Results 1 to 35 of 35
    ballbuster
    Reputation: pimpbot's Avatar
    Dang, MJ808s are spotty! Alternatives?
    I decided to whip out my original Magicshines for a ride last night. My NR Dual 700 has been acting up with random shutting off. So, I have two Magicshine MJ808s, strapped to my bars with a Y-cord. I figure this can give me two side-by-side spots for a wider field. Even that wasn't enough to see anything on the trail other than... well, the hot spots right in front of me. I brought the NR D700 with me as a backup in my Camelbak since I had no idea of the condition of my MS battery.
    It was so bad, I just had to switch back to the NR light. Oh, and I have a Lumina 650 on the lid. That has a fairly narrow spot as well, but on the lid that works.
    So, what low rent Chinese light heads have a wider beam? I was looking at the SolarStorm, or the Gemini knock-off. I don't need a metric crapload of lumens, just a good beam pattern... and enough lumens.
    Then again, I reflowed some of the solder joints on the NR Dual 700, and it doesn't seem to cut off anymore. Maybe this is a non-issue. I dunno.... I'm still curious of the 2000-5000 (Chinese rated) lumen lights. 1000+ actual lumen would be fine. You could say I'm Chi-curious.
    ballbuster
    ... or, are those wide angle lenses worth anything? I see them on fleabay for $5. Might be worth it to try. I thought I read somewhere on these boards that it diffuses the light too much, and makes things kinda dim.
    Reputation: arphaxhad's Avatar
    dual 808's on my bars drove me crazy with their spottiness when I experimented with my 816 on the helmet. I solved the problem with a $5 wide angle lens for one of them. now I have a bright spot from one with a oval "halo" overlay from the other. I run them on my helmet as i put the 816 back on the bars, but still a cheap short-term solution.
    ballbuster
    Quote Originally Posted by arphaxhad View Post
    Swank! Looks like a good cheap solution... which works for me, being a cheapskate and all.
    because GIANT
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    if you can crack the lens of 'insert light here' and toss in about 1/3 full of aerogel granules (who doesn't have a jug of these sitting around? I have lots of it) you can turn any power-led into a smooth partial floody artifact free light. 90% of it settles to the bottom of the light head and static holds chunks around the orange-peel or relector and aerogel is completely translucent and improves the beam on many a crappy light. I am not making this up...I use it on my fast bike at night because it has the best beam of anything I ever tried.
    I learned the optical wonders of loose aerogel crumbs in my high power flashlight fixation. skyray king, thrunite TN11, Klarus xt11, and my McGizmo all have had experiments and optical tests done with various loads of aerogel in the head and I discovered 1/3 or 1/4 full bike light does a great jorb and doesn't harm anything and you can just dump it out if you don't like it.
    united nuclear can sell you a jug of aerogel crumbs. or if you have an old 'elite ' insulated water bottle (they use aerogel) go bust in a swipe a sugar-cube worth...worked GREAT for my Shadow BL21 single XML 3x18650 4.2 volt 800 lumen.
    So could a SASE and a couple of bucks get me some.....?
    because GIANT
    Nov 2013
    this one time to the first person asking, sure. pm sent
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    I think the $5 wide angle lens works great. Makes the 808 and it's knockoffs very usuable at night.
    For a more "floody" beam I like the Cree 3x lights.
    14 Aurum, 16 Fuse, 17 T130
    Quote Originally Posted by 127.0.0.1 View Post
    Nov 2012
    The 808 was too spotty for me as well. I bought this light, an 872 clone, that I used for 8 plus months and am really happy with.
    USA Stealth Black 1600 LM 4 CREE XP G LED Bike Light Light Head Only 872 A | eBay
    It's a nice flood light, that is also brighter than the 808e. I doesn't have the reach of the newer dual led lights, i.e Solarstorm X2, yinding etc, but it has a nice even beam.
    I paid around $32, but now they are down to $23. That's a crazy price! A couple of other guys bought them and liked them. Here's a thread about it:
    Good Chinese flood for bars
    The wide angle lens only expands light in one direction, which I didn't care for. The 872 has a wide cone, which I preferred .
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by pimpbot View Post
    Put one of the lights on your helmet.
    Spots are marginal on the bars, especially without a helmet light. But on the helmet a spot works great.
    I have been using an 808 on my helmet for many years. Have a higher lumen MS on the bars with a flood. It is less effective than the 808.
    mtbtires.com
    ballbuster
    Quote Originally Posted by shiggy View Post
    Gotcha... but I already have my Lumina 650 cordless on the lid. I hate having my lid tethered to my body. For a while, I used my MJ808 with a 2 cell homebrew battery pack I strapped to the back of my lid. I'm using the NR MinewtX2 Dual 700 on the bars, and that is nice and floody while also being able to kick out enough light to see what I'm doing while going fast down a hill. IMO, the beam is much nicer on the NR stuff, but yeah... at 4 times the MS price (at retail, but I got this at an REi Scratch and Dent sale for $50! ).
    I like having two lights on the bars. I can just reach down and point them to suit conditions better... on the fly.
    I'll probably end up keeping the MS light as a backup lights, or buddy lights.... or just sell it. I haven't decided. I was looking for a way to make it more useful. At almost twice the lumen of my NR light, I was still able to see and ride better with the NR light. I'll get one of those wide angle lenses and see how that goes. It's only five bucks. Hard to lose at that price.
    I don't think this is a case of 'get what you paid for', but more of a case of 'right tool for the job'. They just chose to make the focus too tight for my use on the MS light.
    I like turtles
    Reputation: TiGeo's Avatar
    I run 2 808s and use the wide angle lens for the bar one...works well..I have no trouble riding fast. Does tend to dim it a bit but I use an older version (P7)..I am sure if you used the newest version it would be fine. Back in the day I ran 2 lights on the bar with one on the helmet..these were the older halogen deals. One bar light was a flood and one was a spot..worked well as I remember in combo with a spot on the helmet.
    Sent from my SCH-I545 using Tapatalk
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    I like turtles
    Here are some beam comparo of 808s with the standard and wide-angle lens. These are older models, but the effect should be the same on the newest gen of this light. To reiterate, I think the spot on the standard lens is perfect for a helmet light as you are trying to see (at least I do) way ahead and around corners. The wide-angle (aimed downward) works fine for the bar, but is a little dimmer than I would like due to the way the lens disperses the light...just needs more lumens and it would be fine.
    Attached Thumbnails Attached Thumbnails Dang, MJ808s are spotty! Alternatives?-808_comparo.jpg
    because GIANT
    Nov 2013
    I think I am the only nutjob out there who knows and raves about the optical qualities of aerogel. but damn if it doesn't work awesome.
    https://unitednuclear.com/index.php?...products_id=89
    aerogel in a light head pictures, flashlight.
    note: these first two pictures the light is off. that glow is how aerogel captures ambient light and bounces it all around the reflector
    compared, both pictures 750 lumen XML-U2 thrunite tn11
    no aerogel, you see the tn11 is mostly a thrower
    aerogel diffuser, tn11 becomes Mr. Floody
    (this is 100% filled, on a bike light it would be 1/4 full so aerogel crumbs sit at bottom area of lens and reflector, and some crumbs stick via static around the reflector...more throw vs flood as a result)
    Is that small bottle (120cc) enough to do a single light? I have a 3X that I would love to make the lower emitters flood without losing output and this sounds like just the ticket. And at 5.50 is worth a try. Any idea what shipping is?
    because GIANT
    Nov 2013
    Quote Originally Posted by robs31 View Post
    dunno about shipping and yes...small bottle would be ok ...you really only put a teaspoon in there, if that. light that hits the bottom 1/4th bounces everywhere providing some flood without blocking throw...sort of like a partially frosted lens
    here is my Shadow BL21 as i ride it today. so maybe a bit more than 1/3 full and you can see some random bits stuck by static. those help diffuse and wash out any artifacts as well as the bottom pile which adds flood without nuking throw much at all
    thing about loose aerogel is no matter what angle you mount the light the 'frosted' part will always be down, as aerogel does want to pile up at the bottom...self regulating so to speak
    hey it works for me and it works even better since the concept is oddball to begin with
    I initially thought, gee this will be weird actually riding with the bumps and chatters messing with the beam...umm, nope. I don't ever see any artifacts in the beam...
    Reputation: s0ckeyeus's Avatar
    Quote Originally Posted by varider View Post
    I have that exact light. Mine wasn't constructed particularly well. The switch wasn't aligned correctly, the back wasn't tightened, and the lens was loose. I had to take the lens out and install an O-ring behind the refector assembly so it didn't rattle around. The internals looked decent to my untrained eye. Still, not bad for $23. It's definitely not spotty.
    They have three shipping options, cheapest is 5.40. For 10 bucs I'll give it a try since I cant find any diffusion lenses in the size I need.
    First ride last night with my aerogel'd 3X and all I can say is WOW! I filled the lower two lenses and left the upper lens empty. In my opinion this changed the light from a so so bar light to the perfect bar light. Lots of flood close in with a smooth transition to the less hot spot throw. The beam is almost a triangle in shape when viewed on the fireroad. It used to have a dead spot between the floody halo and the hotspot, but no more. Just a perfect transition from near to far. I'll have to try some in my old 808 clone and see what that looks like.
    Darn Robs31, you beat me to it! I got my aerogel a few days ago and havent had a chance to put into my 808's yet. I'll try to beat you with beam shots...
    I like turtles
    Looking forward to the 808 beam shot.
    So I was able to get some beam shots tonight of the 808 with and without aerogel filled to different levels. All photos were taken with it on high using the MTBR settings. Pool filter is at 30', end of sidewalk 60', fence at 90' and block wall approx 180'. Sidewalk is about 5' wide.
    First is the 808 T6 clone with the wide angle lens.
    Next is clear lens
    Next with 25% Aerogel fill
    Next 50% fill
    Next 75%
    And finally 100%
    I'll also throw in my 3X Stepless XML2 U2 with lower two lenses filled. The upper lens has a little aerogel in it also so I need to take a little out to get some more throw back.
    And last is my Yinding XML2 T6 3B with no mods.
    I like turtles
    Wow...that Yinding is BRIGHT!!!
    ballbuster
    Wow, that thing is bright! I'm super tempted to blow the $34 on the Gemini Clone head only. I have batteries and chargers already. I really should be saving for some carbon rims, tho.... I already have a lot of good working lights.
    Feb 2014
    Try Mtigersports MT-3000 35dgree light beam.....?
    Reputation: ironbrewer's Avatar
    Oct 2012
    Can you say what the price will be in the US?? Is it available light head only??
    Reputation: garrybunk's Avatar
    Feb 2014
    Wow that Yinding is SWEET! Love how much better things pop out from the neutral white tint! Is it just me, or does the wide angle lens seem to do a better job than the aerogel? The aerogel seems to kill more throw than the wide angle lens does.
    I just picked up a SolarStorm X3 head only on EBay for $25 shipped. Seller had quite a few listings with no one bidding on them! He also sells the SS X2 for $17 Buy It Now which I was really tempted to pickup as well and play with different optics.
    -Garry
    Nov 2012
    Quote Originally Posted by garrybunk View Post
    -Garry
    which seller? That's a great price on the X3
    Feb 2014
    Seller Jingle-Shop (see Ebay Store here). I don't see any more SS X3's up for auction now. The SS X2 B.I.N. for $16.99 is here. It's "head only" and shows XM-L2's in the photos, though the phillips head screws have me suspicious about being "genuine" (though the X3 has phillips heads too).
    Seller "marked as shipped" and provided me a tracking numbers within hours of ordering too.
    In the meantime, DX is having trouble fulfilling my order with the Pannovo battery case I intend to use with it.
    -Garry
    I wasn't going to buy one, but the white roses and sparkly diamonds in the description convinced me.
    (Actually, my wife probably wouldn't be happy if I bought another light, even if it was just $16.99. Looks like a good deal though.)
    Nov 2012
    -Garry
    Thanks Garry.
    I think the phillips head screws may be a sign of a cheap clone, so I would hesitate buying one. Thanks though.
    -Garry
    If you look at the gate (90') you can see it better in the aerogel photo's than the WA. You can also see beyond the gate better as well. For me the goal was to smooth out the transition between the flood and hot spot so the hot spot didn't overwhelm the eyes and make everything else seem dimly lit. You just have to play around with it to find what your looking for.
    Feb 2014
    That same Ebay seller (Jingle-Shop) has had more of these SolarStorm X3's (or clones thereof) up for auction cheap with no bidders again. They seem to end on Mondays. Only a few minutes left on a couple of them like this one.
    By the way, mine is already in the US! Less than a week from China to New York.
    -Garry
    Feb 2014
    For those interested in following, I received my SS X3 today. Posted about over here in the SS X2 thread.
    -Garry
  1. Dang it!
    By schnauzers in forum Passion
    Last Post: 05-17-2013, 12:19 PM
  2. Dang....never saw a fatty like this....
    By jeffgothro in forum Off Camber (off topic)
    Last Post: 04-26-2013, 02:40 PM
  3. Dang it's hot out there
    By randyharris in forum Arizona
    Last Post: 08-18-2011, 10:02 PM
  4. Wtb medium aņo grey spotty frame
    By roverdoc in forum Banshee Bikes
    Last Post: 08-15-2011, 07:19 PM
  5. Dang! Wish I had the cash for this...
    By hfy108 in forum Arizona
    Last Post: 08-01-2011, 07:00 PM
