Best taillight?
Printable View
  • 11-20-2012
    Dr.Mushy
    Best taillight?
    I hope I'm not beating a dead horse here but what are your favorite tail lights? This time of year it's mainly gravel with a touch of pavement. I've been impressed with the output of my Planet Bike blinky light with the clear LED in the middle but their reliability has been a little disappointing. I am extremely paranoid about being seen (might have something to do with getting hit by a car this summer in the middle of the day!) I have been running approx 700 lumens in front.
  • 11-20-2012
    trhoppe
  • 11-20-2012
    Dr.Mushy
    I had a Planet Bike Superflash taillight break loose from it's outer mount and I had a switch that quit on another one To the mounts credit, when it broke I was on an extremely rough level b road on an unsuspended bike. I am currently running one like the light off Amazon on another bike and it's been good. It's really bright.
  • 11-20-2012
    Cat-man-do
    Although I no longer use them because I have brighter; I've used the PBSF before without any problems at all. I liked the first one so much I bought a second. I found all of the mounting hardware to be rock solid. When you slide the lamp into the mount there is an audible "click". That pretty much locks it in ( until you press on the plastic release just under the mount.
    Also odd that you would have a malfunction with the light internals. While not the brightest of rear tail lights currently available, the PBSF set a new standard when it came out ( some years ago ). If you can find a better made light, buy it.
  • 11-20-2012
    manbeer
    I've been running sans-tail for a while now
    When i first got into night riding in middle school (95ish) i had the nightsun headlight and their matching tail which seemed incredibly bright at the time
    Fast forward 15 years and i just picked up a magicshine tail which seems dim in comparison but it could just be that my front lights are so much brighter
    Thinking of digging out the old nightsun tail and splicing in the magicshine connector
  • 11-20-2012
    MRMOLE
    I'm another one who has had good luck with the PBSF. I still use one on the back of my camelpack. I ride enough though that I go through a lot of batteries (if the batteries aren't fresh the light is not near as bright) and I think I would be better served by a Surfas/Moonshield with rechargeable batteries (and brighter).
    If I want SUPER BRIGHT I already have a light for that. Jim at Action-LED-Lights had some of his wide angle lenses made up in red and I've been using one with a Gemini Titan lighthead as a tail light. I even get compliments on the light from people in cars.
    900 Chinese lumens makes a bright tail light! I actually run it on low (which is plenty bright) most of the time to minimize the decreased runtime I get on a battery charge (I use a y-cable). For me a self-contained light is a better fit since I seldom ride the same bike 2 days in a row (mounting take a little while), but if I were a commuter I'd use this light every time I went out. If you ride in traffic a lot and have an old MS/Gemini/Clone
    lighthead, this is cheap way to make your ride safer!
    Mole
  • 11-20-2012
    notnowvbs
    I have the Nightsun dual beam front light. It doubles as a heater on the cold rides. Actually stopped using it and bought the MagicShine 808u.
    Could you post up a pic of your NIghtSun taillight? I don't remember that one. Don't see one on their web site either.
  • 11-20-2012
    notnowvbs
    As far as a good tail light, I use the MagicShine rear light. Very good and very bright.
    A friend uses an Exposure tail light. It is impressive as well.
  • 11-20-2012
    leaftye
    I have the Planet Bike Superflash clone and Magicshine MJ-818. The Magicshine is much brighter. I have them mounted on the rear of my rack in this configuration.
    PBSF | MS | PBSF
    I wanted to keep all three on always-on solid mode, but the Magicshine is too much brighter, so the Superflash clones are on blinky mode instead.
  • 11-20-2012
    mtbRevolution
    PBSF | MS | PBSF
    The MJ-818 is bright but compare it with the Xeccon Geinea. I will post 2 videos of the comparison. The Geinea will be out soon.
    Leonard
    <iframe width="640" height="360" src="http://www.youtube.com/embed/CTELvM6COw8" frameborder="0" allowfullscreen></iframe>
    <iframe width="640" height="360" src="http://www.youtube.com/embed/CO2yhRHPTfQ" frameborder="0" allowfullscreen></iframe>
  • 11-21-2012
    brianW.
    Do not underestimate the importance of reflectors when sharing the road. Recently read something that the rear reflectors are seen before the blinking ones. My friends that commute also have replacing tape on their helmets and a small blindly facing the rear also.
  • 11-21-2012
    kiloman
    I too use the Magicshine MJ818. I use a single battery pack to power the MJ818 tail light and either a MJ808U or MJ872 headlamp. I can't comment about how the MJ818 compares to other tail lights because I haven't used anything else, except an old school Vista Lite set to blinky mode for visibility, but the MJ818 sure is bright!
