Results 1 to 20 of 20
    XPGQuiccpower now takes Regina
    Just an update our single XPGQuiccpower has been modded to accept the pins of the Ledil Regina
    Cheers
    WeLight
    Cutter Electronics Pty Ltd www.cutter.com.au
    A waste of time it is is
    Reputation: emu26's Avatar
    Is that both the 12.5mm and the 16mm versions or only the 16mm version?
    So...did you use different componentry on the board, b/c it doesn't look like the Regina could even set down on there b/c of that black "4R7" thingy-ma-jigger on the right?
    Randomhead
    it would be nice to have a little more information about the features of these devices
    Hi Guys
    Yes when we have stock of the new pcb with Regina mounts i will release a complete datasheet on it
    Cheers
    WeLight
    Quote Originally Posted by chelboed
    Yes new data and images will clarify the differences
    Cheers
    WeLight
    Reputation: znomit's Avatar
    Quote Originally Posted by WeLight
    Hi Guys
    Gonna have a regina friendly boring MCPCB too?
    Quote Originally Posted by znomit
    What size would you like to see?
    Cheers
    WeLight
    20mm is fine.
    Messing with them this week, looks like the alignment isn't precise once you grind the legs off.
    Bigger is better!
    May 2005
    20mm is fine.
    WeLight - any news on this?
    email went out early this week or late last week. From memory, and I would quote but sorry I deleted it, the 7 up is now available and the data sheet with the single will be available soon.
    Eagerly awaiting the triple, nudge nudge welight
    What? a 7up board with integrated driver is available at cutter??
    absolutely, here
    Deleted due doublepost
    Ohhh ok, thanks
    But imho this is not so useful as a bike light!
    Quote from Cutter page:
    Features include
    - Two modes all 7 or 3 central in a row. set by briefly interrupting the power. No real dimming why?
    - Can run up to 1000mA per XPG (this would be close to the max but you can specify a
    reasonable range when ordering)
    - Thermal regulation with dimming at 80C.
    - 11 to 20V operation
    - 8V operation at reduced power level (4 LED operating)
    - Same physical diameter as PL121xxx Khaotd optic with space for two M3 mounting
    holes.
    Customisation is available, subject to minimum order quantities Please contact us.
    This would include but is not limited to:
    - Under voltage shut down or reduced power mode. this would be great
    - Voltage warning with a blink. also a great feature
    - Different power levels. absolutely needed, three dimming levels high/mid/low with all leds!!
    - Flash modes. should not be incorporated (or available in an submenu so it does not interfere when switching the 3 standard modes)
    - A Red/Blue police/emergency version (often referred to as a wig/wag) With appropriate
    flashing mode.
    - Amber warning version.
    - Royal Blue/White for Coral Grow Applications
    So, the standard version is not suitable for us, what are the minimum quantities to produce a suitable light engine for us night riding folks??
    We are still fine tuning firmware so will update on the dimming issue soon
    Cheers
    WeLight
    Thanks WeLight.
    For my biking use the following are on the essential list:
    1) Adjustable dimming (reduced current = efficiency).
    2) Adjustable low battery shutdown.
    3) UI allows cycling between high and low without passing through either off or flashing.
    On my would-be-nice list are:
    4) 5S battery operation (ie 22V withstand)
    5) Some sort of low battery warning.
    6) A third very low power setting (press and hold to access?).
    7) Low power commuting flash.
    8) High power help/SOS flash.
    Hope this helps.
    I bet you need some beta testers
    Quote Originally Posted by Mark2c
    Thanks WeLight.
    Hope this helps.
    Great points Mark! I am in too!!
    +1
    WeLight - any updates on the 7up quickpower board?
