Results 1 to 2 of 2
    trailtech battery mounting
    I just ordered a trailtech light with their nimh battery. Does anyone have any suggestions on how to mount it to my frame?
    Not sure what your battery is like but for my square shaped battery I cut an old roundish detergent bottle pushed it in there and then put it in my water bottle holder. It worked fine.
    Another idea is put it in the waterbottle holder and just put velcro around it to hold it still.
    For another battery I used to use I got a small soft camera case that it fitted in nicely that had a small carry handle. I put the battery in the camera case and then into my water bottle holder and the small carry handle around my pump that is held firmly in its holder near the water bottle holder. The water bottle holder held it firm enough and I felt safe that if I hit any bad bumps that dislodged it the carry hand around the pump would stop it coming right around and hitting the ground.
