DesignShine... WOW!
66K views 230 replies 36 participants last post by  adams22
#1 ·
I just got me a DesignShine taillight... and it is astounding. :eek: I never though I'd see such a thing, but somebody has just bested the venerable DiNotte 400R. I put them side by side outside, the difference is plainly visible.
I'll post a video shortly, but first I have some work-type work to finish, a very unfortunate circumstance. I'll get to play with my new toy this afternoon.
I also got the DesignShine front light. But I can't really put it to work until it gets dark.
More in a few hours... including a waterboarding. :arf:
#48 ·
@ pethelman - when will we be able to buy the mtb helmet version?
I really like the flood/spot combo picture. You only sell the spot/spot version now, correct?
The light body is already compatible with the existing Cateye helmet mount bracket ($9 part). When I build the battery packs for the helmets, I usually build the connector into the pack itself with no pigtail wire (makes for a clean install). Then you can use the extender cable as an option for off-helmet batteries.
I can make whatever combination of lenses you desire. In general, I like to keep the pure spot lens on the XPE triple, since it does throw so well, but then for the XPG triple, you could use a narrow frosted lens, or a medium frosted, or even a wide. Personally, I think the medium frosted in combination with the pure spot would make for a super nice, single light solution on the helmet, but I really do need feedback from more riders to determine what works best. IF there turns out to be a tiny corner of the market for a light like this and IF I can manage another run of lights (cost and time-wise) after the current batch, then I have a design mod worked up already that would allow the clear lens cover to be removable (and still waterproof) and the lenses to be user-swappable, just by removing the single hold down screw. For the current design, however, it is sealed to the aluminum body, so you have to decide prior to build, what lens combination you want.
Helmet mount pics here:
https://sites.google.com/site/designshinelighting/image-page
#51 ·
I have to say, Chromagftw, I agree that two of those babies would rock!
Last night when I was riding on the trail - and keep in mind it's 2:30 am and I'm alone by the river, and I'm a woman. A big and strong woman that has punched sexual harassers in the face more than once, but still a woman. So I'm riding on that trail and I see something in front of me. Looks like some guy doing something weird. But what??!! F****!
I had my DS on. I punched the button on the BR IV and now I suddenly had 2500 lumens! And I could clearly see that the guy was just fixing his bike.
It really is cool to have that many lumens. I loved it. But the DS and the BR IV and two batteries on my handlebars... that's just too much of a mess. Way too much.
Now, if I had some extra money burning a hole in my pocket, I'd get another DS-1300 and power the two lights from a single water bottle battery. Now that would be a cool setup.
#59 ·
At night both the DS-500 and the DiNotte 400R are about equivalent since you have to run the DS-500 in a lower power setting.
But where the DS-500 has a big advantage is side visibility. It didn't look like much of an advantage at day. But at night, it was like "WOW!!!"
That K-Lite Red, as far as I can tell (and I could be wrong), has exactly zero side visibility. Anybody can take a front light, slap on a red lens, and turn it into a taillight. But that doesn't make it a good taillight.
#62 ·
Azra, you are correct about the K-LIite, but I still think it would be a very useful "back up" tail light to the DS-500 for those who happen to be running a dyno lighting system. When I commute to work, I always run 3 tail lights in case of failures. Although I've yet to see either the K-Lite or DS-500 in person, I've come to the conclusion (based purely on what I've seen & read on the net) that the DS-500 is most likely the best bicycle tail light on the planet. All it needs now is to show it's reliable & robust to fully de-throne the Dinotte.
#60 ·
BTW, the DS-1300 front light also has side markers. Some black tape is included so you can cover them if they bother you.
They didn't bother me at night, and the added safely is certainly welcome.
But there's something else. That light on the side can be used to illuminate a computer. I'd just have to carefully position the light and my powertap computer and I could see my watts when I train at night. :thumbsup:
#61 ·
Hey Guys,
Just throwing out some info here .... I will be getting Peth's helmet mount tomorrow (assuming the UPS plane doesn't fall out of the sky tonite).
By the end of the week I should have some preliminary pictures and reviews up for the MTBR crowd.
I will be swapping some lenses around and reporting back to Peth so he can put the information to good use. Of course, everyone here will be able to read the reviews as they go. I will also be taking pictures of the the multiple beam patterns & intensities in order to provide information. My goal is to try to take some "on the trail" shots rather than "in the back yard" in order to present a realistic picture of what this light is doing.
Please take note that it will take a few months in order to give a comprehensive review and additional pictures. Not exactly dark "early" yet.
Peth .. your wafer thin silicon gasket idea is really good! I will still have my local machinist friend look at how an o-ring gasket can be incorporated for the lens. But your solution sounds much easier.
Matt ... you are correct about beam pattern being subjective. And I understand/agree that a smooth transition is nice. But if you're bumping your way thru the woods at night, I doubt there is any chance you'll even notice the semi-abrupt transition in pattern. I do not have, nor am I buying a vid camera for everyone's enjoyment. :)
I'll keep everyone posted here and in my appropriate thread.
#70 ·
I have noticed this on my DIY helmet light which have Regina reflectors (wide-ish spot, spill at ~1/2-1/3 of the intensity, similar to a MS beam with out the dark ring off-spot), where your eyes adjust to the brightness of the spot, then struggle to see something just outside it. It's not that much of an issue on a helmet light, as you just move your head slightly, but I wouldn't want it on my bars, hence the optics in that light.
Again, I ride fairly open but extremely rocky singletrack where I'm looking at stuff from 2ft to 50ft away. If I rode very tight densely wooded singletrack, it wouldn't be as much of an issue. So, in addition to personal opinion, there's also riding conditions to consider :)
#71 ·
Until Azra has a chance to respond, I thought I could add a pic or two here.
I really do like the way the mounting arrangement turned out. Very solid, with easy quick release.
The seat post as well as either side of the seat stays is an option. Although the picture shows the light above the brakes, you can just as easily mount it below the brakes on the seat stay and the side emitted light will shoot through the spokes at night. Easy to lock down the aiming with a single 5/64" Allan.
Note that on the seat post option, the extender bar does have to be angle down like you see in the pic.
#72 ·
Waiting for UPS here ..... hurry up dammit ! :D
OldAus ... try blackmail. Take some pics of her and threaten to release them on the net if she doesn't let you get the tail lights. If she resists ... sell them and use that money to buy the lights. :lol:
Ha ha ha..... if only it were that easy :lol:
In my former life I used to think of myself as a hard bastard ;) . I've served my country in Somalia, Timor, Soloman Islands & Afghanistan where there were plenty of nasty people hell bent on trying to hurt me. But now.... I've got nothing :( Cause thesedays NOBODY scares me more than my wife!!!
#83 ·
Hi Azra,
I guess that I didn't make myself clear enough. My fault. I have no doubt the 500 is much brighter than the 400R. That's a given. I was simply interested in seeing a few pictures of the light mounted on your bike in the daytime with the light off. Is your bike in the witness protection program :)
Oh well....thank you anyway.
#85 ·
Thanks Matt, I always kind of skipped over the UIP mode, since it wasn't specifically called out for the "bicycle," but I'll check it out.
Finally got the lens comparison video annotated so you can see what's what...
Definitely watch at 720 full screen if you can.
#86 ·
ah. Threemode doesn't refer to the levels, but to how you switch between them. You always have to specify L5 (max drive current), then two out of L1 to L4. I have mine set up as L5=1.2A and Threemode (L1>L4-L5), so I cycle between L4 and L5 with a click, then L1 with a press. Trimode in contrast is Lx-Ly-L5, where "-" is a click, so to get from L5 to Ly, you have to go through Lx.
Matt, thanks for sharing this info in the DIY forum. I was trying to make sense of if all on the PDF Azra linked me to earlier.
3 mode is definitely how I'd like to have my lighting options set to - for both steady and flashing. Cheers mate.
#91 ·
Like Chromagftw I'm trying to get this straight. I think I understand what you're saying about the "threemode". That could work but this "Trimode" sounds more interesting. In trimode , you're saying you can just click to circle through the modes (?)....is that correct? Which Taskled drivers offer this option. My triple has 5 mode and duel mode but I don't think it offered any three mode menu that I'm aware of. Of course this light was built maybe two years ago. Anyway, right now I'm using duel mode and have it set on L5 and L3.
#92 ·
yup, trimode = each click cycles you between a mode. So L1 click L3 click L5 click L1
threemode = L1 click L3 click L5 click L3 click L5 press L1
all current taskled drivers have these options, but I couldn't honestly tell you when George started implementing it. I know it was before the b2flex came in, as some of the later bflex drivers had it, but other than that I'm clueless. If you can open up the light, take a pic of the driver and email it to George, he'll let you know quickly enough.
#98 ·
Thanks Matt. Years ago I complained that the Taskled drivers didn't offer a three mode option. I guess George must of heard my whining and did something about it. Odd though that I'm just hearing about it now.
Years ago I used to use a Dinotte 600L which had a circular pattern three mode. I absolutely loved it but like Scar mentioned, sometimes you forgot what level ( mid or high ) you were in so good point made by Scar. At least with the 600L it also included a rear led indicator that blinked at different rates for the different mode levels. That came in real handy at times. I still consider the 600L the best made light I own. Sadly Dinotte chose not to upgrade the 600L with XPG or E. Currently I'm using Kerry's "K-lite", triple XP-G with remote. I really like this light. I just might have to contact him to see if he has a model using the newer drivers. If this "Design Light" can be used in any 3 mode pattern that is a great selling point.
#93 ·
Out on the trail, Tri-mode did not work for me. Seems like not matter how bright of light you have, you are looking for more, clicking for that next level. Going for high back to low can be scary in certain situations. In three mode you are just cycling between med and high, then when you truly want to drop down to low then just hold the button.
#94 ·
Excellent point scar...
So does nobody use multi-mode? I guess I've been using it long enough that it just feels natural. When you're "looking for more" that last click just gives you a confirming flash that you're there. On the trail, I'm wondering if there is ever a need to switch to lower power levels very quickly?
#97 ·
I find that the issue isn't that I want to drop to low (which I only do when stopped), more that I often don't have the time to cycle through med to get to high. This was a major issue with a Lightbrain powered DIY halogen I used to use and sometimes I can't even take my hand off the handlebar to switch my helmet light from med > high.
I use med for climbing/ extending battery life and high for everything else, so going through L1 would be a pain. Still, at least with the *flex drivers you have the option to tailor it to what ever you want!
#99 ·
Poor pethelman, he's probably going bananas now with everybody specifying different lens combinations and driver modes and all. He must be thinking, "What's next? Are they gonna make me anodize the light in a custom color? Why'd I start this project in the first place?" :mad:
BTW, my next DesignShine, I want it in pink with white flowers, please. :)
#101 ·
One step ahead of you, Azra.
I'm sure I'm driving him crazy with the lights/lenses. I'm hoping to have the preliminary pictures up over the weekend at this point.
He already said "no" to an acrylic green lense cover. :sad: Since I am a big Green Lantern fan, I wanted to cast a green light as "homage" to the character.
I'm pretty confident once I post up the pictures of the lights and their beam, that he will be able to narrow down some options. I'm also trying to keep him in the loop for a modification that I am planning. It may or may not be of any use to him --- but I've decided to punish him by involving him. :lol:
#102 ·
Hey Azra.....
Still waiting for those pics you promised :rolleyes: You seem to have a very aggressive personality and not afraid of trucks flying by at 60 mph, yet you're afraid to post a few pictures of the light on your bike. What's up with that :confused:
btw....do you have any knowledge of why my last few posts went missing ?
#103 ·
Hey Azra.....
suba, might be an idea to back off. If Azra wants to post pics, she will do. If she doesn't, she won't. There's no great conspiracy. There are enough pics of these lights on bikes for you to get an idea of what they look like, if they're not good enough it's unlikely Azra's will somehow satisfy your needs.
You're already starting to come across as a bit of a troll/ stalker/ harasser - don't make it even worse.
#104 ·
mm...
No, I'm not a troll/ stalker. There's something wrong with all of this. Azra doesn't speak or act like any female I've even known. This is the inter webs, where people can pretend to be anyone they want. I have my doubts Azra is a woman. If she is she's someone I would never want to meet.
I'm out of here. You guys can fall all over her ( or him ) but not me.
Everyone have a nice day... :)
#110 ·
Do yourself a favour and leave this thread. Unsubscribe, ignore, whatever, but don't bother reading it or posting in it any more. It was funny at first, but now its just sad. Stop harassing Azra, whatever Azra is, should not matter and you are getting annoying.
Nobody here is falling over anyone, we just interested in the product and the comments of people that have had first hand experience with the light.
Your complain about your posts disappearing , but i still see them all, i just wish i could hide them as they serve no purpose in this discussion.
#105 ·
who cares if Azra is a chick or not? This thread is about bike lights for Pete's sake and your only contribution has been to demand pictures of her bike, propose that her/his/it's refusal to do so is some kind of conspiracy, call into question her/his/it's sex and then start making aspersions as to her/ his/ it's character.
so sum up for me the value that you've added to this thread?
#109 ·
oookay. So, repeatedly harassing someone for pictures of their bike, calling it a conspiracy when they're not provided, then saying that they're an aggressive "man pretending to be a woman on the internet" is independent thinking?
Wow, just wow. Now I realise what I've been doing so wrong my whole life.
