Results 1 to 10 of 10
    Jan 2009
    Vistalite 5w- worth modding?
    I inherited this light-
    i can't get it to work though. not sure if the batteries are dead, the bulbs are burned out, or both. anything worthwhile I can do with it?
    hi
    i would have a crack at fitting some leds
    If the light heads are made of ali, then you could mod your lights like Marwis. Battery packs could also be disassembled and rebuilt wit some LiIon cells regarding the dimensions.
    Jun 2010
    Not sure if it's worth it. Those lights were produced 8-10 years ago. The batteries will probably need to be replaced. The head units will need new LEDs. Not sure if the current driver will work with the new stuff. If you want lighter, more powerful, longer lasting batteries, you'll need a new charger and will probably make your own battery pack.
    If you're willing to mod this light, would you be willing to build your own light? You may end up investing enough time and money into modifying this light, that it would have been better to build a custom light, with all the features you want.
    There's an article here on the Vistalite 5W that might be helpful.
    Jan 2009
    meh, probably not worth the trouble then. if anyone wants this light and all the parts I have for it to experiment, i'll send it to you if you cover shipping costs.
    I'll take it all if you're willing to ship to Slovenia.
    I have an old 5w. Its not worth modding really. If it were me and the batteries worked, I'd source a LED bulb replacement. Tricky as they are mr11 fitting. Or if the bulbs are good, get new batteries and overvolt it.
    SANCTUS
    Reputation: BUSTELO's Avatar
    Feb 2012
    I have this light, retired it years ago since the batteries went out of production.Purchased this unit a few years ago and have not looked back.http://www.turbocatusa.com/products.html
    SANCTUS
    Feb 2012
    How much is shipping to Slovenia? I will give you what I have, the batteries were disposed of years ago.I will go up in the attic tommorow and confirm what I saved
    Dunno about the shipping. You'd have to ask at the post office.
    If it's not the entire set, I wouldn't bother modding it. I'd only take the light head, battery enclosure with all the cabling and remote switch.
