I've been working on a new design as I've been a bit bored at work this week...it's going to be a Triple Triple XPE. It's only in the early stages of design but I'd appreciate any feedback regarding the design, optics, driver etc.
The pic is just a screenshot from my masterCAM drawing
Here's the good bit ( I think)....the 2 pods on the side are going to be rotateable so that the beam can be customised for angle. By using different optics you shoud be able to get a really good beam pattern that would give a nice flood (using a wide or elliptical optic) good miidle light (using a medium) and nice throw with a narrow...
That's a wild looking housing D! Are the side pods adjustable only up and down, or ball-and-socket style for any-angle adjustment? I've been thinking about a triple xr-e design with vertical adjustment on the outer two leds, but it's not nearly so exotic (no CNC mills in my basement).
Thanks :thumbsup: How did you get on with the other housing? At the moment, the housing is approx 90mm wide, 40mm high and 50mm deep. As it's just the initial design, I'll be looking at reducing the size (if possible) and trying to save some weight. Mind you, I don't even know how much it will weigh yet :madman: so it may already be superlight once I get to machine one.
I'll add some more info once I've got the prototype done. Need to place an order with cutters though...
mmmm yummy ... please sir can i have 2 of those squarey roundy middley bits in one piece
a dooble triple, run 6 series on a nFlex with a 6 cell battery (big bright, big runtime)
mount at back switch on top, dc in bottom glass lens protect the optic
black ano ............ `kin killer light :thumbsup:
I've had a chance to do a bit of machining on this little project. I've still got the side pods to make but have a look and let me know what you think :thumbsup:
If you think it's small now you should see it once I've made it smaller....:thumbsup: I reckon I can loose about 20% of the current size! It's just a prototype at the moment so will see how it works once I have enough dough to order some LED's and optics from cutter...I reckon it could be good!
I initially designed it around the hipFlex but as the maxFlex will do fine, I'll be able to make it quite a bit smaller. Just need to get on the lathe so I can turn the side pods.
You'll be 1st on the list if I do a few to sell
womble: I'll be using a 15v 5.4aH Li-ion, driven by a maxFlex
racerdave: You DON'T have to buy one I've really got the bug now...I guess I'm a bit like troutie, I spend a lot of time at work sketching out possible options on what would/wouldn't work. I reckon this one will...and the adjustable beam angles should work really well too.
I've had a bit of a play on my CAD/CAM today and have managed to shave 2mm off the outer size. That takes it down from 40mm to 36mm. Should save quite a bit of weight, the centre body was 110g (with screws/switch and a dummy maxFlex in)
It has a max output of 1.2 amps, so if you are going to parallel the three strings you will only be able to give 400ma to each LED. It would think your housing will be able to cope with more heat than that! :devil:
If you are going series, then it is a massive Vf and will smoke the maxflex.
Just thinking about how bright this could be if they were all running at 700ma :thumbsup:
If the maxflex isn't upto it, what would you recommend? HipFlex?? The electronics side of things is where I go wrong :madman: Still a newbie in that respect
It is a very interesting concept and I am thinking it would lend itself to using a quad in the centre and 2 triples in the outers . this would then give you the even number to split in to two strings .
But I like the concept of 2 drivers here 1 for the quad in the middle and 1 for the outers
so you can have either on at any one time . so maybe a controlable driver for the centre
and a cheap dumb driver for the outers
i think your original plan of a hipflex would be the winner for a triple triple. Run it at 2A with the strings in parallel to give 666ma per LED. The vF would be sub 12V so you could comfortably run it off a 14.8 bat.
got to agree, this is the easiest, brightest, most flexible approach, steve can you hear us!
and hey remember you `could` crank it up to mach 2.8a :thumbsup:
If it is possible to change the design I would like to have the freedom to choose between the setup suggested above by Troutie http://forums.mtbr.com/showpost.php?p=5499283&postcount=19 (quad center + 2 trippel pods) and two driver boards
But also room enough for a hipFlex as suggested by salty above.
(Then I would only have to make my mind up on wich one to build....)
OK, I hear you all...looks like it'll be a hipFlex then :thumbsup:
Will need to have another look as I've modded my programs to take a max but shouldn't be a problem modding again for the hip.
Hakan: It does sound like a good idea but I reckon I'll get the triple triple working 1st. Then have a look at doing the quad centre/triple pods with 2 drivers....
Sinple... i don`t believe there is/was or ever will be a problem!
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
