Results 1 to 10 of 10
    Jun 2012
    3xU2 Fluxient super bright bicycle light
    This is my Fluxient 3xU2, Tonight I will take some photo to compare with 880 and Xpower.
    Jun 2012
    all at 100% bright mode, same distance , unit 10 lux
    Reputation: Cheytac's Avatar
    Thanks partner!!!
    Feb 2010
    Thanks Alvin, amazing thrower.
    A question Alvin:
    Can you guess or a meassure the dimension of the SMO reflector.
    Especially the depth of the refector would be very interesting to know.
    The diameter of the whole unit is 55mm right?
    And a single reflector hole?
    I am wondering how that light manages to produce so much throw.
    Oct 2012
    How are you finding this light, i'm about to purchase either this or the magicshine mj800, cant decide !!
    Quote Originally Posted by MickOR View Post
    Ebay mate!
    I just looked at those lux readings and I'm scratching my head.
    The lamps ( in the photo )look to be about a meter ( or five ft. ) from the wall. When I test my XML tri-clone lamp at that distance the meter almost goes to 3000 lux.. Perhaps the reading giving by Mr. Wu needs to be multiplied by 10. That needs to be clarified.
    The spot pattern on the wall looks much smaller than the one produced by my similar tri-clone lamp. If so the Fluxient 3x XML (U2) could be a real thrower. If the Fluxient does indeed have another 1000 lux output that is an extra 25% more light OTF. Mr. Wu, are you still around to comment about this?
    Oct 2012
    Quote Originally Posted by Cheytac View Post
    Ebay mate!
    sorry !, what i meant to say was, are you happy with the light !, is it worth getting?
    Reputation: Wombat's Avatar
    He does say above the first picture"... unit 10 lux", so you may be correct.
    Tim
    Quote Originally Posted by Wombat View Post
    Tim
    Yeah, I'm figuring something was lost in the translation. If he had said "unit X10 lux" it would of been better.
    One of the things that bothers me in the " Torchy Battery boy " beam shot photos is that the light looks to have a bluish tint. Mr Wu's photos don't seem to show a blue tint.
