Turnigy battery
Any benefit to using a Trunigy battery vs just running some 18650's like Trustfire's? I have several Trustfire set up 4S1P without protection, looking to build another pack. Currently using a 4 x 18650 holder from digikey
the 4S Lipo packs are available in different capacitys
and they are ready with a balance lead
the main problem with 4 x 18650 in 4S, is if you need slightly higher capacity to get a longer burn time
then you have to add another 4S in parallel .. 4S2P = 8cells
of course the problem gets worse if like me you run 6S battery pack,
so i run a 6S 3Ah Lipo
Rolling on 650b
I started running a 5s 4000mah earlier this year after having problems with my 18650's. I wouldn't go back. Quick and easy charging with the hobbyking balance charger, no more taking cells out to charge, and its proven to be extremely reliable up to this point. I had many occasions on a ride where the self protection on a trustfire would shut the whole pack down, and I'd have to rely on a backup to get out of the woods. My current pack is a bit of overkill, but now I sometimes get two night rides in before I have to recharge. I'd say go for it! I also have a 4s1p 18650 pack I use for my helmet light, so far it has been o.k., but the moment it hiccups it'll be replaced with lipo.
I use 4s 5000mah Turnigy lipos for my lights. Work great, easy to balance charge, no problems at all.
Hi
How do you get on with no low voltage cut off using the lipo packs?, i've got a few packs i could use and am interested in how others have got on.
cheers
stevext
Rolling on 650b
I'm using a bflex, which has a programmable cut off.
Pioneer
could connect a volt meter to the balance plug to monitor the cells
 Originally Posted by stevext
Hi
cheers
stevext
And i'm using a maxflex which also has voltage monitoring.
- You may not post replies
- You may not edit your posts
Forum Rules
