View Poll Results: how much lumens Fluxient 3xU2 is ?
- Voters
- 12. You may not vote on this poll
1900 lumens
2500 lumens
3000 lumens
3800 lumens
Hi Alwin,
It's much brighter than the Magicshine MJ-880, that's for sure. I don't think it can be far off 3000 lumen. You can see a comparison with other bike lights here:
Torchy the Battery Boy: Bike light Database
Probably the brightest light I have seen.
[QUOTE=Torchy;9482771]Hi Alwin,
Probably the brightest light I have seen.[/QUOTE
wow ,just now I check this blog, it is so great, compare for many different brand bicycle light and have many photos take for their bright to compare, very professional, thank you very much
No chance to say how many Lumens that is. It could even be a 800 Lumens Light with long exposure time …
two days ago , I compare my 3xU2 with my friend's 2000 lumens MJ880, fluxient 3xU2 looks 2 times Higher bright than MJ880.
this re-seller sated that it is 2500 real lumen if you measure the power and assume they are using the U2 bin as claimed.
Fluxient 3000 3xU2 - Extreme lights
My money is on the 1900 Lumen option (and maybe a little less). I have the 3x XM-L clone (around 1200-1400 Lumen), and the Fluxient is probably not beeing that much more powerfull.
The heat from the multiple powerfull LEDs, is the real limitation in todays bike lights. Putting more and more LEDs into a light, and driving them harder and harder, will ultimately just be resulting in a meltdown .
 Originally Posted by Torchy
Hi Alwin,
Torchy, that is a nice collection of comparisons on your site, alot of work went into it. Great info there, any plans to do the gloworm X2 or more lights? Thanks for sharing it.
I own a lot of lights and I think the above comparison site is accurate when showing this light. The Fluxient lights really are that good.
It should be noted that the author of that site sells some of those lights and could have enhanced some images to suit their business interests. However, if that tactic was being used, it would probably be wiser to use the strategy to sell more of the cheaper lights and get more money. He does say that he'll give you your money back without questions if you feel you've been underwhelmed by the lights though.
Once I get my tri-clone from the other thread, i'll get some comparison shots sorted. I think this is somewhere above 2500 lumens, but not 3000. It is certainly brighter than car headlights. The only way to know a car is coming up behind me on the road is because I can detect my shadow slightly. You have to be careful that you don't blind motorists.
 Originally Posted by Alwin.Wu
Alwin, those looks like some pretty professional and official-looking photo's. Are you a manufacturer of these lights? My advice is that if you really want to know how bright this light is, you send one to MTBR for review. They have all the equipment to do a proper measurement of output, no guessing involved. I'm sure a lot of people on this forum would be interested in seeing how it stacks up.
A measurement from the 2013 bike lights shootout: Measured Lumens: 1612
Light + 6 cell battery pack R1,695.00
Is it really $695?
That's pretty dissapointing, but typical of cheap knock-offs. Lumintrek seems to be just as bad, overstating actual output by about 45%. Now I would like to see what the MJ-880u comes in at. I don't think it will be 1600, but it can't be far off.
- You may not post replies
- You may not edit your posts
Forum Rules
