Results 1 to 20 of 20
    Two simple MC-E tube projects (on process)
    It's my first project topic on MTBR, but not first at all. Want to share with you two simple housings maded from square tube 40 x 60 x 2 mm and 40 x 80 x 3 mm size. I don't have mill/lathe, all parts handmade.
    I don't know english wery well, so little words, more pics
    1) Idea taken from old good Achesalot design with some improvements. Battery & driver comparment maded from 40 x 80 mm tube. Front/side part from 40 x 60 mm.
    Cutted main parts
    Together
    Some grinding, filing, drilling
    With part of mount
    2) This project uses famous DX E27 bulb case. Box maded from 40 x 60 mm sized tube.
    Grinding/filing work already done.
    Some parts in place (voltmeter + button + DX cases)
    So many holes needed for ON/OFF switch, charger 4-pin connector, voltmeter, momentary button for voltmeter. One hole missed - for external mode switch.
    Wait for your opinion )
    Sorry for my eNgLisH )
    May 2005
    You need a new user name. TubeMaster comes to mind!
    Not all my lights made from tubes )
    Reputation: yetibetty's Avatar
    Look forward to seeing it finished, I can see that you have put a lot of work into it so far.
    Amazing....
    You must have alot of time in all that grinding and sanding. Beautiful lights......
    Thanks for sharing.....
    PRETENDURO
    Wow, very nice metalworking going on there! I have made several light housings which utilise those E27 heatsink shrouds, and they are capable of providing plenty of passive cooling potential (7MPH+ speeds) for MC-E setups. Running XR-E LEDs is not even a concern; plenty of surface area to dissipate heat without any static airflow involved.
    QUOTE from MTBR.COM: You have given Brewtality too much Reputation in the last 24 hours, try again later.
    Dirt Deviant
    Reputation: savagemann's Avatar
    Nice work!!
    Very creative with minimal tools.
    I like it alot.
    Look, whatever happens, don't fight the mountain.
    Very nice.
    The idea of using voltmeter display is brilliant for lipo-protection
    Not my idea, but thanks ) DX Voltmeter http://www.dealextreme.com/p/digital...c-models-20024 + some polishing
    Thnx for the link.
    Yet another LiPo protection method http://www.dealextreme.com/p/11-1v-b...licopter-35609 But it VERY loud, i fear it a little
    Reputation: bravellir's Avatar
    Nov 2008
    Very nice work. True Craftsmanship. Those parts are matched without any gaps at all. Very well done.
    Second project completed !
    4x 18650 Sony batteries, 2200mAh, in 2S2P scheme.
    2x MC-E K-bin "neutral white", each connected in 2P+2P. Two cores (high row) from first MC-E serial connected to two cores (high row) from second MC-E. Low row cores - by analogy, in series.
    2x drivers based on MBI1801, each adjusted by 2 external resistors - first for 350mA and second (external switch) for 1440mA.
    Two external switches can run high and low row of diodes independently. Simple version of "High" and "Low" beam, like auto )
    More pics to go:
    No free space at all. Black switch on bottom left switches battery between driver and external charge/balance connector.
    In upper right corner - switch for voltage meter. In lower right - charger connector.
    With enabled voltage meter
    Bottom view
    All for now, first project coming soon )
    PRETENDURO
    Very nice! Looks waaaaaay more professional than my setups that use the same heatsink housings and MC-E LEDs.
    Thanks )
    May 2010
    Electron must be worried about their mount designs - so many people are buying "replacements" ;-)
    Nice hand made craftmanship. Does the high/low work out to be good for the road?
    Still need to verify how it feel on a road. Maybe I can in 2-3 next days, bad weather in here.
    On white wall it is noticeable high or low beam is used.
    Did you use the default optics from DX E27 bulb?
    Quote Originally Posted by klynk
    I try to use default DX optics and three other:
    http://www.dealextreme.com/p/35-6mm-...ic-5-pack-4544
    http://www.dealextreme.com/p/35mm-16...s-5-pack-12437
    http://cutter.com.au/proddetail.php?prod=cut1072
    My choice Ledil EVA XM-D, very good beam and high/low beam separation
