Results 1 to 6 of 6
    Aug 2005
    wiring up a cree mr11 kit help please!!
    hi there ive recieved kit from cutter but do not have any wiring diagrams ??
    can someone post or give me directions on how to wire everything up please!! from the battery to the switch etc etc.
    also my board with the leds on looks different to others ive seen on the net as it has a big hole in the middle as opposed to 2 hole for the wiring?? any ideas
    cheers
    steve
    Reputation: dnlwthrn's Avatar
    which driver board did you get? Go to www.taskled.com for technical info on the Fatman, Maxflex, nflex, or bflex. My MR11 kit (with Fatman) had two small holes in the middle of the board, and you could see the wiring traces from the LEDs that went from + to - fairly easily. If you can't figure it out, take a photo of it and post it here.
    Aug 2005
    my board is different to this picture
    http://www.cutter.com.au/prodimages/mr11wire.gif
    mine has just got a big hole in the middle??
    is it right??
    i can see a track that the leds are on and there are two soldered bits at the end of the track??
    ive emailed mark and await for his reply!!
    Aug 2005
    oh and its a bflex kit
    Not dead yet, just playin
    Reputation: ohpossum's Avatar
    Quote Originally Posted by renton
    is it right??
    The new PCBs (did you get R2s?) look different from the pic on the site. They're a bit thicker and have a big hole in the middle.
    If you look on the PCB at the edges of the leds, you'll see a tiny "+" sign on one side of each emitter. That is the LED+ lead. The pad that is connected to the + lead is where your LED+ line should be soldered. Make sure you wire the regulator correctly.
    op
    www.msmtb.org - Mississippi Mountain Biking
    relax
    Reputation: jeep's Avatar
    Sep 2004
    is it right??
    It's right, I wired one up last week.
    If you look very closely or use a magnifying glass you will see a + & - next to
    each solder pad on the MCPCB.
    Use this link http://taskled.com/techbflex.html to help you wire up your driver.
    It was pretty easy considering I have not much electronics knowledge.
