• 01-07-2013
    Bryank930
    What LED's in police light bars??
    What LED's do they use in police light bars? Those things are BRIGHT!
    I can't seem to find any info online, so I thought I'd check here.
    Anybody know?
  • 01-07-2013
    Leopold Porkstacker
    I started to research this back in 2008 when I started building my own bike lights, but the manufacturers of the different light bars don’t actually state which LEDs are actually being used in each unit.
  • 01-07-2013
    rideit
    A whole lotta crees
  • 01-07-2013
    brad72
    I was going to say red and blue ones ;)
    A lot of the 4WD bars I had seen even 12 months ago used the Cree MCE but I have no idea what they are using now. Remember also that even crappy blue leds seem really bright to us due to our perception of the colour spectrum.
  • 01-08-2013
    adrenalnjunky
    Safety lighting manufacturer Whelen seems to have their own line of LED's - but they don't quote who is making the emitters themselves. Although at the volume of product a company like that requires (they do every type of emergency/safety/motorsport lighting) - they very well could have their own factory somewhere cranking out product to their own specs.
  • 01-08-2013
    Surestick Malone
    Given that they are flashing, not constantly on, I wonder if they are being at a higher power consumption than they could take under continuous operation. There doesn't seem to be much effort at heat sinking them that I've noticed though they may just be built strong enough that there's a lot of thermal mass.
    The takedown and alley lights are halogen, not LEDs (though that may be a cost thing).
  • 01-09-2013
    bikeabuser
    I doubt you'd find a battery to drive the array :D
    911EP | Galaxy® & Galaxy Elite®
    http://www.911ep.com/PDF/Galaxy_Elite_Schematic.pdf
    Fuse = 35 amps + 12 amps per 100 watts of Take Down power for the large model's.
    Can't find the brand, but.............
    Math tells me the LED's are nothing special ... 62 total LED's, plus some Halogens (Take Down Power).
    35/62 = A bit over .5 amps per LED ... And I'm sure that includes a safety factor.
  • 01-09-2013
    sheepdogreno
    We will never give our secrets for our lights out!
  • 01-09-2013
    Surestick Malone
    The LEDs aren't all on at the same time, they alternate red and blue (and if memory serves they alternate sides too) so it should work out to slightly more than one or two amps per LED depending on if half (all the LEDs of one color) or a quarter (all of one color on one side) of the LEDs are on at once.
  • 01-09-2013
    bikeabuser
    You might be right, but.............
    The circuit has a fuse recommendation of 35 amps for the LED's ... If you turn them all on at once, the best they can draw is .5 amps.
    That would be borderline failure, and I see nothing in the literature and/or switch arrangement wiring that says you can't turn them all on at the same time.
  • 01-10-2013
    sheepdogreno
    all i can comment on is what i have...the whole bar is LED and my takedowns and alley lights are LED not halogen. Older LED bars did have different bulbs for the takedowns and alleys. I can set different patterns that fash both side at same time meaning they are all on at the same time. Super super bright and i love em when working busy highways...
    i know im new here and im just commenting on what i have. that said keep the cop bashing to yourself please...
