quote Originally Posted by Homebrew
    ... what I said!
    Its got what plants crave
    Reputation: Jim311's Avatar
    Feb 2006
    A few years ago I converted a 6 volt NR halogen to 12 volts, and upped the wattage to a 20 watt bulb. I got a lithium battery pack from Batteryspace and it ran well over 3 hours without problems, and the 20 watts of light it put out was as good if not better than the Magicshine I'm running now. Still, unless you can convert this thing over for pretty cheap, I wouldn't bother unless you just want a project to mess with. You may be able to get some cheap battery cells from DealExtreme or something and rebuild it yourself for not a ton of money, I'm not sure.
    Ocala Mountain Bike Association - www.omba.org
    Bandolero
    Reputation: notaknob's Avatar
    Centralia
    Quote Originally Posted by pimpbot
    $30 for DX. http://www.dealextreme.com/details.dx/sku.32756
    $38+SH from the guy in CO.
    Slow-core. -.. .-. .. -. -.- .... --- -- . -... .-. . .--
    ballbuster
    Hmmmm
    Quote Originally Posted by Jim311
    I ran 12/20W Halogens overvolted to 14.4v... Magicshine still beat it.
    Reputation: mtb_robs-x's Avatar
    Dec 2009
    gotta love it,....
    pointing him to a MS battery,....
    his light is 12V ,... nimh
    MS battery is 7.4V , li-ion,
    even is he takes 2x,... now its 14.4v overvolt,
    the connectors are different,.... the batteries, protection circuit, will just blow,
    maybe even permanent, since those halogens , want something like 30A+ on startup,
    and 2x ms are over $80,... and still not working,.....
    suggestion could be:
    - sell niterider, what-ever amount,
    - put money for replacement battery + niterider $ towards new light
    cheers
    note: my buddy replaced his mimh battery with a 13.2V, added a 20W bulb,
    is using it as a helmet light, has niterider hid on handlebar,....works for him,
    and he has no intentions to upgrade,... thought he has about $18k in bikes.
    Quote Originally Posted by notaknob
    DIY battery + light working on it
    ballbuster
    No, wait, you misunderstood
    Quote Originally Posted by mtb_robs-x
    gotta love it,....
    cheers
    we were suggesting that for the dough one could invest in rebuilding the battery, you could just about get a MS light. Comparing the cost of ownership, the MS comes out to be much cheaper to own because the replacement batteries are way cheaper too, not to mention LiIon batteries don't self destruct like NiMH batteries do if you leave them off the charger for months on end.
    Nobody suggested grafting a MS battery on to a NR light. A) wrong voltage b) not enough Amp Hours to make it work even if you got the voltage to match unless you stack up a bunch of MS batteries and put it through a voltage regulator that can kick out like 4-5 amps... the cost of making it work and the hassle is far exceeding the benefits.
    What makes LEDs so cool is that they kick out tons of light for very little current, meaning you can get away with a much smaller and cheaper battery. Plus, they don't burn out and fail like HID and Halogen do. Halogen and HID are both dead, IMO.
    'Sub-C' batteries are selling for $3-$4, so for $30-$40 he could make his own battery pack with 10 (exactly the way the factory did), though he'd have to cannibalize his connectors and hopefully, fuse or circuit breaker. The more expensive ones are 3800 mAh. I don't know what the original rating for the factory battery was, and for a bit more you can get 4600 or 4700. Solder tab are easier to work with, but you do have to have soldering skills.
    http://www.google.com/products?q=sub...aq=2&oq=sub+c+
    Only Batteries is selling a 4200 mAh version for $2000 each, so a full pack would cost $20,000. I'd recommend one of the other suppliers.
    http://www.onlybatteries.com/showite...t1=52&uid=2037
    Edit: 10 batteries is assuming a 12V pack. I don't have NR, so I don't know what voltage they ran.
    Edit 2: The OP would also need some basic electronics skills (very basic) to know to solder the batteries in series, but information on that should be widely available on the web.
    The niterider batteries, as is the case with most bike lights, use 4/3A nimh cells typically in the 4000-4500mah range. The 4/3A cells tend to have better discharge characteristics relative to cost for bike lights than sub-c cells.
    Quote Originally Posted by MtbMacgyver
    Never had a NR. My old halogen Cygolite used 6 sub C cells, both in the original, and the aftermarket pack I bought from BatterySpace or a similar online store. They provided 7.2 volts for a slight over-voltage on 6 volt lamps. The aftermarket was definitely rated at 5000 mAh. I think the factory pack was rated about the same. This provided about 3 hours at 10 watts, and 45 minutes at 30 watts (upgraded the 15 watt bulb with a 20 shortly after buying it). When I did a Google search I couldn't find any 5000 mAh sub Cs. They may be going the way of halogen lights. Everything seems to be using multiple 2500 mAh+ AAs, or Li now.
    I believe the 3800s I saw said they could be discharged at up to 30 watts, and that should give 30 minutes + run time at that rate. If the OP doesn't use both lamps, he'd naturally get more run time. Of course assuming he's got the technical chops to do it, he still has to weigh the cost/benefits of staying with the old technology. Money is tight for some folks right now.
    Okay you guys convinced me to get a MS light...
    Where can I get a solid handle bar mount for it?
    Any upgrades to beef up the output or improve the quality?
    Thanks,
    Mike
    Thanks,
    Mike
    The MS looks like it has a rubber band type mount like the Dinotte 200 series, which I have. It's a very secure mounting system. I imagine the MS's will be also, even if the light head is a bit bigger. Just be sure to check the band for deterioration every once in a while. Replacements are available at any hardware store- they're just rubber 'O' rings.
    You want to beef up the output? Do you think you'll need more than 900 lumens?
    Check out Geomangear dot com.
    ballbuster
    Second that
    Quote Originally Posted by California L33
    Yeah... I say get the light and try it out before you to into mod land. I think you'll be pleasantly surprised.
    The only real weak spot I can see is that the bar mount clip is held onto the light head with a small screw. It doesn't look like there are a ton of threads engaged on the screw, but it feels solid enough in reality.
    I ordered some different bar mounts and a couple helmet mounts from Doug Hoffman, should be here next week.
    Now time to order two MS lights, Geoman the place to go for that?
    Feb 2006
    Has anyone given one of these MR16 drop ins a thought for those old halogens you've got sitting around? I just saw them on DX, for 10 bucks it'd be an easy way to get some extra battery life and maybe refresh an old halogen into something usable for a cheap price. 360 claimed lumens *shrug*
    I wonder if it would fit the zillions of Niterider 12V halogens that are floating around on Ebay and such for next to nothing.
    http://www.dealextreme.com/details.dx/sku.30208
    You need MR11 form factor for Niterider and most other halogen bike lights. In general these drop ins tend to be too floody to work well. The power also has to be fairly limited because of the lack of good thermal path needed to keep LEDs cool.
    Feb 2006
    Woops, was thinking it was MR11, my bad!
    Nothing to see here, move along
    what is up with night rider there support sucks ! I have called and emailed with no reply.
    Feb 2006
    Quote Originally Posted by rdmtb123
    Well when you buy a higher quality like like the Niterider instead of say a cheapo like a Magicshine you get better customer support and warranty work too.
    Oh wait.
    night rider is what i got????
    Just did some checking on eBay. It appears that some of these units come with beams as narrow as 15 degrees (though some are as wide as 180 and would be truly useless as a bike light). I'm not sure about the NR heads, but it looks like most would fit my old Cygolite head- a couple of those and a 10 AA battery pack might make a nice cheap alternative. As my Cygolite is only 6V and I have 2 good batteries and a bunch of spare bulbs, and they don't appear to make 6V MR16 LEDs, I won't be doing any experiments in the near future.
    Feb 2006
    I found some MR11 LEDs but they are all very low lumens, like 100 lumens or less. Oh well.
    Keep looking. I found some wide beam patterns they were claiming over 400 lumens (9 watts) from- lots of light but no good for a bike. I found some narrow beam they were claiming over 200 lumens (5 watts) from. With a pair, 400 lumens in a narrow beam would be good for fire road or street riding, not so good for downhill. Unfortunately, I didn't save any links. If I remember correctly, the 5 watt narrow beam bulbs were on eBay, a wide beam offered for sale, with a note in the description that you could specify 15, 30, or 45 degrees if you wanted.
    Feb 2006
    For me personally I wouldn't switch unless I found something 400+ lumens or more. The pack that I have leftover from my halogen setup is 14.8V 4000 MAH, which runs a 20 watt bulb for like 4 hours and puts out 600+ lumens I imagine. I'll stick with that rather than lose a ton of lumens I think.
    It's not exactly an apples to apples comparison. My old halogen system is two bulb, 35 watt total. It probably produces more light than my two Dinotte 200Ls, but I'd rather ride with the later because of the quality of the light (much closer to daylight) and the beam pattern which is more useful (a lot less side spill) and the light is smoother without hot spots. Hot spots and spill may or may not have been addressed with MR16 LED light designers, so if anyone tries it keep us posted.
    Dec 2009
    some math
    14.8 * 4 = ~60whr
    20w overvolted to 14.8 .... ~28w
    60/20 = 3 hrs 60/28 = 2hrs+ don't see ever to get to 4hrs ?
    now if its a small MR11 like niterider,... you won't even get 600 lumen.
    if it's a MR16, a newer one,... at overvolt, could reach 720 lumen, but would dim down,
    as the voltage drops.
    digging out my old halogen light bulbs, and find, there are quit usable,
    that is if you have the battery juice,...
    now if you add a LED, it's quiet nice.
    for the post , the led is smoother,... depends on what halogen,
    the small ones are ruff on the edge,.... the bigger brothers, are really smooth,
    that if it's not a spot. for smooth light, the MR16 wide, is the smoothest I've seen.
    working on a classic / hybrid , what has new/old features.
    CRI is one of them,
    and the yellow, is very good, not only in penetrating fog/wet conditions, and less glare back, but another aspecs, since we are riding, is depth perception.
