Results 1 to 6 of 6
    Code Burr
    Reputation: thebronze's Avatar
    Turbo Cat LED Cree upgrade
    My turbo cat helmet mount was pretty lame compared to my cree homebrew. Even with a 12v upgrade NIMH 4800mah battery. So when I saw this on DX I couldnt resist = "3W Cree, Regulator, Reflector 1x18650 2xCR123A Module Set, 900mah, $11.95 , Takes both CR123A and 18650 batteries (accepted voltage: 3.6V ~ 9.0V)
    - Cree P4 emitter
    - Orange-peel aluminum reflector cup for even and smooth beam
    - 900mAh regulator board installed beneath the emitter (3.6V ~ 9V input)"
    I pulled the mr11 out of the TC, soldered in 2 wires to the back of the heat sink, then soldered the wires to the connectors. 10 minutes and a little liquid tape finished the job. Running on a 3.7v Li Ion the new light produced a super bright spot that was probably 2x as bright as the old 12v halogen without the yellow wash out. I think the li ion battery is probably 2 pounds lighter.
    Just for comparison, I put this mod up against my Fenix p1d and its a bit brighter but it has a much bigger spot. I think the larger reflector in this kit really helps. I will be upgrading to a 7v batter and will post those results.
    http://www.dealextreme.com/details.dx/sku.1447
    For anyone out there using MR11's, this is an exact fit. If it fits in the super slim turbo cat it shoudl fit in your setup.
    One Gear
    Reputation: .40AET's Avatar
    Did you try the light with the standard TC battery? I know that the Li Ion batteries are a lot lighter, but I was wondering if the existing ones would work?
    Code Burr
    Quote Originally Posted by .40AET
    I've never used the turbocat battery. I bought the light mainly for the housing which was immediately upgraded to a 12v nimh 20w system. That still didnt put out enough light for me so I kept fiddling with it. I think the battery I received with the light was a 6v sealed lead acid . That battery would work just fine with this upgrade but it weighs about 3x what the 3.7v li ion does and lasts maybe half as long.
    t
    One Gear
    Thanks, I ordered some Li Ion batteries and the new Crees to start the changeover. Lugging the macho battery around has always been a PITA.
    Can you post a picture of the TC light with this module installed? I have two trailguides that is a great candidate for this upgrade. Beam shots please too. Thanks.
    Jan 2005
    I went to the CX website and read the reviews. Iwouldn't recommend this to anyone. If it's assembled with hotglue it's going to fail.
