Results 1 to 38 of 38
    Apr 2013
    Triple Cree MC-E HomeBuild FD-1
    very cool designs been created by all you guys, i've been watching this thread from the shadows
    One of my ideas (Non-CNC devised), oh yes i have more.....
    Ive got the engineering part of it sussed (see pic)
    but its the electrickery im undecided on. i'm running three CREE MC-E's giving me in theory 12 adressable LED's (4 per die)
    what i use to run them and how i wire them up i was hoping that you guys could advise. I've got 6x18650 cell pack built, its just the driver and wiring i'm out at the decision point on
    enjoy....
    will now duck for cover as the comments come in......
    edit:
    and no its not a prop from flash gordon movie..... :P
    May 2005
    What configuration is your 6x battery? That will make a difference in getting good advice about drivers and wiring schemes.
    Apr 2013
    Quote Originally Posted by Vancbiker View Post
    Currently it's 3 sets of 2 cells and that's only due to the battery pack I removed them from had them paired that way.
    so I'm open to suggestions.
    with the cavities in the light I can either run 3 el cheapo drivers or plump for a nice hi current one and revise my mounting arrangement for the driver. But being full Ali construction it's hopefully going to run cool.
    No talent hack
    Not a bad idea for a light body for a non-CNC fella... I have the body and slug set for one of my own from a single cheap flashlight sitting on my desk.... just need to put the LED and driver in it.
    2013 Specialized Camber Comp
    2014 Trek Domane 4.0
    2015 Surly Karate Monkey Ops (the commuter)
    Apr 2013
    Built with very few tools
    The red cylinders came from my lathe days and I found the Ledil 20mm square optics with the corners removed fitted snugly.
    I've got the mc-e stars bonded to Ali slugs already with cable tails.
    I will post more pics of the build when I get them off the camera.
    This is one of those builds that's evolved as the creation gets made. I've got a finned disc to sit behind the front plate to increase surface area as those three mc-e's will get warm.
    May 2005
    Quote Originally Posted by Carpathia View Post
    Since I am a big fan of the Taskled drivers, I'll recommend the HBFlex. Wire your batteries in a 3S2P configuration giving you 11.1V nominal. Wire your MCEs 4S3P. At 3A you'll be running each MCE at 1A and a Vf of ~14.5. Depending on how your heat dissipation is you may need to set a lower maximum current.
    Apr 2013
    If I understand that right it's going to be a 5 cell battery pack although I'm confused on the LED wiring 4S3P
    Is that split across three dies? I could wire one die as all series but then 3P?
    It's been a long night and the grey matter has had it's time sorry to ask the daft questions
    A scribble will suffice
    Thanks all for your time
    edit, added pics of build
    Triple Cree MC-E HomeBuild FD-1-photo-4.jpgTriple Cree MC-E HomeBuild FD-1-photo-1.jpgTriple Cree MC-E HomeBuild FD-1-photo-2.jpgTriple Cree MC-E HomeBuild FD-1-photo-3.jpg
    Star on alu slug, skeleton frame pre-welding, side shot of skeleton, alu slugs
    May 2005
    That MCE is not the individually addressable style, it looks like a series style, though it could be a parallel style. If it is series, this is how I would wire the batteries and LEDs using an HBFlex driver.
    Attached Thumbnails Attached Thumbnails Triple Cree MC-E HomeBuild FD-1-mce.jpg
    Apr 2013
    Part codes for the led's i have are
    XREWHT-L1-0000-00C01-MCSTAR
    And
    MCE4WT-000M01-STAR
    And going from Cree data sheet they appear individually addressable. Although the sheet doesn't define that so I'm not so sure
    http://www.cree.com/~/media/Files/Cr...g/XLampMCE.pdf
    May 2005
    The MCE itself is individually addressable. The type of star it is soldered to determines the configuration. There are parallel and series configurations of stars. These are easily identified visually as they have either 2 or 4 solder pads only. The individually addressable star is identified by having 8 solder pads.
    Killer b.
    Reputation: The Understater's Avatar
    FWIW I really like your design.
    Very cool.
    Posting on the basis that ignorance shared is ignorance doubled.
    Apr 2013
    Looking at the mc-e they have four pads
    Two of the pads link together onto the same pin
    Pos is on top right chip pin
    Neg is bottom left chip pin
    thanks for the like of the design, not bad for a cordless drill a file and patience of a saint
    No talent hack
    Love the slugs. The copper slug was the best I could do without a mill or lathe. You got any spares?
    May 2005
    That means the stars you have are configured in a series connection. That is the same as in the diagram I posted earlier.
    Apr 2013
    Quote Originally Posted by Knight511 View Post
    im sure I could lay my hands on some, can always make some more to order
    if you have cad dimensions sling them over
    forgot to mention, the slugs are undercut at the back for additional surface area too
    Apr 2013
    Update:
    Battery pack is built, 3p2s 6cell battery with the "Tamiya" latching power connector removing the issue of reverse polarity
    Apr 2013
    As some of us are running "non-standard" battery packs, are there any recommendations on what I should use for charging as its from my understanding Li-ion are not suitable for your average charger?
    Any suggestions welcomed.
    May 2005
    Update:
    3P2S setup is less than ideal if using 3 series MCEs and a boost driver. 2P3S would be more efficient.
    Get a hobby charger from someplace like Hobbyking. Turnigy Accucell 6 seems a very nice unit that can be setup to charge just about anything.
    Apr 2013
    Sorry my bad on the typo, it's set up as per the diagram, 3 sets of 2, throws out about 11.2v.
    wow the turnigy looks a nice peice of kit, comparing it to the Chinese chargers there looks to be more tech in there that "cares" for the batteries. The plug top versions look basic and I have my concerns that they wouldn't be good.
    are they available in uk?
    May 2005
    The I believe Hobbyking would ship to UK. The Turnigy is Chinese too. Quality seems quite nice in spite of that. I have only used it a couple times now. I have been using Ultrafire WF139 chargers for about 4 years now and they have worked fine too.
    Apr 2013
    Ive seen those ultra fire chargers they look good, although they are geared for the multi cell plastic skeleton holders that allow each cell to be charged independently.
    i might go down that route as I can pick up a cell holder cheaply, plus any cell failures can be easily removed.
    wow, now that is what i call a unique light. After a few years on here it's easy to get complacent, thinking that you've seen all there is, and then something completely different pops up! I really like it - looks very retro futuristic
    It's a shame that they're not parallel wired, then you'd be able to do a master-slave set up with cheap AMC7135 boards. There might be some other, smaller boost drivers that would work - International.Outdoors sells some, check out the DIY section on Budget Light Forum for reviews as a fair few people have used boost drivers on there.
    Apr 2013
    Quote Originally Posted by mattthemuppet View Post
    I take it your relating to the Cree chips or the batteries?
    at present batteries are not fully enclosed so a master / backup is still feasible with half the capacity, but academic to run it that way.
    If its the Cree chips, then I have the ones that are not individually addressable so that scuppers it.
    i did look at the cheapy driver boards on ol' eBay but as someone recommended the taskled units as they seem to be longer lasting.
    has anyone had good / bad experience of the cheap boards?
    I do have some concerns on the heat dissipation of the cheapy boards as although I'm not sure of the total surface area all heat emoting devices need bonding to the chassis and last thing I need is dry joints from the Chinese drivers.
    yep, the LEDs - there a lots of choices for running 3V LEDs from 3.7V li-ion packs, it's when you get into the more complex set ups that choice goes down. Not a big deal as Taskled drivers are very good, just large and expensive. If you end up making another light in the future, the Nanjg boards that DrJones on Budget LIght Forum programs and sells are very good and a fraction of the price of the Taskled drivers.
    the cheap chinese drivers are fine physically, it's just more of a lottery what UI, modes and PWM they use. I've used a few and have been perfectly happy with them for what they are.
    Apr 2013
    I ended up going for the eBay drivers to trial the project out, I can always upgrade in the future.
    i did toy with the idea of getting a triple light set on eBay and changing the "head" so most of the electrickery is easier to integrate too
    Correct me if I'm mistaken, but it sounds like your batteries were pulls from something like a power tool or a laptop. If so, it would probably be a good idea to separate them so you can monitor them individually. (Some can fail to hold a charge or have high internal resistance, and you don't want those in series.)
    Just as an example, I got some pulls recently that charged up perfectly well and maintained a charge, but a couple of them get really hot during charging (pila ibc that doesn't mistreat any of my regular batteries), which suggests high internal resistance and prompted a quick trip to the battery recycler.
    Beyond that, nice looking build.
    The study du jour: can one's reputation be artificially inflated by simply putting a request for rep in one's sig?
    Apr 2013
    You are correct, the batteries were rescued from a laptop battery pack, I'm still looking for a li-ion charger for the 18650 cells that sit within. Might scour eBay for a solution.
    Apr 2013
    Recently got the driver board from ebay
    http://item.mobileweb.ebay.co.uk/vie...d=261171202259
    One of the cheap Chinese drivers.
    Have any of you guys fitted these with the remote on / off switch?
    Also are there any recommendations for chargers for our bespoke cell packs as I have also seen the Li-ion cell packs with matched chargers.
    Attached Thumbnails Attached Thumbnails Triple Cree MC-E HomeBuild FD-1-image.jpg
    Last edited by Carpathia; 07-22-2013 at 01:28 PM. Reason: Hyper link to product was kaput
    Apr 2013
    Before I get the chants of I told you so. Upon wiring up the circuit and putting a fresh charge into the batteries it looks to produce a relatively Dim light via the driver. Currently everything is onboard on the driver board with only wires coming off to switch, power and the three Cree mC-e.
    Have any of you had to fit any external variable resistors for brightness with the drivers?
    May 2005
    The driver you linked is no good for your series wired MC-Es The Vf range is not high enough.
    Apr 2013
    Ah, not quite what I had planned.... At least it explains things.All Is not lost I am also building a lid mounted version so it can drive a single xr-e.
    What would the vF be for the three MC-e's?
    Also what driver would be suitable from eBay.
    May 2005
    That driver will kill an XR-E. Use an XML with it.
    The Vf of the MCEs you have is ~14V.
    I don't know anything about drivers from ebay so can't give advice there.
    Apr 2013
    Happy to go grab a XML and throw it in there. Will save it for the brain bucket build.
    What intrigues me is the driver is said to be suitable for mc-e yet the forward voltage is nowhere near.... 5-12v??
    i assume some voltage drop or boost is employed to get to the elusive voltage?
    the solution I can see to that is revising the power pack to suit as 6x 18650 in 3 pairs won't give that (currently 11.1v)
    It appears you are confusing input with output. As I read the poorly written specs on the driver you linked to it is a buck driver - 5-12v input, output 2800mA at an unstated voltage range, but I expect it to be that of a single led - ie ~3-3.5v.
    To use the led and power pack you have, what you want is a boost driver that has an input voltage of 9-12.6v an output current of 2800mA & an output voltage range that includes ~14V. I suspect you will struggle to find one edit: eg this driver comes close, but 3A is just a bit too high for MCEs[/edit]. A HBFlex would do the job, but at $40 it may be more than you want to pay.
    May 2005
    The driver you tried works with a parallel configured MC-E. That would have a Vf of ~3.5V and as each die shares the available current they would each be driven at 700mA.
    Apr 2013
    Ah, that's the small print not on the eBay ad, and unfortunately eBay listings aren't specific as I've been asking many questions of the buyer about this particular driver.
    also with my serial wired mce's all three of the stars would then bump the Vf up rather than dividing it
    May 2005
    The driver linked by find_bruce in post #34 would work in place of the HBFlex. Each MCE would see 1A which is OK if you have really good heatsinking. I ran my old dual MCE light at 1A per star and it was fine.
    Another dual MC-E
    Originally started this light running at 700mA per star but later bumped it to 1A. Better color (very slightly greenish at low current) and a bit more light at higher current. There was plenty of heatsinking in that tank of a housing!
    Apr 2013
    Another dual MC-E
    Wow. Love the light body, looks very good. I will look to order the driver and add more fins on the rear plate. Mine looks underfinned compared to that beast
  1. 29er E-stay homebuild
    By ade ward in forum Frame Building
    Last Post: 11-18-2014, 06:28 PM
  2. M552 triple crank vs. 2013 SLX M670 triple crank
    By tryinghardrider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-01-2012, 05:31 AM
  3. x-post - my homebuild 29er - sub 16" stays
    By mickuk in forum 29er Bikes
    Last Post: 09-22-2011, 08:32 AM
  4. DIY Cree triple, done right!
    By bikeny in forum Lights DIY - Do It Yourself
    Last Post: 07-27-2011, 09:47 AM
  5. Custom-Built Triple Cree XR-E LED Light - Finished
    By achesalot in forum Lights DIY - Do It Yourself
    Last Post: 08-26-2009, 04:28 PM
