I just got me a DesignShine taillight... and it is astounding. I never though I'd see such a thing, but somebody has just bested the venerable DiNotte 400R. I put them side by side outside, the difference is plainly visible.
I'll post a video shortly, but first I have some work-type work to finish, a very unfortunate circumstance. I'll get to play with my new toy this afternoon.
I also got the DesignShine front light. But I can't really put it to work until it gets dark.
More in a few hours... including a waterboarding. :arf:
oookay. So, repeatedly harassing someone for pictures of their bike, calling it a conspiracy when they're not provided, then saying that they're an aggressive "man pretending to be a woman on the internet" is independent thinking?
Wow, just wow. Now I realise what I've been doing so wrong my whole life.
Like I said, the front light is mine, I paid for it. The rear one is not.
Am I crazy to waterboard my own light? ut: Well, I want to know that the darn thing will work next time I ride in a downpour. If it's not waterproof, f*** it! I don't get to choose when I get caught in bad weather, neither should my light.
interesting. glad to see a mix of XP-G and XR-E on the front, should make for a good mix of spot and flood. Don't know why he didn't just use 2 XM-Ls though - the optic/ reflector options for the XM-L at that size are far better than for small triples. Hope it makes a good run of it!
Just a point of clarification...
One triple is an XP-G
while the other is an XP-E
The XM-L actually didn't exist at the time I was finalizing the design. The XM-L triple is coming, however, in the same way that the XP-G creates a wider beam than the XP-E for the same optics, this will happen again for the XM-L. So the improvement over the XP-G may be minimal with the 20mm triple optics. I agree that the larger single optics and reflectors are a better way to go for the XM-L. One of the design aspects was to be able to actually use the light that escapes out the side of the optics, so the triples fit the bill nicely for that.
Full disclosure - I'm the "guy in the garage" designer of these lights. My intent for posting was just to clarify some details and answer some questions.
Well, yes, the rear light is something Satan himself would use. I ride on the roads in an urban/suburban environment all the time and get buzzed within a few inches of my life by cars going 40-60 mph. I need something that will jolt those stupid drivers out of their cell phone/texting stupor. If it blinds them in the process, so be it.
The light has 5 intensity modes, BTW. And DesignShine is adamant the brightest mode should not be used at night. Will see...
This is the video - side by side comparison of the DiNotte 400R and DesignShine DS-500 taillights.
Video was taken at 2 pm. Very bright sunny day. In these conditions a normal $25 taillight would be totally invisible. But these are not normal taillights, these cost $200+.
The video was taken with a cell phone and is unedited. It is not entirely true to reality - the DiNotte 400R is quite a bit more visible to the eye than you would think watching the video. I think it has something to do with the flashing pattern of the 400R and the frame rate of the video. But the DesignShine DS-500 really is that much better.
Note that both lights come short when viewed from the side. Again, the DS-500 is better at a 90 degree angle, but not as good as I would like.
A word of caution:
It does look like the DS-500 is eating the 400R for breakfast, doesn't it? It really is that much better. But the 400R is a phenomenally well built and reliable little light. It is not a gold standard for nothing. The DS-500 still has to prove itself in everyday use. Ask me again in a year if I still think the DS-500 is a better taillight.
This, hopefully, should take care of the video frame rate. Both lights are in steady mode, brightest setting. Both are excellent, but the DS-500 is quite a bit better. There really is no contest there.
Wow, I really wish I had heard of DesignShine before I bought my Magicshine. Yeah, its about 1/2 the price, but the beamshot comparison between the two is astounding! If I ever get into night riding in a serious way, I will be buying one of these lil bastards!!
Thanks Matt, I REALLY appreciate your ideas and comments on any possible improvements. I'm about to ship my first light for a helmet-mounted off-road-only MTB application. He's said that he intends to write up a review here (MTBR) on his experience, which should be interesting. When I last checked, the single XM-L 20mm optics offerings from Carclo were a couple of mms taller than the triple optics and required a holder, so I couldn't use them with the current design. I'd be curious to see the spec dimensions on the LXP-RS. So who's the supplier of choice for the Ledil optics? Newark?. Thanks again.
Last time I checked, the Laura RS (I'm assuming the LXP RS is the same) was 12mm from base of holder to top of optic. Although they come with a holder (I use them after cutting screw/ solder pad cutouts) they optic itself is easily removed and lots of builders (Troutie for one) on the DIY forum machine a lip on their housing for the bare optic to sit in at the right height. Laura RS are from Newark and you can get LXP RS from Digikey.
I don't know what driver you're using (boost I'm guessing? Maxflex?) but if you were interested in a twin XM-L helmet light, the Lflex running off a 2S pack would be ideal. Max drive of 3.5A, all the bells and whistles (temp monitoring, battery warnings, different user modes) of the bigger drivers but smaller (20mm) and cheaper ($25). I'll be ordering one soon to make a single XM-L light for a friend so no first hand experience, though I've used b2flex and h6flex drivers to great effect.
If you want more advice (and better quality too, I'm still new at this), jump on over to the DIY light forum, they're very helpful and friendly.
Oh, and just to clarify one more thing...
The Magicshine 2-cell packs (8.4V) work fine with the taillight (with a minor programming change to the controller).
But the 2-cell is really pushing it for the headlight (read not recommended) since the internal drive voltages are so high. Better to go with the 11.1V (3 cell) for the headlight.
Chromagftw, thanks for the link to the beam shots. Very impressive they are. I do have some questions for the builder....Mr. Pethelman, very well done I do say. What degree/brand optics are used? For the battery, why not a 14.8volt? About the driver, can it be programed for 3 or 4 mode operation and how do the modes change ( circular or up/down ) ?
Any now the big question: Is there any way to buy one with a remote? ( custom order? )
I'm going to play the devils advocate why give beams shots comparing it to an old p7 magicshine?
wouldn't a more realistic comparison be made between maybe a Bikeray4 . That would be more apples to apples.
I like the look of this light might have to pick one up just to check out:thumbsup:
As shipped, the thing has 5 steady modes, 5 flashing modes, and one button to control all that complexity. Personally, I didn't like it at all. It's too complex and too confusing. But that's me. Somebody else may like it.
But it's possible to reprogram the thing into something a bit simpler. I found the manual for the maxFlex5A online last night and I reprogrammed my light - probably to Mr. Pethelman horror. Just imagine what damage I can do now... like crank up the current to 2 amp and get 2000 lumens out... muhahaha! :devil:
Anyway, I got my light in duomode - steady hi/low, flashing hi/low. I like it much better now.
It's not possible to completely customize it - you just get to select from a number of preset modes.
Rakuman - yes, I agree with you, comparing the DesignShine to the old MS is not entirely fair. Comparing it to the BR IV would be more meaningful.
And that's exactly what I've done last night. I want to ride some more with the DesignShine before I comment further. But based on one short ride, I found this:
- The DS puts (rated at 1300 lumens) puts out more light than the BR IV (allegedly rated at 1500 lumens).
- The DS has more throw.
- The BR IV may have a little bit more flood, but not much.
Anyway, I want to ride again tonight and then I'll post some more impressions.
In response to your questions...
Carclo optics.
One thing that I particularly like about these lenses is that there are a lot of options. "Azra" is using the spot-spot combination, which may be the best combination on the road. Certainly good for off road as well (it's what you see in the beam shots), but now that I've tried one, I would probably replace the spot lens on the XPG side with the narrow-frosted lens for off road, which adds a little more width and completely fills out some of the peripheral darkness that you can get with two pure spot lenses. If you have a low to the ground application, like a trike, then dual elliptical lens work fantastically well for that.
As far as the 14.8V supply... Yes, this works just fine with the Maxflex and the series connection of LEDs in the DS-1300. The only thing you would give up is the lowest power levels for a while with a fully charged pack, which is probably a non-issue. Mostly, the 11.1V was chosen as the best option to run both the headlight and the taillight (both using the Maxflex controller).
The Maxflex does provide the ability to remotely locate a power switch without any electrical issues (i.e. noise causing false signals), and I can do this as a custom mod. Just requires an extra hole drilled in the back of the case. I've done this for a recumbent with the light way out front and the switch back on the handle of the under-seat steering. The case-mounted switch still remains functional, since it's simply in parallel with the remote switch.
Yes. 14.8V can be hooked up directly and the light will operate just fine. The only negative is that you can lose a couple of the lower power levels (L1, L2) for the headlight with a fully charged pack (16.8V). HOWEVER, if you want the light to to give you any kind of battery status indication or perform an automatic shutdown prior to the battery pack itself shutting down when it trips it's own low voltage protection (assuming it has this function), then you would need to enter in the appropriate voltage levels into the flash memory on the controller via the menu-driven programming structure that is accessed through the power switch.
The taillight is a different story, and 11.1V (3 cell) packs is as high as you can go with that one.
Since we were on the topic of discussing optics...Out of curiosity, I took a couple of additional beam shots comparing triple optics combos.
For reference, the fence posts are 8 feet apart. Standard MTBR settings. The narrow frosted on the XPG does a pretty decent job of smoothing out the edges, while the XPE spot maintains most of the throw. All shots are with the light on Level 5, 700mA drive.
Well, sure. But the shipping would eat you alive if you decided to return them.
I'm actually about to ship a set out to a guy in Semaphore (Adelaide, South Australia) and it's going to cost around $45 to ship insured from the US. If you were anywhere close by that location, maybe I could put him in touch with you and he could give you a "demo."
One last word on the taillight: I agree with DesignShine that level 5 is too much at night. But it's great for the day, especially in inclement weather conditions like a bad summer rainstorm. Or when you are riding into the sun and you are afraid some idiot will hit you from behind because they are blinded by the sun and can't see anything. Well, level 5 will outshine the sun.
My DiNotte 400R has been sent to the closet, I never thought it would happen. Sniff, sniff! :sad:
I was again riding tonight with both lights. It's 85 degrees and humid. While riding both lights stayed relatively cool. But the DS was noticeably less warm to the touch. However, when I stopped, both started getting hot at about the same rate.
I would conclude that the DS probably has more efficient air cooling.
After a few minutes the thermal protection on the DS kicked in and it went from Level 5 to Level 2. Very nice. Perhaps a little too conservative, I think thermal protection may have kicked in a bit too soon, but that's not a bad thing since heat is the enemy of longevity.
The BR IV on the other hand continued to shine in high mode and got steaming hot. I actually burned myself when I touched it. Eventually I shut it down because I really though it's gonna f* up the electronics inside. So, yeah, nice job Bikeray!
Now, to be honest, my BR IV has been damaged by water so maybe that's why thermal protection does not work. But water got in in the first place because the light has been assembled by monkeys and has a fatal design flaw to boot.
I did take a very conservative approach to heat management. I've seen what heat does to LEDs over time, so I wanted to gives these the best chance possible at a long life. Believe it or not, that little case has nearly 30 square inches of exposed aluminum cooling surface area, which is why it runs relatively cool with a little air flow. The thermal limit was set so that you could come to a stop on the bike for a few minutes without it dropping to the lower power level, but beyond that, it really does need to throttle back to protect the LEDs and electronics. One of the reasons this works so well is that the MaxFlex electronics, which contain the temperature sensor, are extremely well coupled (thermally) to the case via a custom aluminum part and high performance thermal compound. The LEDs are also extremely well coupled to the case via Artic Alumina.
There is such intense competition in the headlight market, and now with the Chinese cranking out tens of thousands of throw-away lights, there is ZERO chance of a custom USA-made light like this ever competing with the price of the mass-production lights. I do try to make up for it, however, with a level of quality design that should last a very long time.
The DS looks like it's putting out more light. In any case everything in front of the light looks much brighter because the beam is better focused.
The DS has quite a bit more throw than the BR IV. I can't really say how much more without taking measurements. But let's just say it's quite a bit more, but not wow more.
Now the flood. That one was puzzling me all night long. I was riding on a paved trail and kept switching from one light to the other. In terms of flood only, I couldn't really tell the difference.
Then I came to a twisty little downhill section following a bike overpass. I did that little twisty section back and forth a few times with one light, then the other. Result: it's clear that the BR IV was better.
Also, if I aimed both lights at a large empty field, it's immediately clear that the BR IV has quite a bit more flood.
But I don't ride on empty fields. And I don't ride that much on twisty trails either. For my purposes, and I'm a roadie, the DS with the spot-spot lens is perfect. If you ride off road, you may want a bit more flood.
The beauty of the DS is that Mr. Pethelman is hand-assembling them one by one and he can customize your light for you.
Edit: All this was with both lights on my handlebars. I haven't tried mounting the DS or the BR IV on my helmet.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
