Results 1 to 6 of 6
    Upgrading my own DIY light from 2010 Cree XR-E to ????
    Hi
    I have a homemade helmet light that I really like. It is super light weight so I hardly feel it on my head.
    It currently has a 3021 Buckpuck driving a cree XR-e at 1amp that I built in 2010.
    I am out of touch with current LED technology.
    Can I replace the XR-E with something that uses the same optic Cutter Electronics
    and the same driver (running at 1amp) and will give me more Lumens?
    I will only be interested in reccomendations if I can the new led from either deal extreme or Cutter and that it comes presoldered to a 20mm star
    Many Thanks
    Richard
    May 2005
    You could go with the cree xpg or xpg2. You would get more lumens but get more flood in the beam pattern. I do not recall seeing anyone use the optic you linked on the xpg, but I think it would work.
    Reputation: Ofroad'bent's Avatar
    There is also an XPE2 which will give a narrower beam than the XPG.
    Thanks, I would like a bit more flood, so an XPG sounds good. Whats the difference between the XPG and XPG2?
    May 2005
    Quote Originally Posted by patrase View Post
    A little newer with a different substrate technology. More lumens outside of the cool white tint. Rated at higher temps. Tiny bit narrower beam.
    Quote Originally Posted by Vancbiker View Post
    And it can be pushed way beyond 1.5A that it is rated for.
  1. cree Q5 240 lumen zoomable light! for less then 10$
    By dugan661 in forum Lights and Night Riding
    Last Post: 02-15-2012, 12:30 PM
  2. cree Q5 240 lumen zoomable light! for less then 10$
    By dugan661 in forum Lights DIY - Do It Yourself
    Last Post: 02-15-2012, 12:29 PM
  3. 1st attempt at Cree XP-G LED Light
    By liv2_mountain_bike in forum Lights DIY - Do It Yourself
    Last Post: 01-21-2012, 08:15 AM
  4. KD C8 CREE XML T6 1000 Lm. - Bike light ?
    By heniekkrol in forum Lights DIY - Do It Yourself
    Last Post: 09-18-2011, 04:04 PM
  5. Custom-Built Triple Cree XR-E LED Light - Finished
    By achesalot in forum Lights DIY - Do It Yourself
    Last Post: 08-26-2009, 04:28 PM
