    can I reuse cells from my gemini packs in panovo case?
    Been having pretty significant power loss on all my 6 cell gemini packs. These are the s"special" 8400? Mah versions that came with the 8.7v charger
    They probably have about 100 charge cycles on them and at first I thought that the loss of capacity was just cold weather related which I know it is partly but im thinking they are going out of balance. The 6 cells seem to be hit harder than all my other batteries
    My question is, if I purchase these panovo holders and nitecore intellicharger can I restore them and get some more use from them?
    I wasnt sure what cells they use other than that they are panasonic
    Figured it may be worth a shot but I know very little about batteries nowadays
    Also if this makes sense, is there an effective way of removing the spot welds
    Thanks in advance
    Nov 2012
    It is better to use protected cells in pannovo since it doesn't have protection. This case would be better http://www.kaidomain.com/product/Details.S021564 - it comes with protection, but the threads for screws are easy to tear off Nitecore charger is a good choice.
    Quote Originally Posted by MK96 View Post
    Thanks for clarifying, I wasn't sure if the panovo had some sort of pcb or not so knowing that the type that you linked seems a good alternative. I will probably leave the cells in to charge normally and only pop them out once a month or so to throw on the nitecore. As you said, the screws seem to be a weak point
    Do you think the problem with my current packs is balance related? Seeing as how the 6 cells seem to be affected the most and they currently last about the same as my magicshine 4 cells, im thinking that could likely be the problem
    Nov 2012
    I can't say it for sure, you need put the pack on a balance charger with data logging for discharging to see what is happening and estimate the capacity of the pack or use another way to estimate the capacity for a single cell. There might be a cell issue, balance issue, PCB issue ... If you can take the cover of the pack away and measure voltage each cell should hold the same voltage.
  1. need some schooling on PCB for unprotected cells.
    By machine4321 in forum Lights DIY - Do It Yourself
    Last Post: 12-13-2015, 11:35 AM
  2. Reuse your chemical toe/hand warmers
    By brebla in forum Fat bikes
    Last Post: 12-02-2013, 02:17 PM
  3. How to for installing new cells in the Geomangear warranty battery packs?
    By rideit in forum Lights DIY - Do It Yourself
    Last Post: 09-12-2013, 12:44 PM
  4. Reuse or dispose brake fluid?
    By bank5 in forum Brake Time
    Last Post: 08-28-2011, 05:29 PM
  5. After flat, reuse tire and tube?
    By egocycle in forum Wheels and Tires
    Last Post: 04-24-2011, 12:55 PM
