Page 7 of 11 FirstFirst ... 34567891011 LastLast
Results 601 to 700 of 1040
  1. #601
    Jan 2013
    I'm not nearly as informed as most posting information on this thread, but i thought i would share what i found, someone may find some interest in it. I bought a Panasonic 6200mah 2s2p from ebay's hunk_lee. I requested that he include a balance connector. Order took about 3 weeks to florida. The batteries packaging looked like the ebay ad with the exception that it said samsung on the label. I cut the shrink wrap off, the cells were indeed panasonics. The balance connector was added but soldered up completely wrong, he didn't charge for the connector. The main connector was magicshine sized connector but not the waterproof variety.
    Received batteries at just over 7.2v
    charged to 8.4v
    discharged to 3.0v
    resulting in 5764 mah or about 93% of capacity as measured by my icharger 106b+
    I'm pretty happy with what i got considering a battery university article states "...All 11 pouch packs show a starting capacity of 88–94 percent..." I could have done without having to cut open the shrink wrap to verify the battery brand and resoldering the balance connector.
  2. #602
    Aug 2013
    FWIW, the capacity of modern Panasonic cells is specified for discharge to the 2.5 volt, not 3.0...
  3. #603
    I think Lee (or someone else that purchased from him) indicated previously that the protection he is using, cuts of at 3v.
    Anyway as I believe Archi is trying to indicate. That means you had an extra 200mAh left in the cells. So that should make your percentage even higher.
    Sent from my GT-N7100 using Tapatalk
  4. #604
    Aug 2013
    Exactly. I've recently tested HunkLee's 6200 Panasonic battery bought by my mate in November 2013: the protection PCB allowed to discharge it to the 5.0 volt without problem (i.e., 2.5 volt per cell) with resulting capacity of 6170 mAh:
    Excellent pack!
  5. #605
    Was that the integrated factory protection on the cell or an external circuit?
  6. #606
    Aug 2013
    I'm not sure what you're referring to as "external" in that case. There's no integrated PCB on Panasonic cells: protection is to be added by pack assembler. In abovementioned case, it was the original PCB installed in the battery.
  7. #607
    Nov 2012
    PCB might be modified by Hunk_lee to suit proper cell cut-off voltage, e.g. 3400 mAh Panasonic will cut-off @2.5V, Sanyo 2600 mAh @3V, ... I just wonder why the balance leads were soldered the wrong way
  8. #608
    Obviously an unintentional mistake, albeit a serious one, as in bad things could have happened (imagine a novice trying to balance that thing).
    Probably one of the staff or Lee himself working overtime.
    Anyway an unfortunate lesson to learn from this is to check (that is if you still dare to buy from him). However some might not like to have to cut off the shrink wrap, when its already been paid for.
  9. #609
    Aug 2013
    Readily-available PCBs typically have wide range of triggering voltages: I've seen many samples with lower limit of 2.4 volt, so probably he's just selected appropriate one for Panasonic range.
    As for balance lead, I hope it will fix that in later batches.
  10. #610
    I ordered two packs from him with balance leads on the 10th. I'll report back how the balance leads are connected once they get here.
  11. #611
    Quote Originally Posted by jimmybjj View Post
    Were the wires soldered to the wrong points (red +, black -, yellow common) or were the wires just in the plug in the wrong order?
  12. #612
    Jan 2013
    Quote Originally Posted by robs31 View Post
    Colors were soldered to the pcb the correct way, they were not in the right sequence at the plug.
  13. #613
    Reputation: mtbRevolution's Avatar
    This thread has been a great resource for many throughout last year. Anyone second a 2014 thread?
    Leonard - All things Xeccon + Beyond
    mtbRevolution.com
  14. #614
    Quote Originally Posted by mtbRevolution View Post
    Hey Leonard, what's up...
    I've toyed with the idea of doing a 2014 version but right now with there still being issues with getting batteries shipped from *overseas sources It would make no sense to list batteries that still might not be available without major delays. Hopefully that will change as more *OS vendors figure a way around the air mail regulations.
    In the mean time a lot of people are looking for vendors able to ship within the continental U.S.A.
    BTW, are you still able to supply batteries to the U.S.? Last I heard you had someone in the U.S. that was shipping batteries for you. Is that still something that is an option for people looking for batteries?
  15. #615
    Valid point on the shipping challenge. No carrier will declare they accept, ship and deliver lithium batteries without issues. We will be the first in line if there was. It's still pretty much hit and miss. We've tried it all - HK, China, Singapore, Swiss, Swedish, EMS etc. Yes today, no next week, yes again in 5 weeks time. We will see more misses when they tighten the noose around lithium shipments.
    We still have hard and soft shell Samsung 7800mAh batteries stored in Colorado. They come with adapter cable to make them fully MS-type compatible. We truly value Mike's professionalism - hat off to you Sir. He dispatches at the snap of a finger then sends me pic of the parcel with USPS tracking number clearly in view, which we forward on. Transit time is within 4 days.
    We've ordered Xeccon's Panasonic packs for post CNY delivery. We will have 2-cell 3400, 4-cell 6800 and 6 cell 10,200mAh packs. Price will be higher than Mr.Lee's since we have higher guaranteed shipping cost, neoprene pouches, fully waterproof connectors and cables and most of all, mtbRevolution's capacity guarantee and Xeccon's warranty. We are considering sending some for the US market but need to gauge interest before doing so.
    mtbRevolution.com
  16. #616
    How serious is the shipping issue really? I mean currently.
    Who here hasn't received their shipment? Say from December onwards.
    I bought 5 separate 18650 packages, all ordered and payed for on different days and all arrived with no problems. Only as written before the first pack took 45 days to arrive but i guess that due to xmas.
    All other (4) packages ordered in January arrived within 2 weeks and thisvis Hungary mind you. So usually slower than US or even UK.
    All shipments came from Banggood.
  17. #617
    Nov 2012
    BG claims they have no shipping problems with li-xxx cells.
  18. #618
    Quote Originally Posted by oalex100 View Post
    Hi oalex, do you still have the battery packaging/s. If yes can you please post a close-up pic of it/them, front and back.
    You can read about the hits and misses in this CPF thread.
    mtbRevolution.com
  19. #619
    Yes, I do have the packaging. However I am not sure about posting my address and tracking number and stuff on a public forum. Is there anything in particular that you want to know about it? I can write down for you any specific info that you might need. Like which post they used or what they declared it as, and so on...
    BTW I did go trough the topic that you linked and it too confirms my suspicions. As of December till date, everyone there too is confirming that they do get their order and as a mater f fact in a timely manner.
    Someone even posted that Wallbuy actually has a post up (somewhere) that most of their buyers have been positively indicating that they are receiving their cells. So shop with confidence. Also Fasttech is again shipping cells (they stopped completely last year). So everything is pointing in the same (good) direction).
    So its more HITs now as I said, just read from mid December post till now. I couldn't find any miss.
  20. #620
    Quote Originally Posted by MK96 View Post
    So does Wallbuys. Quote from CPF forum: wallbuys site notice : Now more and more customers give us good feedback and receive their battery orders after 20 working days, so there is no battery issue in wallbuys now. any problem send a email to us
  21. #621
    Sorry should have mentioned I didn't expect your personal details out in the open. It should be blacked out. Ok, just wondering how the packages are declared. Is there a lithium warning sticker and li-ion cells in the description or are they described as gift and replacement parts. We ordered something from FT for research which we received a few days ago. It's a torch with lithium battery inside but described as I stated.
    mtbRevolution.com
  22. #622
    The declaration just says charger
    I guess they just found the easy way and also port authorities got tiered of the strict screening.
  23. #623
    ....So its more HITs now as I said, just read from mid December post till now. I couldn't find any miss.
    I summarized the same thing. Vendors are finding ways around the airline restrictions but this doesn't necessarily mean that shipping is going to be "business as usual" from every company/vendor. Just before the fall holidays I had an order from D/X that didn't arrive because of a battery issue. I had to contact D/X and have the order sent without battery. On the other hand the battery sent from Hunklee came without delay. Kaidomain on the other hand has an order being sent to me as I write. Seems to be on it's way but I have at least a couple weeks to wait to see if there are any delays.
    Still, if my order arrives in a timely manner I'm not going to assume that we are quite "out of the woods" concerning shipping issues. For that to happen I need to hear or read that the international Airlines are coming to their senses and realizing that the shipping of Li-ion batteries "is" in fact no great threat. Likely almost everyone who travels by air nowadays carries a cell phone, lap top or tablet that uses Li-ion cells. That said, there is no way in h*** that the airlines are going to prohibit those devices. If they did the public would have a mass conniption fit in response.
  24. #624
    Ready
    At long last, bike/setup is 99% ready. Thank you guys. You saved me from possible short circuits
    Details
  25. #625
    Reputation: pigmode's Avatar
    Slightly out of context but I've received or have incoming a two cell Xtar charger, and a Panasonic 3400 mAh XCR18650B (protected) battery. This for a small light for EDC pack carry.
    Would like to have gotten the smart Xtar charger, but maybe later.
  26. #626
    Feb 2014
    I have several L&M units and two of them are older Stella 120's both having battery issues taking and holding a charge. $28 each (parts + labor) at Batteriesplus, working like brand new... battery capacity of the replacements are a step higher than the original cells. Took about 3 days.
  27. #627
    Nov 2012
    Another li-ion cells from DX left China using RQ....SG tracking. Seem that every seller tries to find out how to pass the "rules" successfully.
  28. #628
    Got my packs from Hunk Lee (2S1P 3400, 2S2P 6200) and yes, the balancing leads were not in the correct order. I would like to note that I had previously purchased some balancing leads elsewhere that were also not in the correct order, so not sure what the deal is. The good thing is it's an easy fix. Simply pull the pins out of the connecter and put them back in the correct order, no need to open the pack and resolder. I tested the capacity of both packs and they were close to the stated capacity. My charger discharged them down to 3.1v per cell and then charging stops at 8.2v, so obviously not the full range, but gave me a good indication of where they would be with a full charge. I requested the packs come with the new screw type connectors. I also requested that he add the male end of the connector so I could change out my lights plugs, and he included them and the balancing leads at no extra cost. The packs were packaged very well and arrived in 3 weeks to California through Singapore post. Overall I'm very pleased with the product and the service. Would surely recommend if your looking for a pack.
  29. #629
    Nov 2013
    If add a 3P balance connector is necessary?
    Thanks for your supporting of our products and service!
    If add 3P balance connector is necessary, we can update the design of our battery pack. The cells from Panasonic/Sanyo has very good complance in performance. So charge by 8.4V charger from P+~P- is enough. But I don't know if the cells have difference in performance among same pack after 300cycles.
    FMA Battery
    No Battery, No living.
  30. #630
    Reputation: Hyperocity's Avatar
    Feb 2014
    Can someone lead to me to a batter holder for the bottle cage?
  31. #631
    Nov 2013
    Difficult to ship battery to worldwide countries. But ship to USA no problem now.
    FMA Battery
  32. #632
    I like turtles
    Reputation: TiGeo's Avatar
    Ok, I ordered a "Hunk-Lee" battery off of eBay for a cheap-o 808 XM-L2 clone I bought. I got the following:
    Samsung LiIon Battery Pack 7 4V 4400mAh for MagicShine LED Bike Light 2S2P 22F | eBay
    I should have read up/emailed this guy - does this not have the proper MS-type connector? Are these waterproof?
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
  33. #633
    Nov 2012
    Cells sit in a heatshrinked tube - non waterproof. After all you can e-mail him to quote the mods you need.
  34. #634
    I like turtles
    I already ordered it..bummer! Thanks for the info though...if I order another I will talk to him...or just go through Action LED!
  35. #635
    Reputation: ironbrewer's Avatar
    Oct 2012
    Quote Originally Posted by TiGeo View Post
    I believe that it is a ms-type connector. It is a quality product for a great price if everything I have read is correct. It was not misrepresented in anyway. I also believe that it comes with a neoprene pouch with velcro to attach it. You could always plastidip it to get it mostly waterproof.
    The original ms connectors are water resistant not water proof. To get a waterproof connector, you would need a screw connector with o-ring or something similar.
  36. #636
    I like turtles
    Great info iron..thanks. I wasn't insinuating that he misrepresented it, just that I didn't do my homework. I just was hoping it wasn't like the kid of connector that are MS-type but don't snap together.
  37. #637
    Nov 2013
    The order of balance connector are not only one type. Depanding on the order of balance charger, two orders charger are.
    But re-order action is simple. Just press the metal down and pull wire out, then let the metal clip a little up, then insert in the correct hole.
    FMA Battery
  38. #638
    Some of my thoughts:
    The battery I received from Mr. Lee had a connector compatible with ( other ) MS type connectors....BUT.....the connector does not include the rubber outer shield usually included with other MS type connectors. Without this shield it is very easy for the two connectors to come apart. I'm not saying it can't work but a tighter connection is more desirable in my opinion.
    I should also mention that the wire included with the ( Lee ) connector is also quite short. Judging from the photos on Mr. Lee's website this looks to be a standard length of wire used on his other batteries as well. In comparison to other batteries I have, the others have connection wires that are at least twice as long.
    Since Mr. Lee seems happy to comply with requests I would suggest that anyone ordering a battery from Mr. Lee consider how they wish to mount the battery and the length of wire needed to reach the lamp with your intended mounting solution. If you need the screw-on type connectors you should ask for those. If you want shielded MS type connectors I would ask for those as well. Otherwise you will get the standard set-up which might not work as well as what you want.
  39. #639
    Nov 2013
    Sorry. We should pay much more attention to waterproof performance! How longer of the DC socket wire you wanted? If a 3P balance connector is necessary?
    FMA Battery
  40. #640
    My experience w/ any of these cheaper options (battery/light head) are the connectors. They just don't stay together. They are so bad that they are almost unusable unless you tape them together.
    I have the Dinotte XML-3 dual and it came w/ an extension cord so what's I've done is used that extension to connect the light head to the battery. The Dinotte extension creates a nice solid connection.
    You will more then likely have to mod the connectors some way.
    Just my experience.
  41. #641
    I like turtles
    Got it today. Will use my extra MS extension cable to splice in a better end. What comes on it is not secure.
    Sent from my SCH-I545 using Tapatalk
  42. #642
    Nov 2013
    Shipping battery parcel to worldwide countries become more difficult now. Even this, we ship to a USA customer just take 3 weeks, (Order at Apr.16, received at May.3), the USA customer still give us a negative feedback, we are in China, not in USA. It is unfair to us. Catch such a case, we very disappointed, one of me said refuse to ship to USA. But one said don't hurt most USA customers as they are good and support our ebay business forever! How should we do!
    FMA Battery
  43. #643
    Aug 2013
    HunkLee, don't worry, and just keep your business running! We all know about current troubles with lithium shipping, and you're doing great job finding the ways for successful delivery. Thank you!
  44. #644
    Quote Originally Posted by -Archie- View Post
    +1!......Mr. Lee, The informed consumer here in the USA knows about the troubles with efforts to ship Li-ion batteries from China to the USA. Before airline regulations began to ban Li-ion batteries, normal shipping times from China took anywhere from two weeks to a month. With new regulations in effect no doubt there will be additional delays as you try to find carriers that will accept your shipments. There will always be people who do not like to wait. It is unfortunate that you have to deal with logistical shipping problems ( and angry customers who don't know all the facts ) but such is life.
  45. #645
    Reputation: Gharddog03's Avatar
    Sep 2013
    HunkLee sells some quality packs at a reasonable price!
  46. #646
    Xeccon 4-cells; Panasonic and Samsung; Great Price!
    Okay, I was browsing through the Xeccon website tonight and couldn't help but notice that down on the very bottom of their battery list is a 4-cell 6800mAh Panasonic battery....all set to go! $46.00 USD! That is one great price on a weather sealed Panasonic battery, pouch with good connectors. Me thinks Leonard might be giving Hunk Lee a run for the money.
    Now what doesn't make sense is that in the product description it mentions that the battery is only available to people in Australia??? If true why is it listed on the USA site and listed as $46 USD?? Sort of a mixed message there if you catch my drift. Anyway, I tried the on-line chat thing but got no response. I might have to send Len an e-mail.
  47. #647
    Hi Cat, sorry I missed you on the chat-thing.
    We ordered the 3400mAh cells a while back. We then had the 3100s which went out the door like the flux capacitor fitted DeLorean. The 6800 is by far the most popular because of weight : size : price ratio. The 2-cell 3400 is the next and while I thought the 10,400 would be the go, it actually wasn't an attractive proposition for most. In Australia, besides the racing guys, most buy the packs from us to power their, you guess it - Yindings and Solarstorms.
    I asked Mike of CO a while back if we should consider sending Panasonics to him so we can do batteries only for ConUS. That was towards the end of the night riding season for the northern hemisphere so we left it. Cost of these batteries with shipping (still an issue) is costly. We do have a one-up over Mr Lee - the packs are covered by an extra silicone boot - even for the 6-cell, and the converters are 100% MS-type waterproof connectors. We are not really competing with him though. For now, the 6800 at AUD 46 is below the $50 free delivery threshold. Anyone interested can shoot me an e-mail. We can upgrade the battery pack with these Panasonics which we have in our office in China. Our Spiker 1211s and most recently S12s are fitted with XM-L2 U2.
    mtbRevolution.com
  48. #648
    Reputation: Wombat's Avatar
    Leonard
    Do your batteries still fit magicshine lights or do you now need the converter you mention?
    Tim
  49. #649
    Quote Originally Posted by Wombat View Post
    Leonard
    Hi Tim, Xeccon's square connectors fit MS-type connectors as they are. They will be water resistant but if you want them waterproof then the 30cm converter cable should be added.
    mtbRevolution.com
  50. #650
    ...I asked Mike of CO a while back if we should consider sending Panasonics to him so we can do batteries only for ConUS. That was towards the end of the night riding season for the northern hemisphere so we left it. Cost of these batteries with shipping (still an issue) is costly. We do have a one-up over Mr Lee - the packs are covered by an extra silicone boot - even for the 6-cell, and the converters are 100% MS-type waterproof connectors. We are not really competing with him though. For now, the 6800 at AUD 46 is below the $50 free delivery threshold. Anyone interested can shoot me an e-mail. We can upgrade the battery pack with these Panasonics which we have in our office in China. Our Spiker 1211s and most recently S12s are fitted with XM-L2 U2.
    @mtbRev....Having 4-cell batteries with the 3400mAh Panasonics available to the USA market would be a big plus. My bet is that if you had these stocked with your US supplier you would be selling so many you wouldn't be able to keep them on the shelves ( if priced as well as your others. ).
    @Wombat...Having used the Xeccon batteries with the squarish connector plug myself I think some clarification is necessary. The metal connector on the Xeccon battery is actually round, just like with any other Mshine type battery. What's squarish on the plug is the rubber shield. Strange as this might seem, it works perfectly well with any lamp I own that calls for a Mshine type batttery. ( * The exceptions are: DiNotte...which doesn't work with any Mshine type battery without modding save the Hunk Lee's ) And, The Mshine type batteries that use the "screw on" connectors.
    Truthfully, I don't know if any of the standard Mshine type batteries I use have connectors that are fully waterproof. Almost all the ones I own, ( except the Hunk Lee ) are very well shielded though. The square "Xeccon" ( female ) plugs work so well with my standard ( round/male ) lamp plugs that I really don't see there being a real issue ( or need for an adapter ). The fit is very tight and looks very"weather-resistant" to me if not completely "water-proof. I will also say this about the new Xeccon ( squarish) plugs; Used in combo with the matching Xeccon lamps... The fit is so smooth and tight I would bet money that they are water-proof to 1 meter.
  51. #651
    Thanks for the advice Leonard and Cat.
    Tim
  52. #652
    Leonard- just told me that Panasonic batteries are not available to US, only if you buy a light. Also noted by Cat the square connectors do work perfect with MS and SS lights, I have last year BAT and Samsung batteries from Xeccon and still going strong.
    I also still feel Serfas bike lights are the best to can buy for the money, from the light head to the battery, switch, connectors all first class. Try to find a deal on one.
  53. #653
    Battery packs?
    I have some decent batteries that i would like to use in a 4 and 6 cell setup.
    Any recommendations on cases would be great. This appears to be the best one out there. A little pricey but looks solid.
    PANNOVO B-C04 Water Resistant 4 x 18650 Battery Pack Case for Bike Lamp - Black - Free Shipping - DealExtreme
    I've been unable to find a 6 cell case?
    also for the people out there making there own do you.
    A: Whats the best way to make sure batteries are paired? (i can source some good quality lenovo laptop batteries last set i got all 8 were great and have kept voltage without an issue)
    B: Protection circuits. do you buy the protection PCBs and if so any recommendations as i really don't know where to start on this.
    C: Leads and where to buy them from
    Just as reference I want to have a 6 cell so i can run two Yinding dual XML's from.
    Thanks in advance
  54. #654
    Mar 2006
    Quote Originally Posted by steviemidnight View Post
    This is a very good case if you have your own cells. I have a couple for the lights I've made.
    Right now this case is sold out at DX.
    I don't think there is a 6 cell case holder yet.
    "By Your Command"
  55. #655
    Reputation: Swissam's Avatar
    Just a quick question that is sure to be beating a dead horse, did a search, please dont sue me. Picked up a couple of lights from Amazon (assuming they may be "slightly" better than random ebay vendors). The brand is securtiying and they came with battery packs, how long do I need charge these? And how long is too long before it becomes dangerous? I already ordered a Panasonic pack for my head lamp which will be in my backpack and I will use the cheep batteries for the bar lamp with the pack mounted to the frame. Another question is I live in Switzerland (220v) but I bought these since Im in the U.S at the moment. I am assuming the charger should be able to convert 220v and I will check once I receive the package. I doubt the conversion should be a problem but I am worried about charging the cheap batteries. Any help or links to threads that have already covered this topic would be greatly appreciated. Thanks.
    Edit; one pack is 6400mAh and the other is 4800mAh
    Amazon.com : SecurityIng® 3X CREE XM-L T6 LED 3800Lm LED Headlight Headlamp and Bicycle Light (Generic Packaging) : Bike Headlights : Sports & Outdoors
    Amazon.com : SecurityIng® 4 Modes Waterproof 2800 Lumens Cree XM-L U2 LED Bicycle Light & 4800mAh Battery Pack & Charger, Cree U2 LED Bike Lmap Light, Super Bright Lighting Lamp Bike Light CREE LED Flashlight Torch for Outdoor Sports Like Camping, Ri
  56. #656
    Hi Swissam, a couple of options - (1) use the chargers that come with the lights or (2) buy use the buy a hobby charger - eg see this thread & this website.
    Check when you get your hands on the charger, but AFAIK all chargers use switchmode power supplies and should be compatible with 110-240 V, you just need an adaptor to use the correct plug. You should not have to remember which charger belongs to which battery as either charger should charge either battery.
    Personally I prefer to use a hobby charger but the vast majority of people just use the charger that comes with the light.
  57. #657
    Quote Originally Posted by find_bruce View Post
    Thanks for the tip. Just wondering if these chargers have an automatic shut off once fully charged. Ill wait until tomorrow as I dont want to leave it on all night. How long do these battery packs normally take to charge up?
  58. #658
    Just Ride !
    Reputation: C.M.S's Avatar
    Getting a 2 cell 18650 light set up via slow boat (MS 816 clone ) that use individual cells in a cradle , my question is that when I upgrade cells do I have to have Protected cells ?
    Hit the trails with your bike and get freaky.
  59. #659
    Just Ride !
  60. #660
    May 2005
    Is there a battery case that i can fill with 2x18650 cells? For my Yinding light I use at the moment the Pannovo 4x18650 battery pack with some Panasonic cells. As my nightrides are normally very short (about an hour or so) I want a lighter, less bulkier battery case that I can fill with only two 18650 cells.
    I am looking for a case similar to this case on the left from Fenix:
    The Battery Thread: 2013-fenix-bt20-bicycle-lights-high-intensity4.jpg
  61. #661
    Quote Originally Posted by Swissam View Post
    All chargers for Li-ion batteries are designed to shut off once the full charge has been reached. Most batteries are shipped with a 40% charge. Should take about 3-3.5 hrs. for the initial charge. When fully depleted the battery might take 5-6hrs to recharge. I highly recommend charging in a safe place and under supervision. Anyway most chargers have an LED indicator that will change from red to green when the battery is charged. Once charged it is a good idea to remove the battery and charger from the wall power outlet. I say this but only because i know that sometimes a voltage surge in line voltage can damage cheap electronics.
    @ C.M.S. > About the protected cells; Not a big issue if you know when to switch out batteries.
    @ randan > Don't know if there's a cheap 2-cell ( series ) holder but at least you have the one sold by Fenix that should work as long as the plugs are compatible. Option two is to just buy a two-cell ( 2-series ) battery. I bought one from Hunk Lee ( ebay vendor ) using Panasonic batteries for a good price although if you choose this option you will need to weather proof the battery ( which is not too hard to do ) The Hunk Lee connectors ( though not the best ) work fine depending on what type of connectors you have.
  62. #662
    Mar 2006
    Quote Originally Posted by randan View Post
    I'm sure you can use the Pano's with two cells. It won't be less bulky, but will be lighter.
    "By Your Command"
  63. #663
    Just Ride !
    Which ones are recomended for the lighting n00b that I am ?
  64. #664
    Sep 2013
  65. #665
    Reputation: patski's Avatar
    Dec 2005
  66. #666
    Quote Originally Posted by patski View Post
    These Xeccon batteries look pretty nice, comes with a nice soft case, shipped from the US... great price.
    Xeccon Panasonic 4-cell 6800mAh Ultimate Li-ion Battery
    Patski, I have one of the Xeccon Ulitmate 6800mAh batteries. It is definitely the best packaged battery you can get for the price. Unfortunately living in the USA you might not be able to obtain one at the moment as the last I heard they ( Xeccon ) weren't selling these ( aftermarket ) to the USA due to shortage of stock ( inside the USA ).
    If you want one you might have to contact Leonard from Xeccon and check on availability.
  67. #667
    Dec 2005
    Well, I't let me add it to the "cart," didn't click "buy" tho....
  68. #668
    Your right, thanks. Took about 3hrs to charge on 220, the charger was warm but never got too hot nor did it explode and burn my house down. I did however order two Panasonic packs from hunk_lee on ebay but I will keep the cheapo chargers as they look identical to the ones on hunk_lee's page. I tested the lights out on a friends farm in the middle of nowhere and these lights (ones I listed above) light up the whole field and will be more than enough for trial riding. I'm hoping I won't run into too many problems once I get the upgraded battery packs as these lights seem to be well built. I spent a little over $100 for both set ups (including upgrading the battery packs) and so far I'm more than happy with them. Now I just need to mount them and go ride....one the rain stops.
  69. #669
    Reputation: Viva Borracho's Avatar
    Maybe I had too many post ride beverages last night, but I can't envision how the fit between the "square connector" on the battery pack can have a tight fit with a MS type "Round" connector.
    Is anyone able to post a picture of this connection. I would like to purchase one of the Xeccon Samsung Battery packs as a replacement pack for my MS, Gemini, and SolarStorm lights.
    Xeccon Samsung 8.4V 5200mAh Li-ion Soft Shell Battery
    Thanks for any help.
  70. #670
    Dec 2005
    I PM'd Leonard, these are currently NOT avail in the US, he's looking into it, will ping me when/if a decision is made. Hopefully he'll post to the community...
  71. #671
    Quote Originally Posted by Viva Borracho View Post
    I'll try to get some photos during the weekend. Xeccon also has the adapters
    ( square to round ) FWIW. If you needed an adapter I wouldn't think that they would cost more than a couple bucks but like I said before works fine without it.
    The Xeccon 5200mAh battery should work very well with any lamp using 1-2 emitters. For years I ran my Gloworm X2 using 3yr old Bikeray 5200mAh batteries ( BAK cells ) and never had a problem. The Xeccon's with Samsung should be even better and as a side note the Samsung 2600 cells should be lighter than the Batteries built with the heavier Panasonic cells. Not that it is that much difference but I can feel the weight difference ( in my hands ) when holding the Panasonic 4-cell built with 3400mAh cells.
  72. #672
    Mar 2006
    If you're looking to order batteries from China, word is that most vendors (DX, Fasttech, Walbuys, etc) are having issues shipping them out. Especially to North America. Shipping companies have deemed these batteries as hazardous and highly explosive. It'll be hit and miss when ordering from them.
    Your best bet is to order within North America, price is higher, but at least you'll receive your order.
    "By Your Command"
  73. #673
    Just Ride !
    Where are all these vendors like fasttech , DX , and others that sell individual high quality panasonic cells in particular for a very discounted price based out of ? And are they authentic ?
  74. #674
    Quote Originally Posted by C.M.S View Post
    China...as far we know they are authentic. They buy in bulk so can sell for less.
  75. #675
    Aug 2013
    This pack came with an SSx2. I'm having a hard time understanding what configuration this is? Seller description is 8.4V 6400mAh. On the sides of the batteries it states "IRC18650 3.7V", only other marking are the + and - symbols. I can find the IRC models in 1600, 2200 and 2400mAh. Samsung makes a pink IRC18650 model in 2600mAh. These must be the Purple People Melters.
    The Battery Thread: 2013-img_20141021_152647_872_zps74013e56.jpg
    The Battery Thread: 2013-img_20141021_152316_574_zps19e925b7.jpg
    The Battery Thread: 2013-img_20141021_152325_700_zps7467f39f.jpg
    Edit: I don't know what it looks like...
    Goodbye '95 ZJ. Just so you know, transfering box of left behind womens panties to next truck. Thank you ZJ!
  76. #676
    May 2005
    Someone effed up building that battery. It should be a 2S2P configuration. The mAh rating advertised as 6400 is using Chinese mAh which really equates to about 2000-4400mAh in reality.
  77. #677
    Aug 2013
    Quote Originally Posted by Vancbiker View Post
    As in 'its not configured properly'? Because the configuration does not look like anything I've read about yet.
    Edit: I had the battery charging for four hours today, after testing today. The light on the supplied charger is green, so I guess that means the charger thinks it is full. I set the multimeter to DCV200 and the battery reads 8.4V on the MS power plug. My multimeter is nothing special($12 harbor freight), its amperes setting is 1.5V 4A, and gives a reading of 23.8.
    [SSx2]If I were to balance the Trustfires I linked and build a 2S/2P pack, what PCM would I want to buy; through huck_lee or or will this one work
  78. #678
    Dec 2005
    Aren't the left side batteries are the Pos terminals and the right side are the Neg.
  79. #679
    Nov 2012
    This is the middle wire of the 2S 3 wire setup on the photo. You can clearly see that one cell of three should be reversed. There should be two positive and 2 negative cell terminals if you want a proper 2S2P setup. The wiring here is wrong!
  80. #680
    Aug 2013
    The setup looks very wrong from everything I've read over the last week, what I want to establish is if this is even a type of battery configuration? We know it's not 2S2P, so what is it, just bad assembly?
    With a 2S2P configuration, I think I need a PCM that will handle 7.4V with 8A Maximal continuous Discharging current? Will this PCM work for x4 18650 protected 3.7V, 2300mAh Trustfires in 2S2P configuration, to run the SSx2?
  81. #681
    Nov 2012
    It is a 2S1P and the rest 2 cells are useless in that config, IMHO
  82. #682
    Aug 2013
    Okay, pulling it open again to see what PCM was used, since I didn't flip it and get a pic last time. Though, I'm going to drain it again before I do.
    Edit: 58f and raining out. Placed light behind house out of the rain with a sheetmetal bucket to capture the light, light is set on high. Put battery to MM before test, DCV reads 8.4v; (1.5v/4.0mA) setting reads 23.8... I need my friend to get back in town so I can use his analyzer... I got phone recording time to cut off. Will report how long it last.
  83. #683
    Dec 2005
    I see, it should be like this, yes?
  84. #684
    Nov 2012
    Almost One red wire on this picture should get two plus cell faces and the other two minus faces. The biggest problem here is that three cells are plus oriented and one minus. Two/two would be OK. You need to split this pack or rearrange one cell - the topmost cell should be enough.
  85. #685
    Dec 2005
    I'd pull one of mine apart but they've all been plastidipped....
  86. #686
    Just Ride !
    Panasonic (green) with a silver NCR 18650b 3400 mah 3.7V made in China sticker on it isn't authentic is it !
  87. #687
    Nov 2012
    Yep, you'd need to wrap & plastidip 'em again
  88. #688
    Being that i missed out on the Waterproof case (thanks C.M.S) i kind of thoughts i don't need it. The 2 cheap 4 packs i have to date have survive just wrapped in sandwich bags.
    My new thoughst are just use
    2 of these
    A Battery Holder/Case for Li-ion 18650 17670 battery 2S1P w/PCM output:6-8.4V | eBay
    or create a pack using these:
    5 Pcs Black Plastic 1 x 3.7V 18650 Batteries 2 Pin Battery Holder Case | eBay
    i'm just confused over protection circuits. do i need them? Being that i plan to use and charge batteries in my nightcore charger
  89. #689
    Are you using the spray can?
  90. #690
    Dec 2005
    Quote Originally Posted by pigmode View Post
    I dip them directly into the can, Performix 12213 Plasti Dip Black - 22 oz. Dip Can
    The Battery Thread: 2013-438.jpg
    The Battery Thread: 2013-436.jpg
  91. #691
    I bought 2 of those so called Panasonic's 3400mah (via China) and the run time on my Ultrafire XML U2 is about 30-40 min before light output starts to diminish. So I would say they are fake.
    Guess I'll just pay the freight and get the real ones but where do U buy so that U know they are real.
    MB
  92. #692
    May 2005
    Callies Kustoms. Genuine, but expensive.
  93. #693
    Reputation: garrybunk's Avatar
    Feb 2014
    Quote Originally Posted by mb323323 View Post
    MB
    US Source (ships international now, except that shipping Li-Ions will be a problem I believe) and BLF member: Moutain Electronics .
    -Garry
  94. #694
    Aug 2013
    Okay. Battery stripped 'again'...
    Flipped one battery for a proper 2S2P configuration. So then I decide that I need to test every cell. Okay, so two of the cells did not show a charge on DCV200, switch to DCV20 to look for really low voltage... None! Either the two batteries that were not wired correctly have deceased, or they have never been charged. At full the battery pack is 8.4V, 2380mAh. At cutoff the battery pack is 2.83V, 1170mAh.
    So I try to see if the i4 will tell me anything. I stick one battery in and in about 60s it tells me the battery is fully charged. When I remove the battery from the charger and test it, it shows (DCV200)1.6V. The charge wont climb any higher and the charger says it's done charging in less than one minute. Okay, so lets try the other battery in the i4 and see what I get. After 60 seconds of being in the charger, the charger is not reading that there is a battery in the charge port, the light does not even blink as it does when reading batteries, so I figure that the cell that was pointed out as needing flipped by you guys, is a dead cell, and all it has been doing is restricting current since it is the battery connected to the positive terminal with all the other batteries behind it.
    So I'm going to set aside the two working pink 18650's for now(which actually have a tight rating to each other; well matched) and wire my Trustfire 2300mAh(rated 2500mAh) batteries in 2S2P. Though, I need to find those "U" shaped ribbons, or any battery building ribbons(don't really know the name) like the ones a few pages back, because I've called all the battery and hobby stores in town and no-one sells the supplies for building batteries, except for shrink. Though there are plenty of shops that will build you one 30% more than online cost.
    Checking the number on the PCM, it is in fact a 8A protective circuit.
    I took all my trustfires and charged them one-by-one. Between all four Trustfires(using friends analyzer) there is no more than a .16V difference between the lowest charge and the highest charge at full battery, and there is no more than a 68mA difference in two of the cells. Seems safe?
    So my biggest issue right now is locating a place, either on the net, or within 25 miles of me, where I can buy ribbons for making battery packs. Links and answers are greatly appreciated!
    Vancbiker, if you have any of the ribbon in your stock, I would gladly trade you some beer and/or money for 5" in ribbon?
  95. #695
    May 2005
    Quote Originally Posted by pdxmark View Post
    Sorry, don't have any of that. I either buy pre-made packs online or use battery holders. Those factory connections are spot-welded with a special machine. There have been a few posts from folks that were able to get that done at local batteries plus type shops. There have also been posts where folks have soldered the connections to the cells. Unless you are quite proficient at soldering electrical connections, I would not advise doing that. It would be easy to kill a cell by overheating it during the soldering.
  96. #696
    May 2005
    Forgot to add...
    If you need to re-configure a pack in the future, do not pull the spot welded tabs off the cells. Cut them apart leaving a half inch or so of the tab attached to the cell. Then you can easily solder new connections to the remaining tab without risk of heat damage to the cell.
  97. #697
    After looking at this photo and knowing what lamp the battery was sold with, I feel at this point I would have to tear the shrink wrap off of every cheap Chinese battery I own just to make sure I don't have one of those. It is very obvious from the photo that only one cell is on the positive side when there should be two ( assuming two cells in parallel connected in series ( positive to negative ) to the other two parallel cells ). This scares the crap out of me. Someone must of left their glasses home that day before getting to the assembly line.
    @pdxmark, If I were you I would contact the vendor to get a new battery...AND, if you got this from an e-smay vendor I would lodge a complaint with e-smay.
    ( Edit; I just removed the shrink wrap off of one of my cheap batteries. No problems with mine. Actually the connections look much better than the one that pdxmark has. Anyway, still a good idea to check it if you own and actually use one of these. Personally, I only use the cheap batteries for testing and that very rarely.
  98. #698
    Dec 2005
    Are you just going to get a large 2" wrap like this? Will 2" fit?
    10' Black Polyvinylchloride Heat Shrink Tubing
    Will clear work? That could be interesting.
  99. #699
    Dec 2005
    Somewhere on one of these forums, I saw a battery pack photo with a hollow tube in place of one of the cells...
    The Battery Thread: 2013-img_20141022_162218_376_zps757b53a9.jpg
  100. #700
    Truthfully, I've never used heat shrink tubing that large before and I don't own a heat gun. I just know if you use it that it will have to be big enough to get the battery inside "before" you shrink it.
    If I were going to use this battery outside I would likely just replace the shrink wrap with black duct tape which sheds water very well. Then if I wanted it to be completely bullet-proof I might use the "Plastic dip" product or try a can of "Flex Seal" and apply that over the tape. I've never used PD or FS before so I have no idea if they are worth the money. Many people on this forum have used Plastic dip, never heard if anyone has ever tried what I suggest.
Members who have read this thread: 18
