 Originally Posted by Chromagftw
Stephen, nice vid!
Either your neighbors are oblivious to what goes on outside their doors OR they are very understanding. Break out the shades!
Thanks,
It was about midnight when I did the test, so I was hoping that everybody was asleep, plus I didn't have to disturb the setup mid-stream to get out of the way of any cars. I did kind of shoot in a hurry and "run away" if you know what I mean
 Originally Posted by pethelman
I couldn't out-run any combination, even on fast down hill (<30mph), but when you're really getting on it down a hill, level 5 just gives you that extra confidence.
I can confirm that. I was riding last night on a parkway. 4 lanes wide, flat/little downhill and straight - so very fast when you start hammering in the drops. And completely dark. BTW, it's totally illegal to ride a bike there, but I can't be bothered with rules and regulations.
Last time I was riding there was with the BR IV and I was wishing for more throw. Not so with the DS! Perfect.
3. I can see how the triple mode of operation may be better than the five-level (multi-mode) mainly due... blah blah
Ha! I told you multimode/superlock is way too complicated. But noooo, you won't listen.
 Originally Posted by OldAusDigger
1 x Radbot 1000 and 2 x PBSF (1/2 watt version).
Not bad for little blinkies but you will find the DS-500 in a totally different league.
But my wife still hasn't calmed down since I spent over a thousand bucks on my front lights.
Can't say I blame her. If I was married to some %@$@@! that's spending all his paycheck on himself instead of buying me chocolate, ice cream, tiramisu, and bike lights, I too would be f-ing furious.
No, seriously, try playing the safety card. Does she want to see you under one of those B-Double trucks?
 Originally Posted by suba
Azra,
Do you have any pictures of the DS-500 on your bike ?
Nope, don't have a picture. Could take one later. But mine is mounted pretty similar to pethelman's first picture.
It works fine, but personally I'd like it better on the back of my saddlebag (much cleaner look) - like my 400R. For that I'd need to drill a hole in the last cooling fin. And I'd need the hole to be threaded. So need to find me a machine shop, I guess.
Azra...
Could you post a few pictures of the DS-500 on your bike ?
I was interested in seeing a few pictures of the light on your bike. What's the big secret ? I think most people here would appreciate pictures on your bike. After all you started the thread.
This is the side view of the DiNotte 400R and DS-500 at night.
http://www.youtube.com/watch?v=Q7MLxEF9kRQ
On top is the 400R. Below is the DS-500.
Both lights are on the brightest setting.
Hi Azra,
I guess that I didn't make myself clear enough. My fault. I have no doubt the 500 is much brighter than the 400R. That's a given. I was simply interested in seeing a few pictures of the light mounted on your bike in the daytime with the light off. Is your bike in the witness protection program
Oh well....thank you anyway.
3. I can see how the triple mode of operation may be better than the five-level (multi-mode) mainly due to the mechanics of dimming the light. In the triple mode (low-med-high), clicking the button just cycles between the three levels. So if you're at high (L5), then it's nice just to do a single click to dim for oncoming motorists, rather than a press-and-hold
I use Threemode on my mtb lights (L1>L4-L5) as I find that L4 and L5 are where I spend most of my time, with L1 for trailside repairs/ not blinding friends etc. I use Duomode on my commuter light (single XM-L@1.2A, so ~400lms), though I never use the low setting.
Something that might be worth investigating is the UIP mode that Troutie told me about:
LFlex for XML and Li-ion
Sounds like it might be ideal for a road oriented version, although I don't have any experience of it myself.
Thanks Matt, I always kind of skipped over the UIP mode, since it wasn't specifically called out for the "bicycle," but I'll check it out.
Finally got the lens comparison video annotated so you can see what's what...
http://www.youtube.com/watch?v=SP8hD_OU6_w
Definitely watch at 720 full screen if you can.
 Originally Posted by mattthemuppet
ah. Threemode doesn't refer to the levels, but to how you switch between them. You always have to specify L5 (max drive current), then two out of L1 to L4. I have mine set up as L5=1.2A and Threemode (L1>L4-L5), so I cycle between L4 and L5 with a click, then L1 with a press. Trimode in contrast is Lx-Ly-L5, where "-" is a click, so to get from L5 to Ly, you have to go through Lx.
Matt, thanks for sharing this info in the DIY forum. I was trying to make sense of if all on the PDF Azra linked me to earlier.
3 mode is definitely how I'd like to have my lighting options set to - for both steady and flashing. Cheers mate.
just a Newbie
I like.
Only can a female bicyclist will mix bike lights along with chocolate, ice cream and tiramisu
no worries. It's not 100% fit and forget, but it might be of interest for the more savvy user.
you're welcome It took me a while to get used to programming the Taskled drivers, but once they're set, they're just awesome. The fact that they're what's powering the DS lights is an enormous plus in my mind.
Like Chromagftw I'm trying to get this straight. I think I understand what you're saying about the "threemode". That could work but this "Trimode" sounds more interesting. In trimode , you're saying you can just click to circle through the modes (?)....is that correct? Which Taskled drivers offer this option. My triple has 5 mode and duel mode but I don't think it offered any three mode menu that I'm aware of. Of course this light was built maybe two years ago. Anyway, right now I'm using duel mode and have it set on L5 and L3.
yup, trimode = each click cycles you between a mode. So L1 click L3 click L5 click L1
threemode = L1 click L3 click L5 click L3 click L5 press L1
all current taskled drivers have these options, but I couldn't honestly tell you when George started implementing it. I know it was before the b2flex came in, as some of the later bflex drivers had it, but other than that I'm clueless. If you can open up the light, take a pic of the driver and email it to George, he'll let you know quickly enough.
Out on the trail, Tri-mode did not work for me. Seems like not matter how bright of light you have, you are looking for more, clicking for that next level. Going for high back to low can be scary in certain situations. In three mode you are just cycling between med and high, then when you truly want to drop down to low then just hold the button.
Excellent point scar...
So does nobody use multi-mode? I guess I've been using it long enough that it just feels natural. When you're "looking for more" that last click just gives you a confirming flash that you're there. On the trail, I'm wondering if there is ever a need to switch to lower power levels very quickly?
The only time I drop down fast it is when I see oncoming cyclists or hikers/runners who might be sharing the same trail, provided I'm not going fast. It's really out of courtesy more than anything else yet i still find myself apologizing as I go by (does anyone else do this?)
On the trails, most definitely yes. Like Chromagftw said, when there's a bike coming the other way, you don't want to blast them with 1300 lumens. It's rude and it's dangerous to boot.
That's why I like the duomode. One click and I'm in L2. Another click and I'm back in L5. Simple.
I find that the issue isn't that I want to drop to low (which I only do when stopped), more that I often don't have the time to cycle through med to get to high. This was a major issue with a Lightbrain powered DIY halogen I used to use and sometimes I can't even take my hand off the handlebar to switch my helmet light from med > high.
I use med for climbing/ extending battery life and high for everything else, so going through L1 would be a pain. Still, at least with the *flex drivers you have the option to tailor it to what ever you want!
Thanks Matt. Years ago I complained that the Taskled drivers didn't offer a three mode option. I guess George must of heard my whining and did something about it. Odd though that I'm just hearing about it now.
Years ago I used to use a Dinotte 600L which had a circular pattern three mode. I absolutely loved it but like Scar mentioned, sometimes you forgot what level ( mid or high ) you were in so good point made by Scar. At least with the 600L it also included a rear led indicator that blinked at different rates for the different mode levels. That came in real handy at times. I still consider the 600L the best made light I own. Sadly Dinotte chose not to upgrade the 600L with XPG or E. Currently I'm using Kerry's "K-lite", triple XP-G with remote. I really like this light. I just might have to contact him to see if he has a model using the newer drivers. If this "Design Light" can be used in any 3 mode pattern that is a great selling point.
Poor pethelman, he's probably going bananas now with everybody specifying different lens combinations and driver modes and all. He must be thinking, "What's next? Are they gonna make me anodize the light in a custom color? Why'd I start this project in the first place?"
BTW, my next DesignShine, I want it in pink with white flowers, please.
I rode with both lights in light rain today and again in rain tonight. No problems to report... other than a mofo homicidal truck driver.
- You may not post replies
- You may not edit your posts
Forum Rules
