    Battery Questions
    I have a Solarstorm x2. The battery that came with it is a 8.4 volt 6400mAh. I have a 7.4 volt 6200mAh battery. Will it work with the light head? Not enough juice? Sorry I know next to nothing about batteries or electricity. Please dont kill me too bad if this is a REALLY dumb question.
    Reputation: garrybunk's Avatar
    Feb 2014
    Yes it will work. The batteries are the same, it's just that one is reporting "nominal voltage" (7.4v) and the other is reporting full charge voltage (8.4v).
    -Garry
    Quote Originally Posted by garrybunk View Post
    -Garry
    Thank you. That helps alot.
    Reputation: Flamingtaco's Avatar
    Mar 2012
    Might be, but also, 2p lifepo4 batteries charge only to 7.4v. Double-check so that you aren't don't accidentally charging a 2p lifepo4 pack with a 2p li-ion charger.
    Will a 7.4v pack work with an 8.4v light? Yes, but you may not get full brightness. Depends upon how much of the voltage overhead is in use.
  1. OpenLight Rechargeable Battery -- 20% off (MagicShine battery alternative)
    By lightjunction in forum Lights and Night Riding
    Last Post: 12-06-2013, 06:36 AM
  2. Serfas True 1500 battery/Lipo/Protection-Circuit questions...
    By rbid in forum Lights DIY - Do It Yourself
    Last Post: 07-02-2013, 12:24 PM
  3. Battery Build Questions
    By BlueMoon100 in forum Lights DIY - Do It Yourself
    Last Post: 08-31-2011, 07:31 AM
  4. Noob Battery Questions
    Last Post: 08-21-2011, 08:20 PM
  5. pre-made battery pack vs. battery cell holders
    By Andy13 in forum Lights DIY - Do It Yourself
    Last Post: 01-28-2011, 11:58 AM
