Results 1 to 3 of 3
    Idea! Yet another triple led...
    hey, the Blackburn System X is good for something...well, at least the mount is
    3 x SSC P4 leds
    bflex (v1)
    Oct 2007
    Quote Originally Posted by cytoe
    3 x SSC P4 leds
    bflex (v1)
    That looks great. Love the plastic backing , great use of the led and bflex mounted switch, very neat solution.
    How does the driver 'pod' attach to the main part of the housing?
    Also how is the optic held in? Are you not worried about it rattling loose? Makes for a really neat and small front end though
    Gawd Jawb!!!!!!
    Thanks...
    the pod is held in place by a set screw. The back end and the body are machined to fit (w/ a grove and o-ring between). That last picture is actually of a newer one I made, one piece. I'll post pics of it later.
    The lens is held in place using silicone...that lens isn't going anywhere...I know because removing it is a real pain.
