    nocturnal oblivion
    Reputation: stumblemumble's Avatar
    Mar 2006
    "Filtering" a MS 808 - Will it overheat?
    I'm starting to commute and not doing a lot of night trail riding, so the MS has been mounted under the seat along the rails using the helmet mount plate. Would using a red filter over the lens cause overheating?
    I'm thinking of using the adhesive translucent tape used to fix vehicle taillights. Up front I have a 400L Dinotte on the helmet. The MS is a quick release mount via the rubber o-ring, hence the reason it was relegated to taillight status.
    "...like sex with the trail." - Boe
    GeoMan
    Reputation: GEOMAN's Avatar
    We have used a plastic diffuser lens over the MJ-808 and run it on high for a 12 hour night race, didn't seem to cause any heat issues
    Quote Originally Posted by stumblemumble
    GeoMan
    We Ride!
    www.geomangear.com
    nocturnal oblivion
    Mar 2006
    Sounds good! Thanks.
    GeoMan
    If it doesn't work out and you need to replace the glass lens, just email geoman@geomangear.com and we'll take care of that
    GeoMan
    We Ride!
    www.geomangear.com
