Results 1 to 23 of 23
    XML Bastid clone
    Hi again had this sitting on my desk for a week while on holiday
    An XML Bastid clone not Magicshine but dont know who yet.
    looks very similar but subtle differences .
    beamshots later tonight
    Dirt Deviant
    Reputation: savagemann's Avatar
    Thanx for the pics Trout.
    Waiting patiently for the beamshots.......I am thinking the XML will have a little bit more of a flood than the P7.
    Also, the ground wire soldered to the B- spot in the last pic kinda scares me.
    Look, whatever happens, don't fight the mountain.
    www.hahntronix.com
    Reputation: mhahn@hvc.rr.com's Avatar
    Looks like an incremental improvement in the driver design.
    R7 & R6 look like current sensing resistors (last photo). Still too small, they are 0805 smt packages so will get pretty darn hot. But having them both be .15 ohms will probably give an LED current of 2.67 amps, which is a bit more than the original bastid managed.
    The inductor, while not shielded is at least mounter on the PCB and not dangling in space.
    C1 looks to be a halfway decent tantalum capacitor, but I cant make out what voltage it's rated for. Would be nice if they put in something rated at 16 volts or more. It looks like a 1210 package, so it might be rated for 16 or even 25 volts.
    D3 looks like a SS34, which should be able to handle around 3 amps, up to 40 volts. It will probably still get pretty warm (not enuff copper around it to spread out the heat), but this is the first bastid-like light I've seen with a diode that had halfway decent specs.
    IC2 is probably the driver IC. Looks like it is labeled 5340, which may mean it's an improved version of the SM5241 used in the bastid, or some completely different chip. I can't find a data sheet for it.
    The button side of the PCB looks interesting (next to last photo). It has about the right number of components that it may be using the microcontroller (8 pin soic to left of button) do figure out the battery voltage. The original bastid used a voltage level detection chip which is why the battery level LED stayed on all the time. Is that still the case Troutie? The traces I can make out on the PCB make it look like the microcontroller might be a PIC (easiest way to tell is pin 8 will be ground and pin 1 will be around 5 volts). If the micro is a PIC I may break down and buy one of these since it will be pretty simple to change the programming.
    The quality looks a little bit better than the first bastid I tore apart, though the B- wire looks like it had a bit much stripped off it before being soldered down.
    Troutie, is the user interface any better?
    Mark
    Nimium est melior!
    May 2010
    Is it wrong to say I prefer the shape of the original? There I've said it.
    Reputation: HEY HEY ITS HENDO's Avatar
    lol @ MrLee
    ..and nice post Mark, very informative!!
    ...Scun.thorpe, UK
    Thanks Mark
    I was hoping you would see the thread and chip in .
    The story is Smudge was searching for battery bags and some how stumbled on a site that had stuff like that .
    he was then bombarded by emails about all sorts of stuff including this light which was about to come out she did say they were nothing to do with MS .
    so we ordered a couple of samples with a view that if they were any good we would buy a few to sell on .
    Smudge is pulling the battery apart soon to see how good / bad it is .
    Beamshots
    old P7 MS Bastid
    new XML No name Bastid
    MS Bastid
    new Bastid
    It has High / Med / low /
    wired to my bench supply at 8 volts it was pulling
    1500 ma on high but then it went down to 1380 as it warmed up the old bastid was pulling 1280 ma
    med 520 ma old 450 ma
    low 150 ma .
    it also had a flash mode
    similar user interface IE each press cycles through Hi/Med/low/flash/off / back to hi .no press for off .
    we did ask if the interface could be changed and she said yes if we ordered 500 units.
    Reputation: znomit's Avatar
    Quote Originally Posted by troutie-mtb
    Beamshots
    This looks much like the difference between my cheap P7 and XML torches.
    I think the extra OP needed on the P7 really hurts the beam.
    ....wired to my bench supply at 8 volts it was pulling
    low 150 ma .
    it also had a flash mode ...
    troutie, Thanks a bunch for the review photos and beam shot photos.
    Looks like the light head is a little longer to accommodate the longer reflector (?) Definitely looks to have more throw than the old MS.
    Now about the throw... .....how far away is that tree? Do you feel there is a significant improvement in throw over the old MS's??
    I'm a little confused though. You're saying you only measured 1500ma on high (?) Tell me it ain't so...
    Other people claimed the old MS pulled about 2400ma on high so I am completely bewildered.
    Right now I have only my P-7 torches to compare my XM-L torch ( C-8 model ) to and beyond a doubt,
    my C-8 blows the P-7 torches away when it comes to throw but then again it is using a
    rather large reflector which gives it a much brighter farther throwing hot spot.
    The C-8 draws about 2600ma at the cap.
    Quote Originally Posted by Cat-man-do
    The tree was about 50 yards away
    the current was what was coming from the power supply at 8 volts not what was coming from the driver to the leds Sorry I should have worded that bit better.
    yes it blows the old P7 bastid into the dust for throw and looks a whole lot better in real life than on the pics .
    I like its beam and so will most users I dont like the user interface and am betting it is why there are reports of switches failing as from hi back to hi is 4 presses on the old bastid would much prefer something like Georges Trio mode. and no flash
    www.hahntronix.com
    Troutie,
    Nice beam shots. The beam from the new nameless bastid looks very nice.
    Any chance you can buy just the light heads? These look like they'd be pretty easy to modify if the micro is something standard. If you see markings like you find at www.microchip.com, then it is probably a PIC. It would be pretty easy to gin up a new PIC with a better user interface.
    If the markings aren't clear (sanded off), when you get a chance, look at the voltage across pins 1 and 8 on the 8 pin soic on the button side of the PCB. If pin 1 (the one closest to the dimple on the soic, on the lower left corner of the soic in your picture) is between +5 and +3.3 volts and pin 8 (upper left corner) is ground, the chip is probably a microchip PIC.
    Assuming the current sense voltage on the driver IC is 0.2 volts (what it was in the original bastid) then a T6 XML would put out around 840 lumens, or maybe 700 lumens after optical losses.
    I am a bit disturbed by the current values you measured. The initial reading of 1.5 amps implies an efficiency of around 75%. 75% is pretty dismal efficiency, the electronics board will be dissipating around 3 watts. I would suggest heatsinking the electronics is you can.
    The reading the light settles down at: 1.38 amps, would imply a slightly better efficiency of maybe 82%.
    Mark
    Nimium est melior!
    Quote Originally Posted by mhahn@hvc.rr.com
    Troutie,
    Mark
    Took a bit of trickery to read the chip ended up brushing a bit of the wifes makeup powder on a bit like fingerprint powder .
    top line 12F675
    next line 1/SN103S
    bottom H Q ( or could be 0) B
    put the multimeter on the led wire and it read 2860 ma which settled down to 2700ma on hi as it warmed up
    900 ma on med
    260 ma on low
    will see if the heads are available though the battery pack seem to be OK and in a rubber case
    www.hahntronix.com
    12F675 is a pretty standard 8 pin microchip PIC. 1K worth of instruction space (1.75K bytes of ROM if you prefer), 128 bytes of eeprom (can be used to store last mode of light), and a whooping 64 bytes of memory. $0.90 in quantity 25 from digikey.com for the soic version.
    I might be willing to trade some custom programming for a couple of light heads and the email address of your source in China . A simple user interface with 2 or 3 modes, long push to turn off, and ability to remember last mode light was in would be pretty easy to program.
    With a slightly more expensive 8 pin PIC ($1.07 in quantity 25) it might be feasible to add features like user programmable light levels, optional flashing modes (done in a way that you don't normally have to cycle thru them when all you want is a light), user programmable low battery levels (handy for using light with a 9.6V NiMh battery or even a 14.8V LiIon battery for example), and other such fluff.
    What's the quality of the battery packs? Any chance they are more waterproof than the original bastid?
    Does the charger look decent, or more like the original bastid charger that got so hot I was sure it was going to catch fire?
    Mark
    Nimium est melior!
    Hmm, wonder if you could shove an LFlex in there (or get a new seat machined up). If you can get it lighthead only, swap out the driver, and hook up a nice little 1s2p 18650 battery... this might be a great little semi-custom job.
    Thanks for the teardown, It still looks to be low quality (although better than the P7)
    The clonewars continue...
    Reputation: BrianMc's Avatar
    The heatsink pill doesn't appear to have any tighter or larger contact area with the body that the old one, though the light being longer, it has a bit more air interface once the heat gets to the body. Unless cleaaned, no AA to help, either. So is the thermal path mostly unchanged as it appears?
    Reputation: Billabang's Avatar
    Just saw it on DX, I'm tented...
    Reputation: Ofroad'bent's Avatar
    Anybody know anything about the new "waterproof" battery with the MS clones?
    Quote Originally Posted by Ofroad'bent
    yes now know lots
    did a runtime test last night they say it is a 4.4 ah pack
    full to empty on hi. they say 3 hours. I got 2 hours 35 mins
    did the same with one of Smudges batteries and got 3 hours 35 mins. his was using samsung 2.6 ah cells so 5.2 ah
    they are in a rubber sleeve which seems not too dreadfull .
    www.hahntronix.com
    Troutie was kind enuff to forward contact info to me and I wound up buying 3 lightheads to see if these things are any good (Thanks Chris). The pictures he took of the electronics didn't look too bad.
    My short review of the lightheads I got is: save your money up and buy one of Troutie's lights (or one of mine ), or build your own. Any of those choices will be better quality than these lights. OK, so I may be a bit biased, since I sort of compete against these guys.
    Here's the longer boring review details:
    I bought 3 lightheads from a company named *st*r (will reveal name later, but if that pattern matches somebody you are thinking of doing a big buy from, please PM me).
    I implied that I would like to buy a lot of these. I wasn't lying. A lot of people come to me wanting to buy lower powered lights in the 400 to 1000 lumen range. I make some small ones in that range, but with the economics of building 10 to 20 lights at a time being what they are, I can't compete with the price of the Magicshine/Bastid lights. I'm probably going to stop making smaller lights. The amount of work I put into them means I make something like a dollar an hour building them
    If the quality of the lightheads had been halfway decent, I was going to replace the PIC on the back of the driver with one that could sense temperature and had enuff ROM for a decent user interface. With a bit of thermal epoxy and a way to regulate the LEDs output if it got too hot, I thought I might be able to sell these as low end lights and offer a longer warranty than most US distributors. I also figured selling them with NiMh batteries would get around some folks fears of cheap Chinese LiIon Batteries. And if somebody wanted LiIon batteries, they could always buy some of the "new and improved" packs avaialable from various distributors.
    I'm not sure advertising them as "Cheap lights made in China, but re-engineered in America to be more reliable and less explosive" would have been a viable marketing ploy, but it might have worked if the electronics were well made.
    When I opened up the lightheads my first thought was "Wow does the quality of the electronics suck." All 3 had problems like: cracked inductors, badly soldered parts, etc. On the board with the cracked inductor, I was able to pull the inductor off with my bare hands. I'm not superhuman , the inductor was never soldered down, it was being held in place by dried solder paste. I'm pretty sure this means you could buy one of these lightheads, test it on your bench, then have it fail while out on a ride because the solder paste eventually let go.
    Pretty disappointing for samples sent to a prospective distributor. They all worked, but one had annoying flickering on the low setting.If you buy any of these, you pretty much have to dis-assemble each one to see if it is any good. It really is a shame that the driver board appears to be so shoddily constructed. The design isn't nearly as bad as the original bastid.
    The drivers at least use two 0.15 ohm 0805 sized resistors (R6 and R7) for current sensing which is better than the original bastid. The current running thru each resistors is about 1.333 amps (the LED is driven at 2.67 amps, the bastid drove the LED at about 2.4 amps), so the resistors must dissipate about 0.2666 watts (watts = (I * I) * R). Thats kind of pushing it, but you can find 0805 resistors rated to handle up to 1/3 of a watt. 1/3 watt resistors cost around $0.50 cents each. 1/4 watt resistors cost maybe $0.15. 1/8 watt resistors cost about $0.05. My guess would be they used the cheapest ones they could find, but there is no way to tell just looking at the parts.
    They use a halfway decent diode, a SS34. That can handle 3 amps at 40 volts. I'd probably have used a 4 amp 20 volts diode like the MBRS320T3G. I like my diodes to handle more current than I think they'll see. The Magicshine/Bastid uses something undersized like an SS22.
    The input capacitor (C1) appears to be a 4.7 uF tantalum capacitor. I can't find who made it, so it's hard to determine it's maximum rated voltage, but I have found 10 and 20 volt capacitors that same size. My guess is it's a 10 volt cap.
    The inductors (coils) are nice looking, at least the ones that aren't cracked.
    The LED driver chip, labeled 5341D is almost surlely some variation on the SM5241, the one used in the bastid. The pinouts appear to be the same. I'ts probably got an input voltage range up to 36 volts. I googled for SM5341D but couldn't find a data sheet.
    The MOSFET (an IRF9410 8 pin soic) looks pretty decent. I hung a scope on the gate of the MOSFET on the driver board that seemed to work well. It seems to be switching the MOSFET pretty cleanly, so the 5341D chip does a decent job of driving the MOSFET.
    The 12F675 PIC (near the button) is being used to light the voltage LEDs, do PWM (pulse width modulation) to set the light level, and monitor the input voltage. Too bad the user interface sucks. As you push and release the button you get: high, medium, low, flash, off, high, medium, etc. I can't figure out why most of these cheap lights make you go thru a flasher mode when switching thru light levels. The 12F675 doesn't have a hardware PWM, so maybe the user interface (UI) sucks because the Chinese firmware engineers spent too much ROM figuring out when to turn the PWM output on or off and didn't have enuff room for a decent UI. They could have bought a slightly more expensive chip and fixed that problem.
    I'll probably put my sample lights back together with a 4 amp diode, a higher voltage input cap and some physically larger current sense resistors with a higher resistance (probably 0.2 ohms in a 1206 package). I figure you can run the xml at 2 amps and still get more light out of it than the bastid, you get longer battery life and hopefully the current sense resistors won't burn up. With a higher voltage input cap, you can probably run these lights on anything up to a 14.8 volt battery. I have a few friends running homebrewed four 18650 cells in series battery packs, who need a cheap backup light. I'll probably sell a couple to them and see how they like them.
    I might keep one for me. As Troutie points out the lights have a very nice beam. Too bad the rest of the light sucks.
    I'll try to post some pictures later this week.
    Mark
    thanks for the detailed review.
    most of them still think, they could squeeze by with one light.
    and anything new is cool, while 2x P7 is still better then 1 xml.
    Nothing really new, since we still need
    - better drivers
    - better housings
    - better battery protection circuit
    - better batteries
    - better battery housings
    - better chargers
    and to power 3+ LED's, everything needs to be in place.
    Still looking to design everything from scratch.
    By end of this year, there is going to be a lot more choices in the 2-3k lumen range,
    at least for the lights, the Battery pack availability is still needs to catchup .
    Since those things , going to need power.
    Would need lots of input and recommendations. I'am good with pcb design, not that good with circuits. The hardest part, like pulling teeth, is getting parts, some stuff, like the crappy zetex, can't even get sample parts under 100 pieces, the real good stuff, they want to sell you 3000. As a little Garage hobby guy, I'am broke, don't have a CNC ether , argh.
    Well, if anybody has a laundry list, of the 3 Stooges , Good, Bad, Ugly, + availability,
    maybe we could start sorting things out.
    cheers, Rob -> contact me for input , feed me
    mtbl.robs-x
    ...yes it blows the old P7 bastid into the dust for throw and looks a whole lot better in real life than on the pics . I like its beam and so will most users
    thanks troutie for the beamshots.
    the bastid's throw looks impressive, although the cri seems to be awful.
    could you commend on the throw of the bastid compared to other optics. (laura, regina ..)
    thanks
    reinholdus
    Quote Originally Posted by reinholdus
    thanks
    reinholdus
    Yes it has a better throw than Laura / Regina sharp spill cutoff like regina .
    very cold white led no indication of what bin .
    Good evaluation Mark Thanks .
    Like you I am staying away from selling crappy chinese imports or even making similar output lights to sell .( its fraught with all sort of issues look at Geomans problem )
    I managed to sell one of the samples I got for the price I paid and will keep the other as a point of reference in my archive of lights .
    ^^The thistle in the posey patch. what an archive...
