Results 1 to 7 of 7
Thread: bd strykr sl
    bd strykr sl
    just recieved the stryker sl just wondering how long the battery needed to charge before usage. came with no instructions the wall charger shows green but when plugged into light no light output any commments appreciated
    Reputation: androgen's Avatar
    Apr 2005
    Quote Originally Posted by 07civ View Post
    i have never used Baja but i would guess within 2 hours of being plugged in it should already work. however i like to charge my lights to at least 40% before testing them.
    the first charge may take a bit longer than simply charging from flat, but shouldn't be much longer.
    Apr 2005
    how did it go ? did you get it to work ?
    light on charger should change
    When you plug in the charger, LED light should come on. When you plug in the battery, the light will change color. When the batter is fully charged, the LED light on the charger will change color back to original color.
    I know nothing about Baja lights but some lamps have a "press and hold" start-up safety feature. You might try that to see what happens.
    Most batteries are shipped with a small charge. That charge should be enough to operate the lamp. Still, should take about 4-5hrs to reach a full charge. If you continue to have problems, look up a Baja thread and give the Baja people a shout out. I'm sure they will take care of the problem right away.
    Apr 2005
    Dinotte requires a double press to turn on.
    Contacted baja sending a new battery and charger good customer service
  1. Baja Designs Strykr SL on sale $199.95
    By Baja Designs in forum Lights and Night Riding
    Last Post: 12-06-2012, 12:39 PM
  2. bajadesigns strykr sl
    By Rocker T in forum Lights and Night Riding
    Last Post: 12-03-2012, 12:28 PM
  3. strykr pro change??
    By Romic tech in forum Lights DIY - Do It Yourself
    Last Post: 08-31-2012, 10:10 AM
  4. Replies: 74
    Last Post: 08-28-2012, 05:11 PM
  5. 2011 Baja Designs Strykr/Strykr Pro Trade-Up Program
    Last Post: 04-11-2011, 09:26 AM
