    May 2012
    Broke my o-ring mount
    Hi everyone,
    I had my light mounted to my bars and went OTB the other day and broke the plastic mount that holds the o-ring. I can't seem to find a replacement. I want to now mount it to my helmet (to avoid this problem to begin with), so if there is a good hack I'll listen to that idea for sure!
    The light is just one of the cheap MagicShine China knock-off, T6 Cree deal.
    Aug 2013
    Quote Originally Posted by mvwmvw View Post
    Hi everyone,
    Handlebar clamp - $4.00 : Easy2LED.com, The store for LED DIY
    Magicshine Universal Mounting Bracket
    Aluminum Alloy Bike Headlamp Mount Holder w/ Silicone Rings - Black - Free Shipping - DealExtreme
    Perhaps, just use a piece of aluminium sheet with holes for light's screw and for velcro band?
    May 2005
    I have adapters that allow the use of the GoPro mount system on your style light. PM for info if you are interested.
    Keep pedaling
    Reputation: Furball the Mystery Cat's Avatar
    I have my light mounted upside down, under the bars. If the bars hit the ground in a crash, the light won't be damaged. It also seems less likely to slip when hitting bumps in that position.
    Action-LED-Lights - Replacement Mount for Magicshine
    Action-LED-Lights - MJ-6058, (MJ-880 Helmet Mount)
    Action-LED-Lights - PARTS/ACCESSORIES
  1. Direct Mount ring compatibility?
    By Shark in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-02-2014, 12:04 PM
  2. Lower Shock Mount Bolt Broke on 2011 5.Spot
    By Falldog in forum Turner
    Last Post: 05-09-2013, 09:06 PM
  3. Looking for an upgrade from an o-ring bar mount
    By mazspeed in forum Lights and Night Riding
    Last Post: 10-25-2012, 04:30 PM
  4. Replies: 2
    Last Post: 06-15-2011, 03:16 PM
  5. Broke my friend's XX brake lever mount...
    By bauhaus in forum Brake Time
    Last Post: 06-02-2011, 08:29 AM
