Results 1 to 42 of 42
    Reputation: Goldigger's Avatar
    The ugly remote switch
    Have to admit this didnt turn out the way i had imagined!! but should make you laugh..
    This was meant to be used with a quazzle 332 board, as you need two switches..
    biggest problem is finding a small water proof on and off switch that will handle the current draw from the battery..
    In my box of bits i had 2 3amp toggle switches.. and the new ip67 tactile switches..
    looking at this a remote switch for the 333 board should come out nicely as all it needs is the tactile momentary.
    I wont bolt the next one together, ill just use some glue to bond the cover on instead of the bolts!! not sure why i did that in the first place.
    just needs two holes in the side for this one.. for the 333 one hole for a 2 core cable.
    It will probably end up in the bin..i dont like them toggle switches, dont trust them to stay on.
    Reputation: bravellir's Avatar
    Nov 2008
    The toggle switch facing forward its a safety feature? Auto cut off if you hit something
    Quote Originally Posted by bravellir
    Yes, it made easier wiring if i had it pointing forwards or backwards.. you can mount the switch the other way round to..
    Rep Power Infinity +2
    Reputation: brad72's Avatar
    Ah Mate, form and function. In the dark you will never see your switch, you'll just be dazzled by how good your light is
    May 2005
    Nothing to laugh at there! A glued up version could certainly be smaller, but this one puts most other DIY switch housings to shame.
    Dirt Deviant
    Reputation: savagemann's Avatar
    Looks good to me GD!!!!!!!!!
    If you wanna se ugly, wait to see what I come up with after my tactile switches arrive from digi key....= )
    Look, whatever happens, don't fight the mountain.
    Looks Good to me Jay Your making that mill earn its wages .
    You know Jay you might need to get a production line going and sell the switch to all those who have the Quazzle board. Bit of pocket money to pay for end mills etc
    There easy enough to machine, delrin is like cutting frozen butter on the mill..
    If I were to make some would people want a bar mounted one or a slimline cable one..
    These ones would be just a single momentary switch to support the 333 boards..
    Doesn't look ugly to me. I'd be interested in a bar one for a commuter light I'm considering. I fancy a 'dip switch' by the grip that I can press with a thumb to switch high/low.
    If you can make a neat inline version you'll have a ready market on this forum, I'm sure. There are dozens of posts asking where to get them other than Batteryspace.
    Ok, ill come up with something, do you want the bar mount with the simply oring system?
    how long do you need the wire? 20cm enough?
    Momentary syle switch?
    I need to find some rounnd 2 core as small as possible..
    It will be simular to the one in this thread, but much smaller..no bolts and just the tactile momentary switch..
    Any thoughts?
    Cheers
    Quote Originally Posted by Goldigger
    Any thoughts?
    Cheers
    Cheers Jay
    For me, O-ring mount, 20cm cable and momentary switch would be perfect. Others with wider bars might need a bit more cable, I guess.
    For cable, this is the 3.35mm 2-core I was thinking of using as power cable for a helmet light. Shame they don't sell it by the m. There's enough here for 500 handlebar switches!
    http://www.rapidonline.com/sku.aspx?...catref=02-0260
    Does anybody know of a glue suitable for bonding delrin to delrin?
    I read that its a difficult material to bond together
    Maybe this loctite super glue will do it?
    http://www.loctiteproducts.com/p/sg_...el-Control.htm
    How's this for MK2, do you think this is small enough?
    meep meep !!!
    Reputation: Road_Runner's Avatar
    If you can make the Mk 2 version screwable / unscrewable with let's say mini allen headed screws please mate, then I would certainly be interested in buying a few from you.
    I've just had a remote momentary switch die on me due to pitted contacts, so the ability to replace the switch component without wrecking the housing would be very useful indeed.
    Dirt Deviant
    Looks awesome!!
    Looks spot on to me. I agree that small countersunk screws might be better than gluing, unless that makes manufacture harder
    May 2005
    I make my switch housings from ABS. Machines quite similarly to Delrin, but is easy to glue. It also bonds better to silicone if you need to seal the cable entry.
    Only problem with screws is that it will add to the size..
    This is using 1.6mm cap screws with 3mm heads..very tight!
    EDIT...SORRY MADE A MISTAKE IN MY DRAWING..NOT TO BAD WITH THE SCREWS/BOLTS
    FIRST DRAWING AMENDED FOR ERROR
    I do a lot of work with acetal that is very similar to delrin. I haven't had too much luck gluing parts that have a load on them so mostly I will weld the 2 pieces together with a soldering iron.
    You could try loctite 770 primer to prep the surfaces then use some loctite 406 (Cyanoacrylate). Clamp together in a vice overnight and see haw that goes. You have no load on the parts being glued so it should work.
    Dec 2010
    Very tough plastics to bond. Probably not possible. You might try Devcon Plastic Welder. It is a cyano-epoxy. At least it works well for solveable plastics like ABS.
    I have posted this in another thread.
    Made from a DX keychain light and a silicone cap. Glued to a velcro strap.
    CNC LED light housing for DIY projects
    meep meep !!!
    Quote Originally Posted by zemike
    That is an astonishingly good idea!
    I have all the components needed to make one of those.
    Thank you very, very much.
    After much fettling MK2 has arrived..
    Looking good. How wide is it?
    Went wider than the drawings.. 18.5mm gives more material to seal the cable..
    I trimmed a base to 14mm, it looked to narrow, and was narrower than my thumb..so didnt feel nice.
    meep meep !!!
    Excellent work Goldigger, it looks really good.
    Will these be available to buy in the near future?
    Quote Originally Posted by Road_Runner
    All depends what people are willing to pay for them.. to cover my time and materials
    There fiddly little buggers to make..
    I did make more than one..
    meep meep !!!
    Does a tenner a pop sound reasonable?
    I'd take a couple off you if that was the going rate.
    PM me if you would be happy to transact.
    Let me give it some thought.. i still need to source some suitable cable to factor into the costs..
    Needs to be nice and thin.
    Or i can supply them without cable, but you may have to drill the hole wider then what i drill them out as..
    plus there is the sealing it up.. Im going to use sikaflex EBT adhesive.
    When would you want a couple by? Im on holiday for most of feb, so not a great deal of time to make a run of them at the moment..
    Looking there GD. All you need now is a migrant or two set up in your spare room pumping out 1000/day. 2c per hour wages, a bit of bread and water and you'll be away.
    As for your cable a 0.25mm≤ 2 core flex would be perfect. I use this for controlling my lights as I always have heaps left over from automation sensor installation. Outside cable diameter is only 3mm so nice and small plus being flex it is very hard to get a break in the wire. About the only downside is that it's almost always grey.
    meep meep !!!
    No rush mate, take your time and let us know when you're ready.
    Have a nice holiday, in any case.
    Nice build!
    On the photo I see a sweet spot for a remote button - on the brake clamp.
    Anothr idea - use the Delrin base and for the top - a glued DX silicone cap.
    I added in some cable paths, just need to drill the correct sized cable entry hole (on the left) to match the cable that i still need to find for it.
    cable path is minimum 1.4mm wide by 0.75 deep so should be fine for the tiny wire needed for the momentary switch.
    If anybody wants any of these please let me know, so i can get some numbers.
    I'll see what it will cost me to get my mate to knock up 100+ of them on CNC
    I'm estimating £10-£12 each..
    For 100 pieces ?
    BTW anybody knows what's inside a Magicshine remote switch and whether it is waterproof?
    For 100 pieces ?
    the key word was in my post you replied to..each..
    Just to clarify that is for a complete switch, not just the housing.
    That includes
    bolts
    sealant
    cable
    IP67 momentary switch
    my time assembling it.
    To be honest it takes me more than an hour to make one, i wont work for £10-£12 an hour.
    sounds like a pretty reasonable rate to me. I'd buy one if I wasn't an inveterate tinkerer too
    Quote Originally Posted by brad72
    Brad, i tried this superglue http://www.loctiteproducts.com/p/sg_...el-Control.htm
    had some in my tool box..
    It works perfectly on small stuff, i cannot get the two parts apart..dont know what it will be like on bigger items that take constant strain.
    Excellent GD. As the superglue you have is Cyanoacrylate based it should work pretty well.
    Go faster!
    Reputation: sergio_pt's Avatar
    Hey doers
    I've been searching for a cool mini remote switch with status LED... with no success.
    Anyone seen something like that?
