Results 1 to 7 of 7
    jsg
    jsg is offline
    desk jockey
    Reputation: jsg's Avatar
    May 2005
    Charger for GM 6.0 battery
    Will my existing chargers from the recalled batteries work on the new ones? I had no issues charging the original GM batteries (I had one if each) but now I have the new 6.0s and the charging light does not change when battery is plugged in.
    It should work. Contact Geomangear. They have replaced chargers that don't work with the new batteries due to the voltage being slightly out of spec (or something like that).
    Reputation: Rakuman's Avatar
    I have a bunch of 6.0 battery's and one of them did this plug it to your light for a minute and run it on high then try to charge it. worked for me. I had this happen before with another new battery different brand and did the same thing and it worked , give it a try wont hurt
    I always type in bold cuz I'm blind as a bat
    For the Rich there is therapy!!!! for the rest of us we have Mountain Biking
    There are inconsistencies in the male/female plug length/depth between chargers and lightheads. My newer charger works with all batteries. My old charger from the first generation MS900 works only with older (recalled) batteries.
    It's a circuit continuity issue, not voltage. Well, I mean 0 volts...
    jsg
    jsg is offline
    desk jockey
    May 2005
    Geoman sent a new charger, thanks Geoman for your awesome service.
    VENI VEDI BIKI
    Reputation: skankingbiker's Avatar
    I want to get a second charger. The only chargers I see on their website are the Magicshine US chargers. Do these work with the new 6.0 batteries?
    Quote Originally Posted by skankingbiker View Post
    yup
  1. 4S battery charger / balancer?
    By piesoup in forum Lights DIY - Do It Yourself
    Last Post: 12-24-2009, 02:26 AM
  2. DIY Battery & Charger help
    By toonarmy20 in forum Lights DIY - Do It Yourself
    Last Post: 11-11-2009, 01:21 PM
  3. Battery charger question
    By cowens677 in forum Lights DIY - Do It Yourself
    Last Post: 01-16-2008, 07:30 PM
  4. Solar Battery Charger???
    By Ultra Magnus in forum Lights DIY - Do It Yourself
    Last Post: 09-14-2007, 03:29 PM
  5. 12v, 4000 mah Ni-MH battery w/ charger $30
    By iamnate in forum Where are the Best Deals?
    Last Post: 03-30-2004, 03:16 PM
