Go Back   Mtbr Forums > Classic Mountain Bike Forums > Lights and Night Riding
Reply
LinkBack Thread Tools Display Modes
Old 02-04-2012   #76
Rep: Vancbiker will become famous soon enough
user gallery
Are you measuring that voltage under load? Most of the "budget" 18650s have a fair bit of voltage sag under load. That may explain the light shutting down when a no load voltage reading is 3.4V.
Vancbiker is offline   Reply With Quote
Old 02-04-2012   #77
Rep: claytonedge is on a distinguished road
user gallery
Argh! No, very good point! Thanks, will run the battery down a bit and have a look.
claytonedge is offline   Reply With Quote
Old 02-04-2012   #78
Rep: zarr will become famous soon enoughzarr will become famous soon enough
user gallery
tagged for future reference
__________________
songs: "Wind", by Circus Maximus
"Pendulo" by Egberto Gismonti
If the ride is 'mo fly,you must buy.- Snoop Dogg
zarr is offline   Reply With Quote
Old 02-04-2012   #79
Action LED Lights
Action LED Lights's Avatar
Rep: Action LED Lights is on a distinguished road
user gallery
Originally Posted by claytonedge View Post
My suspicion at the moment is that once either pair of cells drops below 3.4v the power from the battery is cut. This is a bit annoying since it's really 3.2v before we start getting any damage to these cells....but it could well be that the temperature we're riding in is influencing the cut off voltage.
claytonedge,
Here is a typical discharge curve for a 4400mAh 2S2P pack under load. Your light probably pulls about 1.5A on average so the red line would be about right. You can see that by the time it reached 3.4V per cell or 6.8V it's headed south pretty fast so the difference in run time between 3.4 and 3.2 would be pretty small. However, this test was on an assembled pack and ran down to 5.6V without the PCB cutting out. I believe the cutoff under load is 5.4V.
I don't know about your pack but the Magicshine and Gemini packs have a balancing lead between the pairs to monitor and charge each pair separately.
__________________
Jim Harger
Action LED Lights
www.action-led-lights.com
Action LED Lights is offline   Reply With Quote
Old 02-04-2012   #80
user gallery
Thanks Jim - very kind of you to post the discharge chart, and to share your experience.
On these batteries there's certainly no balancing lead between the pairs (I've attached one myself), but it is good that the fancier/pricier batteries do have some mechanism to balance the charging.
For others reading as well - the capacity of these cheaper batteries is more in the 3400mah region than the 4400mah....but I'm even quite dubious of this!
Old 02-04-2012   #81
Action LED Lights
user gallery
Oops, now that I look closer at the graph is see this particular test was with a 5200mAh Gemini pack. The shape of the curve is the same with 4400mAh, just shifted a little to the left.
__________________
Jim Harger
Action LED Lights
Old 02-09-2012   #82
user gallery
Updates here.
Full charge, cell1 4.2v, cell2 4.2v
Cut out after 90 mins of riding in freezing temps
Voltage, cell1 3.7v, cell2 3.7v both under 0.7a load.
After charging the battery normally takes 3400mah from empty, but from this cut off state only took about 1300mah.
It appears the protection circuit is cutting in very early when it gets cold.
Have ordered another battery, an rc type Lipo and will see how this goes.
Old 02-17-2012   #83
Rep: shellshocked is on a distinguished road
user gallery
Ordered the $60 ebay light and got it three days later from a US seller. I have to say I was very impressed with the packaging and the overall design. No short-cuts that I could see, OP reflector, etc... It has three light levels plus strobe. This is my first bike light but this thing puts out an incredible amount of light. I will ride with it next week. The only flaw I see with the light is the mounting bracket is designed to fit a thinner bar - not the 31mm MTB bar. Seems like it will work ok with the provided rubber band mount but not ideal.
shellshocked is offline   Reply With Quote
Old 02-17-2012   #84
Rep: hernluis is on a distinguished road
user gallery
just bought one
i just pulled the trigger on one with a smooth reflector. Hopefully i will get it soon. I did see that the ones from over seas are on sale and last time i looked about a 1000 had been sold they are going at about $42 shipped? not bad.
hernluis is offline   Reply With Quote
Old 02-17-2012   #85
Rep: fevans is on a distinguished road
user gallery
Originally Posted by J_Hopper View Post
I have an original P7 MS900 with the new, replaced-under-warranty Geoman battery. I'm having difficulty with the switch on the back of the MS900 (I have to push it very hard to get it to change modes, hard enough that it's difficult to maintain the pressure for 2 seconds to turn it off). I'm considering upgrading to the newer XML version. I'm trying to decide, is it worth it?
I've had this problem a few times with my MS light. The problem is that the retaining nut that holds the light puck in place inside the head gets loose over time.
All you have to do is take the crown off and remove the reflector to get to the retaining nut. It has two holes which are used to tighten it. You can use a pair of needle-nose pliers to do this.
fevans is offline   Reply With Quote
Old 02-17-2012   #86
mtb enthusiast
torreyaz's Avatar
Rep: torreyaz will become famous soon enough
user gallery
Riding with mine tomorrow AM in Az. Probably dark for an hour ride time. I charged it to green (about 2.5 hrs). It's maiden voyage and I'll report back on the performance.
torreyaz is offline   Reply With Quote
Old 02-21-2012   #87
Rep: nathan59801 is on a distinguished road
user gallery
Are most people using this light on their handlebars or helmets? If using on your helmet, is there enough cord to run the battery to a pocket on your jersey? If stuffed in you pack, does the battery get hot?
nathan59801 is offline   Reply With Quote
Old 02-22-2012   #88
Sourloter's Avatar
Rep: Sourloter is on a distinguished road
user gallery
I bought the exact same light about 3 weeks ago, for 38 euros. It's amazing! I am using it for about 2 hours and the battery can keep for more.
I haven't used it on my helmet yet, but i'm sure it's gonna be stable enough.
Sourloter is offline   Reply With Quote
Old 02-23-2012   #89
user gallery
Rode with my light tonight. Rode an hour on bright and no problems. The amount of light is excellent. Overall I am extremely pleased. If I had one change it would be to make the beam pattern a little wider as where I ride has a lot of tight switchbacks and with the light on the bars having more light on the turn before I actually turn the bars shining the light into the turn would be nice but it is still pretty good as is. Someone asked if the cables are long enough - short answer is yes no issue - I have the battery mounted on my seat post and the light on the handlebar and still have about a foot of extra cable.
Old 02-24-2012   #90
Action LED Lights
user gallery
Originally Posted by shellshocked View Post
If I had one change it would be to make the beam pattern a little wider as where I ride has a lot of tight switchbacks and with the light on the bars having more light on the turn before I actually turn the bars shining the light into the turn would be nice but it is still pretty good as is. .
See our Wide Angle Lens.
__________________
Jim Harger
Action LED Lights
Old 02-24-2012   #91
user gallery
Action: Thank you - I just placed an order with you.
Old 02-24-2012   #92
Rep: Mr. Lynch is on a distinguished road
user gallery
The wide angle lens from Action LED works great. I have one in my MS light and it was a perfect fit. On the knockoff MS lights all you have to do is leave the stock lens in place and put the wide angle on top. It then fits great and the light still seals nice.
Mr. Lynch is offline   Reply With Quote
Old 02-24-2012   #93
Action LED Lights
user gallery
I would suggest you put the stock lens on top smooth sides together with the ribs pointed into the reflector. The effect is the same either way and then the glass protects the plastic lens. This won't work on a true Magicshine as it won't seal with the added thickness.
__________________
Jim Harger
Action LED Lights
Old 02-24-2012   #94
user gallery
That's exactly what I did. wide lens, then stock lens on top with smooth sides together. It has held up great thru some really nasty conditions. I just listed the pieces wrong above, but anyone installing the lens would figure that out quickly!
Old 03-20-2012   #95
xycarp's Avatar
Rep: xycarp is on a distinguished road
user gallery
Just checking in to provide an update and some extra info...
1. Update - It's been pretty darn warm in Michigan the last few weeks and the light has been working much better. I am able to get 3 20+ minute rides out of it without recharging.
2. Extra info - The rubber ring that holds the light on the bars broke. It's an oddball rubber ring that I could not find in the hardware store. I am not surprised as I have been riding in some pretty crappy and extreme weather (like 7 deg F). I ended up making my own ring out of surgical tubing. That stuff is awesome. If your ring breaks, buy a few inches of tubing and make a ring. Not to mention the stuff is so strong it's worth keeping in your riding toolbar for misc trail repairs.
The light is working fine!
xycarp is offline   Reply With Quote
Old 03-21-2012   #96
user gallery
can you explain about the tubing.(more detail)
__________________
Old 03-24-2012   #97
user gallery
Introduction
Ok - I've done as much experimenting on this as I am likely to. I embarked on this as the light draws about 1A of current, and from a 4Ah battery I'd expect about 4 hours. When using this in the cold from Monday to Thursday, I would get about 2.5 hours. Admittedly this was in the depths of winter - when it's super cold anyway. This experiment is to try and understand what is going on.
First some vital stats on the light - current drawn at
A - high - 0.93A
B - low - 0.36A
C - off - 0.02A
Executive summary - the light draws a fair amount of current even when it's switched off. The battery performs worse when it's cold. The available capacity reduces the longer it is left in the cold.
Methodology - carried out three discharge tests - each discharging at 0.7a until the battery voltage dropped down to 6.0v. All tests were done discharging the cells individually by passing the protection circuits.
Test1 - charge battery to full capacity, and discharge at room temperature. This is the top line in the chart.
Test2 - charge battery to full capacity, freeze battery over an hour, and discharge in a cool box. This is the middle line in the chart. Temp started at 0c (32f) and finished at 4c (39f).
Test3 - charge battery to full capacity, freeze battery for four days, discharge in a cool box. This is the bottom line in the chart. Temp started at 0c (32f) and finished at 4c (39f).
Results
Battery will cut out at about 6.4v if left to its own devices.
Test1 - around 4000mah
Test2 - around 3700mah
Test3 - around 3500mah
Conclusion
When it gets cold - for several days - the capacity of the battery drops - even when it's not being used.
This in part explains why the performance of the light was impaired in cold temperatures.
Secondly - the light when plugged in, even without being switched on, draws 0.02A of current. The light on standby would therefore drain a fully charged 4Ah battery in 174.59 hours - about a week.
My usage of the light would see it operating over four days, a total of 2.5 hours on high - and a total of around 90 hours on standby. Thus - 2.2Ah consumed by the light while being used on the bike, and around 1.8Ah being consumed by the light while in standby mode.
Recommendation
1. Keep your battery warm to get the best power out of it.
2. If you want your battery to last longer - when not in use either unplug it, or manually install an in line switch and turn it off.
Old 03-27-2012   #98
Buddha43's Avatar
Rep: Buddha43 is on a distinguished road
user gallery
I have 4 of these batteries (disassembled) if anyone wants them. Pay shipping and there yours, PM me.
They have been charged 4 times.
Buddha43 is offline   Reply With Quote
Old 04-04-2012   #99
Rep: sc redneck is on a distinguished road
user gallery
I bought this light and gave it a 1 1/2 hour workout last night. It performed flawlessly.
Biggest bang (brightness) for the buck...
$32 shipping included off ebay.
sc redneck is offline   Reply With Quote
Old 04-04-2012   #100
Rep: mappable is on a distinguished road
user gallery
do you mind posting a link to the light and battery that you purchased?
mappable is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Thread Thread Starter Forum Replies Last Post
New True Fab Bike Pr0n (True Fabrication Bicycles, Austin, Texas) rearviewmirror 29er Bikes 30 12-13-2009 08:09 AM
Cento Bike Corp? To good to be true speedyd Where are the Best Deals? 2 11-21-2008 02:03 PM
Specialized Epic Comp 2003= $1100?? Complete bike TOO GOOD TO BE TRUE? gtbiker210 Bike and Frame discussion 2 04-27-2004 09:45 PM
My new bike, not so light, but so good :-))))) xc-rider Weight Weenies 20 03-22-2004 09:31 AM
Hot Deals
Latest Mountain Bike Articles
Latest Lights Shootout Articles
Press and News Articles
Interbike - Virtual Trade Show Booths
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
Search Engine Friendly URLs by vBSEO 3.6.0
