Originally Posted by ihaveagibsonsg
I have the minewt dual with the o-ring mounting system. The rings are worn, but I want a way to mount them more securely. They keep slipping until they're facing the ground. Is there a better way to mount these? I don't want them to budge at all while mounted.
Get a rubber strip an inch wide(enough to go around the bar twice). Rubber glue one side of the strip and fit to the bar. Then use a thin but strong zip tie to secure where the o-ring used to hook front and back.
If..the o-ring mount is like this...
