Results 1 to 20 of 20
    Reputation: fonarevka's Avatar
    Big Flashlight Comparison Test (Beamshot)
    You can see many flashlights in our beamshot comparasion in http://fonarevka.ru
    English Version
    Our project is independent and we are not sellers. Flashlights - this is our hobby!
    Video-Instructions for using the base test
    Image-Instructions for using the base test
    Trailer
    Please, feel free to ask any questions about this test.
    New dislocation (the scene) "Parking 3"
    There were brand flashlights are tested:
    ArmyTek
    Camelion
    Convoy
    DQG
    EagleTac
    Fenix
    GP
    JETBeam
    LIGHT
    LumensFactory
    MAXTOCH
    MONARH
    Maglite
    NEW-K9
    NITEYE
    Nextorch
    Nitecore
    Olight
    Preon
    Quark
    Quark-X
    Roche
    Shadow
    SkyRay
    Solarforce
    Spark
    Streamlight
    Surefire
    Trustfire
    UltraFire
    Uniel
    XENO
    XinTD
    Yarkiy Luch
    Trailer (Click Like in video )
    Jul 2013
    Wow!!!
    Reputation: mtbRevolution's Avatar
    Quote Originally Posted by fonarevka View Post
    Hi Fonarevka, I've seen Kir and you around in the Velomania.ru forum. Welcome to mtbr. What are your camera settings? ISO setting and exposure time?
    You have quite a collection of torches. In your collection, which torch has the longest light throw?
    Leonard - All things Xeccon + Beyond
    mtbRevolution.com
    Quote Originally Posted by Xeccon View Post
    Our default settings for beamshots are ISO200, F/3.0, 2s and 8s, WB: daylight
    In "Road' scene WB was "cloudy".
    Nikon P5100
    Xenonics NightHunter One is the longest I think. Polarion PH50 is the brightest one
    New scene Parking 5
    tested:
    EagleTac
    Fenix
    Ferei
    Inova
    Lupine
    Nitecore
    Peli
    Petzl
    Spark
    Yarkiy Luch
    announcement
    Thanx for taking the time to do and share these beam shots with us. With all the work you are doing it isn't doing the beam shots any justice with the over exposure of the photos. For example,,, the piko on the high setting (1120 measured lumens) looks way brighter than the TM-26 I have (3500lumens),, and well the Betty-TL2 just looks like about a million lumens. Not trying to be negative, just don't like to see good work hindered. Cheers!!
    We test the flashlights on the two exposures 2 and 8 seconds, because participate in the tests.
    Yes,,, these seem much more realistic. Couldn't understand your 8second exposure reasoning on your next post??
    8 seconds - to flashlights < 60 lm, which are involved in the tests. For 2 seconds, with a small flashlight brightness will not be visible)
    Ok,,,, yes I see where 8 second exposure will benefit the low output torches so we can see beam shape etc.
    Flashlights Tests.
    February - 2014
    In the last weekend of February, the regular tests flashlights.
    65 flashlights were tested the following brands:
    Lupine, Lux-RC FL33, Roche, Convoy, XinTD, Sunwayman, Xeno, FormOptik, NiteFighter, SmallSun, SolarStorm, StrongLight, UltraFire, SingFire, NiteFire, RoadLeader, Speedwolf, Jexree, EagleTac, Nitecore, MagLite, Solarforce lights and number of modified from our members of the forum.
    Announcement here
    New scene here
    I applaud your effort to capture all the lamps for review but truthfully none of the beam shots that you supplied are going to help a person ( looking to buy a new bike light ) choose a lamp. You can't take photos inside a structure that has walls and a ceiling and expect this to translate to what is seen during actual use. There is so much light bouncing / reflecting around off the ceiling and side structures that it makes the lamps seem 3x brighter than they really are. So much light is bouncing around that you can't help but notice the light that is reflected "behind" the camera. In actual use you won't get that kind of thing happening unless you ride through a tunnel.
    Case in point; I own a Solarstorm X2 and the photo you show makes the lamp seem WAY brighter than it actually is. I don't know if this is due to just the "light bounce" factor or if your camera settings are just over exposing the photo's. Any one buying a lamp based on the photos you provide are going to be VERY DISAPPOINTED ( to say the least ) once they get their lamp and take it out for a ride.
    Any such tests Flashlight - a comparison between the Flashlights themselves.
    In the scene there are two Exposure: 2 sec. and 8 sec.
    Photos of self-other can not convey what he sees the human eye because of the camera matrix, differences in monitor settings, etc., but perfectly suited to compare the light of Flashlights together.
    As far as I know, all who chose flashlights to our tests (in the forums CPF, budgetlightforum, taschenlampen-forum and some others) were satisfied with the results, which helped to make the right choice.
    Flashlights often show different results under different environmental conditions. It is our goal to show how a flashlight shining in the narrow space or on the street, or other conditions.
    We shoot tests since 2006 and have accumulated sufficient experience to make our objective tests.
    Soon it will be warm and we will be able to carry out tests on the street (in the park)
    Exposure: 2 sec.
    Solarstorm X2 + A small reflection of light off the walls. On the street results will be slightly different because of other environmental conditions.
    About how he shone. Bright lights always look on Exposure 2 seconds. All tests were conducted on the same settings of the camera in order to maintain objectivity to compare flashlights together.
    Flashlights tests. April 2014.
    In the test, attended the brand Flashlights:
    Fenix, Nitecore, SupBeam, Spark Technology, Xtar, Olight, Sunwayman, Klarus, IWT (Videofon MV), Yarkiy Luch, Mag-Lite, Lupine, SureFire, Stella Aqua, StreamLight
    Video
    announcement
    Scene: Dendropark
    Flashlights tests. September 2014.
    Has been tested for about 70 flashlights following brands:
    VASKA (made in Russia), Fenix, Niwalker, NITECORE, JETBeam, ORCATORCH, Brinyte, Imalent, Armytek, Sunwayman, Zebralight, Olight, IWT Videofon MV (made in Russia), Spark, Convoy, Roche, XinTD.
    announcement
    Scene: Dendropark-3
    P.S.
    Previous tests published
    Scene: Dendropark-2
    NEW PROJECT
    LedCalc - LED Calculator
    on the datasheets basis:
    *calculates the luminous flux, power consumption and efficiency
    *builds comparative tables and graphs
    *calculates the current limiting resistors
    *helps to visually choose parameters for the Aqualab LED drivers database
    Tests headlamps. November 2014.
    From 15 to 16 November, another test flashlights, this time themed: Tests headlamps.
    110 has been tested headlamps following brands:
    Fenix, ZebraLight, Spark, Bronte, FOCUSray, Sunree, Crelant, Rayfall, Skilhunt, LedLenser, NiteCore, Peli, Petzl, VASKA, Surefire, Streamlight, Wolf-Eyes, Armytek, MagicShine, Olight, XTAR, Yarkiy Luch, Kosmos and some other brands.
    In tests participated custom headlamps from motogans, from Dsche, of Tamagotchi, and the headlamp from small-scale Russian producer VASKA
    Scene Info
    View new scene here (Parking 7 Headlamp)
    Announcement of the event here
  1. Is solar flashlight superior to normal flashlight ?
    By Alice2012 in forum Lights and Night Riding
    Last Post: 07-05-2012, 09:13 AM
  2. pliny test beer taste test
    By fc in forum The ReCycle Bin
    Last Post: 06-26-2011, 01:22 PM
  3. OT: DOA XM-L flashlight.
    By Dream Plus in forum Lights DIY - Do It Yourself
    Last Post: 03-29-2011, 10:09 AM
  4. suggest an LED flashlight for me please
    By srileo in forum Lights and Night Riding
    Last Post: 02-21-2011, 01:14 AM
