Has anyone tried the new Gemini lights? I'm particularly interested in the new Titan, 4000 lumen, looks like three duos stuck together. The prices are very reasonable and they now have wireless remotes. Thanks
Although I don't find issues with 6000K tints found on the lights I use or the XM-L2 U4 leds in the new Gemini products as I don't find them washing out all the detail on the trails as some do. If not to yellow once back on my bike I will have to see if I can get my hands on a neutral white light. At this point I may not know what I'm missing until I try it. I read a post somewhere where Lupine is offering neutral white led boards for Betty's only at 4900K/or 5000K. Maybe time to switch my led boards.
Crazy. Really just 3 Duos together. I wonder if there would be any interference issues with some stems? I like the new Xera. The wireless remotes are sweet.
To bad the Xera isn't included in the wireless remote family as it is a good helmet light. I was wondering the same thing about stem clearance with the Titan,, may be an issue with some?
Remote switches (except Xera), better heat-sinking light bodies, new emitters for more poser - all great upgrades to the Gemini line. Also encouraging are the Xera's MTBR lumen/lux test #'s, hopefully the new Duo and Olympia will also more accurately match their power claims. Published runtime claims confusing though, Xera and Duo #'s match previous versions while the Olympia looks to have a considerable reduction in runtime out of its battery options. Looking forward to seeing MTBR's tests on these units.
Mole
Just a guess here, but since last years (claimed 2100 lumen) Olympia fell terribly short on output (1478 lumens actual) if I'm remembering correctly,,, the much shorter runtimes on the 2016 version hopefully is do to a major bump in output which should be north of 2000 if keeping on par with the Xera.
Gloworm has their work cut out for them. They're going to have to develop wireless remotes and slash their prices to compete. On the other hand, however, they do have batteries with fuel gauges, the option of neutral white emitters, and a choice of lenses. If Gemini were to offer neutral white emitters it'd be an easy decision.
That's funny, I just inquired with Dan about the 4900K boards for the Betty R as well. I'm currently running a Gloworm X2 with NW emitters (with 2 wide-angle lenses) on my bar so it'll be nice to have a matching tint on my helmet-mounted R.
I'm close to pulling the trigger on either the GW X2 or the Gemini Duo. I'm currently running two MJ-808 clones, one on helmet, one on the bar. Either the X2 or Duo is going to be a pleasant upgrade, but a couple of questions for some of you that are definitely WAY more knowledgable — and probably discerning — about lights than me:
Is the NW really that much of a game changer? I've seen some comparisons and I can see the difference, but wondering how it translates to actual riding? Worth the $25 upgrade? (from action-led)
Looks like the new Gemini Duo uses U4 bins — is this going even farther from neutral white than the U2 in the last version?
The price difference b/t the two is ~$50 or $75 including the swap to the NW on the X2. It seems like the GW is a little more refined overall, but are the differences really that important?
I'm close to pulling the trigger on either the GW X2 or the Gemini Duo. I'm currently running two MJ-808 clones, one on helmet, one on the bar. Either the X2 or Duo is going to be a pleasant upgrade, but a couple of questions for some of you that are definitely WAY more knowledgable - and probably discerning - about lights than me:
Looks like the new Gemini Duo uses U4 bins - is this going even farther from neutral white than the U2 in the last version?
Although I'm curious to see the difference on the trails myself, I cant say I have been disappointed with the 6000K emitters I'm using now. Hopefully I can find someone locally in the Tuesday night ride at some point who is using NW before committing to a $300 board change.
It's a subjective subject and you will be paying double the price for the NW X-2 over the new Duo with wireless remote to find out. I think like me you have to try for yourself to make that call. It wasn't long ago many of us were riding with P-4 equipped lamp heads which were almost as blue tinted as HID. We managed!!
I'm really curious about the NW as well. I have not even seen side by side screen shots or anything. I was thinking my Gloworms were already fairly warm over what most of the local riders are running.
Beamshots and videos will never reveal the advantage of NW emitters IMO. NW emitters don't make your light work better (1500 CW lumens measures the same as 1500 NW lumens), they allow your eyes to work better. CW emitters appear more powerful because they produce more glare. The harsher (not more powerful) CW light makes your pupils constrict more (for any given lumen amount) than NW would, reducing your vision performance. For the last few years I've run a Gemini Olympia as my bar light and had come to the conclusion that my vision was actually reduced at anything over 80% power on that light. I can run my BT21 or BT70 with NW emitters (which makes more measured lux) at full power with none of the reduced vision issues (mainly washing out trail irregularities) I notice on the Olympia at 100%. So looking at beamshots (and running a mix of NW and CW) eliminates the NW emitter advantage and again IMO not an accurate way of comparing the two emitter tints. I imagine NW emitters are like most things in that the degree of advantage depends on your eyes, riding environment, riding style and speed - I definitely think it's worthwhile (I also own an X2 & XS and will be having them changed to NW soon).
Mole
I've complained about poor night vision for a while now and do find even around the house in winter months I need more light than my younger wife. But also on the trails,,,, I've got lots of output and it works for me, but based on how you describe how the eyes react to cool white vs NW it makes sense to me. If the light is still as bright in lux but distributed in a warmer tint yes maybe the pupils wont close up as much thus better perception on detail in the lighted area.
In general I also have diminished night vision. Additionally, I don't know if this factors in to emitter tint at all, but I am really adversely affected by super bright car headlights — which always seem to be of the cool white variety. Again, I don't know if it's simply the brightness and the color is just coincidental or there's a connection. Maybe some of you know. . .
But yeah, the value of the new Gemini lights really seems to be a strong argument for them over the Gloworms — especially if the NW emitters aren't that big of a deal. I realize it's subjective though and for some people that'll sway them towards the Gloworms.
I'm really torn but starting to lean towards the Duo.
I have two sets of the Gemini Duo and Olympia lights. My old ones are 1200 and 1800 lumens. Loved the lights enough that I bought another set to share with the family. I do like the remote idea. Looking forward to trying them out. As it is now they are fully charged and ready for action. I was never lacking for light on the old set so imagine the new ones will be equally as bright in the trail.
We'll have them in stock the middle of next week. I'm anxious to do some testing on them and how they have improved. Particularly in how they handle over heating. I'll post results here as soon as I have them. I'll be doing beam patterns and then output vs time with no air movement. I'll probably retest the old ones for comparison.
Still a few of the older ones left at sale prices. (they've just been reduced even farther)
I look forward to seeing how they test out. I noticed all the light-heads weigh a little more so that should help with the heat. If they still get hot here's the solution I'm currently using that makes my Gemini lights work fine in desert ride temps. (+100°).
Mole
I did forget to ask about the thermal? That was one area Gemini was lacking in the past as when they stepped down, they really stepped down to the low setting. I prefer a more controlled gradual step down system like the GloWorm products. Please confirm when you have a chance if thermal has improved.
The new Xera, Duo, Olympia and Xera Flashlight are in stock. That flashlight is a super little light. Same beam and output of the standard Xera and so small.
I have finish testing beam patterns and thermal performance. I'll get the pattern test up tomorrow. Thermal is about the same as previous models. In still air they slowly drop for the first few minutes but then suddenly drop to 10%. When they cool off they switch back to 100% but then cycle up and down until you get some air moving over them. With the increased surface area this should be no problem if you have any speed at all. But it's winter here so a real world test will be hard until summer.
Jim at Action was saying the 2016's thermal is pretty much the same as the previous years model,, I would say it's more like about 20% but still to low. So room for improvement.
I live in the Bay Area so it's never very cold or hot, at least at night. I don't think the temps here are anything for me to be concerned about. I ride with someone who has an older Duo and he never has had a problem with it either. Still, seems like something that should be addressed.
It's something that was never an issue for anyone that I've heard of unless they live in Arizona and were riding slow on a hot summer night. Now that the the lights have more surface area it should be even less of a problem.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
